F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > Bolt Patter
Studio RSR
      07-19-2014, 09:17 AM   #1
rustyminded
rustyminded's Avatar
248
Drives: BMW 328i
Bolt Patter
What is the bolt pattern that will fit F30, I want to upgrade to 18", I know they are 5X??
which one will fit ?!
5x1143
5x112
5x108
5x100
F30 328i - 8 auto.. JB4-EWG harness, OCC, Injen Intake, AFE Scoop, AFE dp, AA axle-back - H&R springs, H&R Rear SB, Front Strut, F&R BMS spacers..
      07-19-2014, 10:12 AM   #2
Presario
Presario's Avatar
Drives: 2018 X3 M40i, 2016 435 GC
5x1143
5x112
5x108
5x100
LOL none of the above. It's 5x120.
      07-19-2014, 12:31 PM   #3
rustyminded
248
Drives: BMW 328i
Holy hell , I have wheel spacers can I use them with their bolts ?
      07-20-2014, 06:29 PM   #4
Presario
Presario's Avatar
I would not run any spacer without extended bolts, especially if it's over 5mm. Your safety is just not worth it!
      07-20-2014, 09:37 PM   #5
rustyminded
248
Drives: BMW 328i
yes it's the wheel spacer bolts that came with it, or you mean i will need different ones as well ?
      07-20-2014, 09:51 PM   #6
Presario
Presario's Avatar
Okay got it. If they're extended bolts that came with the spacers that will work. But you have to make sure the bolts work because all F models went to a new bolt thread size of 14x1.25 from the older BMW size of 12x1.5. Good luck!
      07-21-2014, 02:08 AM   #7
rustyminded
248
Drives: BMW 328i
ah don't worry they are BMS got them already for my stock rims & they fit perfect but the problem is they are 12mm front & 15 mm rear , won't this be too aggressive for 18x8" & 18x9" rear ? what about offset what do you think is the right offset for this size of spacer to fit 35 ot 45 ?!
greatly thanks
f30post
