speedo and gauge pod e92.....
07-22-2014, 01:44 PM | #1 |
65
Rep 515
does it pop out? or does the plastic screen/cover come off?
i had my vehicle into dealership yesterday and i told the techs about a creak i was having in my dash just above the gauge pod they told me they took it out and lubed it somehow and now the creaking is gone but i noticed a weird stain on the bottom right of the inside of the plastic screen and i want to see if i can clean it off, otherwise i will bring it back in how could have the lube got down in there? thanks |
07-22-2014, 05:27 PM | #2 |
packet jockey
16
Rep 299
Two screws at the top, it kind of tilts downward then you can pull it out. Single cable at the back to disconnect. I believe they are T9 screws.
The DIY cluster LED swap shows how to get it out.
2011 335d
With great torque comes great responsibility |
07-22-2014, 05:39 PM | #3 | |
65
Rep 515
07-22-2014, 05:57 PM | #4 |
No 55mph
1622
Rep 8,476
That removes the cluster - but you will then also have to remove the plastic lens from the cluster to clean the inside - no big deal though...
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
07-23-2014, 03:49 AM | #7 | ||
No 55mph
1622
Rep 8,476
Here from DIY section: Remove the 2 T-10 torq screws Lift up the top of the dash and pull down and out on the cluster. It should come out pretty easy Push down on the center tab and pull the lever all the way down to the cluster until it clicks and the plug will release Remove the 4 T-9 torx screws from the back Using flat screwdriver or fingers, release the 8 clips around the cluster Lift off the front of the cluster. Now you have 2 pieces If you want to see the entire post that deals with Needle Removal/Install & different color LED swap: http://www.e90post.com/forums/showth...=gauge+cluster
