Mo Reviews
Go Back   BMW M3 and BMW M4 Forum > BMW F80 M3 / F82 M4 Technical Topics > Wheels | Tires -- Sponsored by The Tire Rack
      07-12-2014, 06:21 PM   #1
BimmerBoomer
demoted
BimmerBoomer's Avatar
445
Drives: 2022 Audi S5 Sportback
Confused about winters for M4...
I'd like to buy wheels for a square setup on my 435i xDrive to transfer to a new M4 in a year or two. It looks to me like an 8" wheel with 32mm offset and 225/45 18 tires should work well for both vehicles. Yes or no?
      07-12-2014, 09:09 PM   #2
gthal
gthal's Avatar
1901
Drives: 2018 340i xDrive
Maybe but until you test fit it, very difficult to know for sure.
2020 X3 M40i | Black | Current DD
2020 C8 Corvette | Z51 | Torch Red ... built and waiting for delivery
2016 M2 | Long Beach Blue | 6MT
2015 M4 | Austin Yellow | DCT
2012 MB C63AMG | 2011 E92 M3 | 2010 E92 M3
      07-12-2014, 09:15 PM   #3
BimmerBoomer
demoted
445
Well gthal...
In terms of tires, only 225/45 18 or 245/40 18 makes sense for a square setup. Assuming Tire Rack has it right, BMW is recommending a staggered 245/40 and 265/40 setup.
      07-12-2014, 09:20 PM   #4
gthal
gthal's Avatar
1901
That's interesting... I am planning to run a 255 square set up. The issue I'm having is that very few vendors can get me a wheel they "know" will fit at this point (hence why I said a test fit is probably needed... especially with 18's). The vendors I spoke to are concerned about brake clearance and the concavity of wheels... not necessarily the offset.... until they can test fit a car.
I plan on running a 19x9 ET 25 to 30'ish and a 255/35-19 tire.
      07-12-2014, 10:59 PM   #5
BimmerBoomer
demoted
445
Hmm...
It looks like I might be safer to go with 225/40 19s on an 8.5" x 19" wheel with a 30mm offset. 225 should work for me - I ran my 335i coupe w/ Dinan stage 2 for 5 winters on 225s with 421 foot pounds of torque - and no LSD.
      07-13-2014, 12:17 AM   #6
bdoooh
Drives: 2014 SSII M5 CP
Yeah the concavity is weird in these stock wheels, see my thread..
Wheel Fitment BEWARE! http://f80.bimmerpost.com/forums/sho....php?t=1007832
      07-13-2014, 12:58 AM   #7
BimmerBoomer
demoted
445
Yeah, I read your thread...
It was the reason I posted. Looks like I'll wait until someone finds a wheel, or buy 4 of the OEM front wheels. No way I'm going staggered.
      07-13-2014, 08:36 AM   #8
bdoooh
Well the wheels I got for example or staggered but you can still run a square setup. For our winter OEM winter wheel size, tirerack recommends 245 squared.
      07-13-2014, 10:00 AM   #9
BimmerBoomer
demoted
445
Yeah, but that eliminates all rotation since you can only rotate high performance winters front to back. I think if I were choosing just for the M4 I'd go with 235/40 19s.
      07-14-2014, 01:50 PM   #10
StageIIGroup
StageIIGroup's Avatar
Drives: BMW M
Your current wheel setup for the 435xi will not work with the new M4 as they require lower offsets for brake clearance.
      07-15-2014, 02:28 PM   #11
BimmerBoomer
demoted
445
I'm not as confused as you appear to be.
      07-18-2014, 09:13 AM   #12
milhouse
Norway
37
Drives: M4
BMW recomends and I am going to run 255/35/19 on the oem winter rims. 8,5 and 9* 19. 19 because og the ccb.
Nokia hans soft winter tires in that size. Studs and normal. I am going for studs so i can take the car on the icetrack....
I can check the 18 oem setup if you guys want. the have a continetal tire for there normal setup but that is usless in Norway.
2015 M4 MG on SS.
X:2002 M3 ESS JeppeJ edition,2011&2010 335i DCT,
98 M Coupe, 10 X6 30d, 09 z4 23i +++++
      07-18-2014, 10:20 AM   #13
signes
signes's Avatar
Drives: 991 GT3 RS
Nokian HAS Hakka R's in that size? That would be great, best winter tire I've ever owned.
GT3 RS | Desperately seeking the next great M car...
      07-18-2014, 10:59 AM   #14
gthal
gthal's Avatar
1901
Yep... their new R2 if memory serves me. That is what I will use this winter.
      07-19-2014, 06:36 AM   #15
Floridagator
Obsessed with braking
Drives: 2015 BMW M3
2015 BMW M3  [0.00]
For the 18" setup, the recommended tire is the 255/40R18. The ETK database shows the recommended tire as the Conti Winter Contact, but Michelin's euro websites also show a Pilot Alpin for the BMW. Unfortunately both are unavailable in the US at this time, but that may change as we get closer to the winter months.
Search this Thread:
Advanced Search
f80post
