07-20-2014, 07:57 PM | #1 |
14
Rep 147
Oh My!
Had jb4 running for a month... No problems.
Installed MPE... No problems This afternoon... Installed BMS intake... 5 minutes drive no problems. 6th minute....problem. CEL came on... Then Drivetrain Malfunction... Maximum output not available. Could not connect to JB4 at all... (Have done many times in the past) I completely removed the JB4... No help... I disconnected and reinstalled the factory intake... No help. Car is now completely factory, with MPE... CEL STILL ON DRIVETRAIN MALFUNCTION... Still going on... Any damn clues anyone? |
07-20-2014, 08:40 PM | #2 | |
169
Rep 926
make sure u have EVERYTHING connected properly |
07-20-2014, 08:42 PM | #3 |
14
Rep 147
So... What do I check for?
I guess it's limp mode... Maxium power not available. Took it for a spin.. See if it may reset itself.. 8 miles... No help. What did you do? |
07-20-2014, 08:50 PM | #4 | |
***** noob
1369
Rep 10,479
Drives: 325xi>M235i>428GCx Mspor
2006 325xi (Sold)
2014 M235I (Current) 2015 428xi Gran Coupe (STB) |
07-20-2014, 09:44 PM | #7 | |
***** noob
1369
Rep 10,479
2006 325xi (Sold)
07-20-2014, 09:52 PM | #8 |
14
Rep 147
Please forgive me, as I didn't hook it up. However, when disconnecting it.. I reattached two BMW connections.
Both on the right side of the car. 1) back on/close to the firewall, had to remove engine cover to access it 2) behind the air box and down. Does that make sense? |
07-20-2014, 10:36 PM | #10 |
***** noob
1369
Rep 10,479
My bad, i meant MAF sensor. Did u disconnect that?
2006 325xi (Sold)
07-21-2014, 07:26 AM | #12 |
256
Rep 1,040
Not this will clear the CEL, but when you add/remove the JB4 it is recommended to remove power to the car by disconnecting the battery. I did this procedure everytime I have installed a device or remove one; always disconnect the battery.
Disconnect the battery for 1 hour and reconnect and see if the CEL will clear itself. If not, you will need an OBDII reader/reset tool to clear the fault. |
07-21-2014, 10:31 AM | #16 |
What goes here?
450
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Would be helpful if we knew exactly what the codes were.
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
07-21-2014, 10:40 AM | #18 |
***** noob
1369
Rep 10,479
If all connections are good (no air leaks) then the MAF is reading to much air mixture causing CEL.
I have seen alot of this (bsm intake) cel issues.
2006 325xi (Sold)
07-21-2014, 10:54 AM | #19 |
12
Rep 60
Reading this is really putting me off buying a jb4. It could however be possible there is a fault that is nothing to do with your upgrades. If you can't sort it out with the advice above then I would get it back to stock and take it to BMW.
07-21-2014, 12:29 PM | #21 | |
***** noob
1369
Rep 10,479
This is why i dont like hot air intakes on turbo cars
2006 325xi (Sold)
07-21-2014, 12:47 PM | #22 |
256
Rep 1,040
Sounds like you need to leave everything stock; which you said you did. Double check all you sensors.wires are connected properly; reseat them. Try clearing the codes again. If same code comes up then you will need to take it to BMW for diagnostic check. Be prepared get charged for the repair work.
