07-21-2014, 07:52 PM | #1 |
28
Rep 333
What to check before a long road trip?
Considering the car is so new (1800 miles so far), do I need to take it in for an inspection before my 3000-mile road trip?
07-21-2014, 08:13 PM | #4 |
28
Rep 333
07-21-2014, 10:28 PM | #5 |
10656
Rep 6,936
Drives: 2018 M2 AW DCT
Biggest thing is to check the tire pressure.
07-23-2014, 03:21 PM | #6 |
208
Rep 602
Am also on same page with fresh oil change. Get break in oil out and new in. Yeah, I know...I'll get flamed for it sounding too old school, but if you are taking that long of a trip with sustained speeds, most likely, nice to have fresh oil now that break-in time is completed.
At same time, have a tech--- or DIY-- double check torque on wheel bolts. They may be OK but may also have worked the adjustment-need magic after 1800 miles. Air inflation as above is a must. Don't assume its the same as when you picked it up. And even then it might not have been spot on. Have a great trip... |
07-23-2014, 04:07 PM | #7 | |
28
Rep 333
07-23-2014, 11:54 PM | #8 | |
1399
Rep 5,262
http://www.fcpeuro.com/products/bmw-...FctzMgodozYAPw Last edited by pikcachu; 07-24-2014 at 12:02 AM.. |
08-15-2014, 12:58 AM | #9 |
Rep 2
I agree with checking your tire pressure before a long trip. Mine was delivered with all tires at 34 psi, which is two psi too high for the front and 2 psi too low for the rear. Once I put in the correct pressure the car handled much better. If you do change the pressure significantly to bring it back to specs you need to recalibrate the car tire pressure monitoring system. It is easy to do (instructions in owners manual).
08-15-2014, 08:43 PM | #10 |
lieb923
12
Rep 49
Drives: '15 M235Xi
M235 Oil
Iirc the oil spec is 0-40. Approx 7 qts. Enjoy the trip.
08-15-2014, 09:51 PM | #12 |
***** noob
1369
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
1800 miles and oil change? Dont waste your money, but do one after the trip
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
