2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum iPods the best option? for idrive
      07-21-2014, 08:33 AM   #1
martin mustang
Ireland
257
Drives: 640d,X5 45e, 911c4s, 635csi
Question on music via i-drive, are iPods the best option? From easy use like play lists and search ….
My experience so far is only with the Ipod Classic, with a good amount of space, but one down side to it is the resolution low compare to iphone or ipod touch, the album covers on display is not the best, hence can you get better result with memory stick?
      07-21-2014, 01:47 PM   #2
SonicEndeavor
48
Drives: 2014 535i MSport
Yes, in my opinion memory sticks are the way to go. The artwork resolution is quite good (provided the artwork in your music files is of sufficient resolution), plus you can play high resolution flac audio files without having to convert them to another format, and also dts 5.1 audio works well from the memory stick.
Additionally, you can copy from the stick to the iDrive hard drive without any loss in quality.
      07-22-2014, 06:29 AM   #3
martin mustang
Ireland
257
Thanks for your feedback SonicEndeavor, do you use any app to organise your playlist or simple folder structure?
      07-22-2014, 10:00 AM   #4
SonicEndeavor
48
Just a simple folder structure - one folder for each album and playlists in a separate folder. I drag and drop from iTunes then use dbPoweramp to ensure the album art is stored in the file since iTunes doesnt store the artwork in the file unless you use the manual add feature in iTunes.
It's a little cumbersome but it works well. Although if you have a large library it will take some time for iDrive to index it.
As another option, I just started using the Amazon Prime music service which integrates nicely with the iDrive. You can either download the music via wifi or stream it live.
      07-22-2014, 10:25 AM   #5
Sjoerd
Sjoerd's Avatar
Netherlands
19
Drives: MY18 G11 750i, MY13 911S x51m7
I use a 160gb Ipod Classic. Before on memory sticks but prefer the Ipod. About 120GB now is taken
For me Ipod works great; much better than memory stick or bluetooth Ipone.
I only have MP3; not FLAC eg.
What I do as well is play music DVD's. Suits the B&O quite nicely
Current: MY18 G11 750i (daily), MY14 Porsche 991 S (x51, m/7) (fun), MY17 Mini Clubman JCW All4 (GF)
Retired: MY14 F10 535d, MY11 F11 530d (temp), MY10 F10 535i, MY87 BMW E30 325i (fun), MY74 BMW E3 2500 (fun) (and more..)
      07-22-2014, 11:37 AM   #6
Dodge DeBoulet
BMW Virgin
Dodge DeBoulet's Avatar
Drives: 2014 535i XDrive
2014 535ix  [0.00]
I just grabbed the Itunes Media directory from my PC and copied it onto a 32GB thumb drive. All of the album art seems to work fine even though it's in separate files.
I have a 2014 535ix, if that makes a difference.
2014 Dark Graphite Metallic BMW 535i XDrive
Date Purchased: 07/02/2014
Options: Cold Weather Package, Driver Assistance Package, Multi-Contour Seating, Premium Package, Black/Dakota Leather Upholstery
      07-22-2014, 12:11 PM   #7
SonicEndeavor
48
It depends on how the artwork was obtained. If you let iTunes find the artwork, then the artwork is not embedded in the file. If the music was downloaded from other sources and already has the artwork embedded or the user adds the artwork manually in iTunes, then it's already embedded and will work fine.
      07-22-2014, 12:55 PM   #8
Dodge DeBoulet
BMW Virgin
2014 535ix  [0.00]
All of the albums in question were purchased through iTunes, and I did nothing to obtain the artwork for them. So there goes that theory . . .
      07-22-2014, 01:33 PM   #9
SonicEndeavor
48
Purchased from the iTunes store is different. That artwork is embedded in the file. I'm talking about music imported from other sources like CD's where the iTunes software on the computer finds the artwork and adds it. iTunes adds the artwork to a folder on the PC instead of embedding it, so if you copy the files to a flash drive, there's no artwork.
      07-22-2014, 02:57 PM   #10
Dodge DeBoulet
BMW Virgin
2014 535ix  [0.00]
Ok . . . but there are also jpg files in the directory with the m4a files, which seems somewhat redundant. I guess I wouldn't put it past Apple, though
      07-23-2014, 05:13 AM   #11
TheGr8Swami
TheGr8Swami's Avatar
Drives: 2012 550i M-Sport w/XDrive
I have a question for the iPod owners.. Are you using a regular iPod USB cable or the special cable from BMW? My 2012 5 series experience multiple iPod restarts and shows fault codes and the technician stated I needed to use the BMW iPod cable to eliminate this issue!??!
2012 550xi MSport - everything but TV's in the head rests!
      07-23-2014, 06:57 AM   #12
Dodge DeBoulet
BMW Virgin
2014 535ix  [0.00]
I tried using my iPod Touch 3G with the regular USB cable, but it acted very strangely; it kept beeping like it was being plugged/unplugged and I couldn't really control it. I'm wondering if the USB voltage is low on that port.
My phone (HTC One M8) works fine with ConnectedDrive and a 32GB thumb drive works too. The phone would normally show an error charging if the voltage is low, so I'm not sure what's going on . . .
      07-23-2014, 07:08 AM   #13
TheGr8Swami
Yes, it is a voltage issue that the technician is reporting. I may purchase a BMW cable from Amazon this week to see of the random restarts still occurs.
      07-23-2014, 03:52 PM   #14
SonicEndeavor
48
I use the regular USB cable and haven't encountered any issues, but my iDrive is NBT (2014) vs. your CIC iDrive so there are hardware differences.
      07-24-2014, 02:50 PM   #15
Grover432
22
Drives: 2013 535 XDrive
I didn't know my 2013 535 X Drive had a HDD to copy music to. How do I do it?
2013 535 X Drive, Alpine White/M Sport/Executive/Apps/Black Dakota/Fineline Anthracite
      07-24-2014, 03:31 PM   #16
SonicEndeavor
48
There's a partition on the iDrive HDD dedicated to the Music Collection where you can rip CD's to or copy music from a USB drive.
Here's a how-to:
www.bimmerfest.com/forums/showthread.php?t=417311
It's also explained in the entertainment/ navigation manual.
      07-25-2014, 02:39 AM   #17
martin mustang
Ireland
257
Here's a how-to:
Nor sure I have HDD in my 2011 car! I need to check this out, thanks for the link
      07-25-2014, 07:47 AM   #18
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
I've got most of my music on the HDD too.
5post
