proTUNING Freaks
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      07-30-2014, 01:39 AM   #1
F82FTW
75
Drives: 17' M3 ZCP, 88' M5 Blk/Blk US
AD08R Fitment?
Anyone tried this yet? I want to do 295/30-19 in the back and 275/35-19 up front on STOCK wheels...is this far fetched?
F80 M3 ZCP - Current...E28 M5 1/30 Blk/Blk US Spec - Current...17' 911 - SOLD...E90 M3 - Sold...F82 M4 - SOLD...F02 750Li - SOLD...Austin MINI - SOLD...E82 135is - SOLD...E89 Z4 - SOLD...F10 535i - SOLD...E30 325is - SOLD
      07-30-2014, 06:08 AM   #2
Black Gold
590
Drives: M3
IMO, this is too wide for proper fitment on the stock widths
it will work, but it wont be stretched as much and this will cause slop in the handling and steering feel. the positive is that ad08r are much stiffer in the sidewall than PSS, which will counteract some of the softness from running a less stretched setup.
BMWs are designed with stretched tires compared to a lot of other manufactuers. this results in the tire getting a lot of support from the wheel and really sharpens up steering response. for example, an rs5 runs 275s but on a 9 inch wheel!
I am a big believer in semi stretched (not hella flush, but the max wheel width that can work with a given tire size) for the steering feel, sidewall support and subsequent handling improvements.
IMO, if I were to run ad08r, which I will when the PSS die if RE11 are not introduced in OEM sizes, I would run them in OEM sizes. That's a lot of tire.
If you want to go 275/295, IMO you need at least 9.5/10.5 width wheels.
And I still am not in love with running a 275 on a 9.5 inch wheel but you can do it.
FWIW
      07-30-2014, 07:03 AM   #3
jackkk
jackkk's Avatar
Russian Federation
73
Drives: M3 F80
275/30 front 295/30 back will be okay
F80 M3 SO/SO |BM3 St.1 91 oct.|Cattless DPs|Tractive P'n'P|Brembo 6pot|Rays G25 with CUP2 tires|GTS coding|
1M VO FBO (KW DDC) PTF st.2+ sold
e90 335i FBO jb4 sold
      07-30-2014, 09:49 AM   #4
F82FTW
75
FWIW
Thanks for the thoughtful reply; makes sense indeed. I wasn't aware of the loss in sidewall stiffness due to stretch. Guess we'll have to play this one by ear and see how long the PSS's last!
      08-01-2014, 09:53 AM   #5
Blaizon
Blaizon's Avatar
Drives: 335i Coupe & 335i Sedan
I'd be conservative with the ADO8r's they run big.
2008 Sparking Graphite 335i 6MT Coupe - Single Turbo
2007 Montego Blue 335i 6AT Sedan
f80post
