Meth on dyno
07-23-2014, 08:41 AM | #1 |
8
Rep 99
Meth on dyno
Hi i had 325 whp no meth ( very hot day ) and with meth i got 340, thats 15 whp gains and its to small i should be making more power, we found the problem though, the engine gets to little meth, cuz i had meth all the way home 900 km and it only used 7 liter total (50water/50meth)
The nozzler is a cm10 that should be big enough but i will buy a bigger, u guys think it will help ? Or its maybe the pump gets to little electracy what i read about in n54 section I have same kit as hotrod ( cooling mist recomended it, its for n54) but still that should not be the problem its feels like its flucating like a heartbeat (pulse) think it should be stronger Regards rami |
07-23-2014, 08:56 AM | #3 | |
51
Rep 719
ASE master tech (many moons ago)335xi- JB4 G5 iso/e50 custom flash/Custom meth/Borla mids/Custom x-pipe/DCI/ER charge pipe/Dual Ebay BOV's/Alpina B3 flash/Paddle shifter retro fit
07-23-2014, 09:11 AM | #4 |
3442
Rep 79,211
It's not the meth mixtures or the nozzle.
You need to increase boost and ignition to gain more power. Meth alone with no other changes makes only a little power because of IAT reduction. We would need before and after logs to determine what was missed. |
07-23-2014, 09:23 AM | #6 | |
Out Boosting...
243
Rep 3,987
07-23-2014, 09:24 AM | #7 | |
8
Rep 99
and cooling mist wasent helpful when mailing them and they recomended this kit, anoter guy (hotrod) runs same kit on his 335i and 335d so something is wrong installed or something |
07-23-2014, 11:45 AM | #8 | |
3442
Rep 79,211
07-23-2014, 05:47 PM | #9 |
171
Rep 2,682
Meth does not spray continuously. It's load based. If you're cruising the 900kms home you could in theory use no meth at all if you don't activate it. Now if you floored the pedal the whole way 900kms you'd last maybe 10 minutes before your meth tank ran out. 7L over 900kms sounds completely normal to me with 1 nozzle and occasional/frequent short WOT pulls on the highway.
I think you need to do some more research on how meth works and how to tune for it. That small power increase has nothing to do with not enough meth flow. You gained power because the DME normally pulls power to compensate for hot IATs. You said it yourself that it was a very hot day. All spraying meth does in your case is lower those IATs to reduce the compensation by the DME. If you were to blow dry ice cooled air into the intake it would probably give you the same power "increase". You need to tune the car for the extra octane, extra fuel and lower IATs to get more power. It doesn't matter what whoever it was that sold it to you said. That kit sounds like it's working perfectly. You just don't know how to get the most out of it yet.
07-24-2014, 02:15 AM | #11 | |
8
Rep 99
I did put the meth so it should ve full activated on 0.2 bar so it was activated all the way, why im posting in n54 section is cuz its a n54 made methanol kit and prolly more people have it here then m57 section Anymore tips, have any of u guys have coolingmist kit ? |
07-24-2014, 02:24 AM | #13 | ||
171
Rep 2,682
I could spray 10L/second with 69 1mm nozzles shoved in all ends and bung holes of the charge pipe and that wouldn't make me any more power. Probably just destroy the engine and everyone's fun in the process. People have explained above what you need to do to make more power with meth. Volume won't get you anywhere without a proper tune.
07-24-2014, 02:33 AM | #14 |
8
Rep 99
Oh thats why my tuner who make his own maps has a 800 whp m3 , nothing is wrong with the tune, when we were on dyno he said him self its drinking to little after like 20 - 30 puls it drank less then half liter
Something is wrong with the kit or how we wired it i will try bigger battery |
07-24-2014, 08:26 AM | #17 | |
34
Rep 1,093
Best of luck.
07 335XI (A008006) 6AT ~94K miles JB4 G5 ISO VSRF DP's
09 135I M (VK80379) 6MT. Race Project car. 1) Install Cobb/piggyback? and Motiv 600 Kit[HTA3076R w/ tial .82] 2) JRZ or Moton suspension. 3) Build high flow intake manifold with multi-port fuel and relocate OFH 4) Build full cage 5) Complete staged twin setup with HTA4205R [w/Tial 1.16] 6) Complete dry sump system |
07-24-2014, 09:11 AM | #18 |
Rep 254
maybe your pump is set to a low psi or your nozzles are clogged.
Did you check your lines? You could have air in your lines because you didn't prime it properly and you're barely flowing any meth. |
