BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Mechanical Maintenance: Break-in / Oil & Fluids / Servicing / Warranty > Aim Halogen Headlights
      12-11-2007, 08:55 AM   #1
P2
P2's Avatar
53
Drives: 2023 i4 M-Sport eDrive 40
I found a thread on aiming the Xenons but not Halogens.
For Halogens, I think I found the screws for the adjustment. Can anyone confirm it is the white round plastic piece in the picture? Does clockwise adjust up or down? Thanks for the help.
p2
      12-11-2007, 04:53 PM   #2
jetblk328i
jetblk328i's Avatar
309
Drives: X3 M40i
Yep that is it right there.....i believe clockwise is up....
      12-12-2007, 05:46 AM   #3
P2
P2's Avatar
53
ok, I'll play with it a bit.......
      09-20-2009, 03:22 PM   #4
vince88
vince88's Avatar
31
Drives: '13 328i Xdrive Sports
According to the Xenons thread, clockwise is down.
Of course I'm not sure about Halos, but I dont see why it would be different.
Maybe some1 can confirm...
      11-02-2009, 04:23 AM   #5
Jahman
Drives: F30 320d MSport
I want to adjust mine also, Is it clockwise up or down?
      04-04-2010, 07:07 PM   #6
konradsa
konradsa's Avatar
19
Drives: 2008 328i E90
I just tried it out on mine, ccw is higher, cw is lower.
I just did three turns ccw, it's quite a bit higher now. Will have to test drive it to see whether it is too high. Would be good if other people could post how many turns they adjusted their halogens.
EDIT:
Yep.. three turns ccw seems to have made it much better, and nobody was flashing at me on a test drive. So I can recommend that setting.
      04-15-2010, 02:09 AM   #7
WingZeroX5
WingZeroX5's Avatar
Drives: F80 / F30
EDIT:
I turned mine just now like 20 times before the stupid thing even starts to move up >.<
but, it's much better now.... before it was practically aiming completely down & one of the things that I always wanted to change
      01-16-2011, 06:25 PM   #8
teleopti
teleopti's Avatar
Drives: 07 328i Sport
informative post!
      05-06-2011, 01:03 PM   #9
nky
7
Drives: E90
I can't adjust my driver's side headlight angle by turning the white screw but my passenger's side can be adjusted with no problems. I tried turning the screw all the way c.w. or c.c.w. until I meet resistance and there is no change to the height of the driver's side light. Is there a way to fix this or am I screwed?
      06-24-2015, 07:26 PM   #10
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
resurrecting this thread... in the picture that is one of the adjustments. there is a plug in the fender drain line that if removed reveals the outside adjutment for the headlight, does anyone know why you would adjust one or the other?
OEM Black grill and Blackline tails - LCI halogens with Lux V2 coded as DRL - 3M Crystalline - BMS PBX - OEM Euro Airbox with K&N - Hardwired CTEK - Bilstein B6 w/OEM springs and SP perches - Conti DWS06 - HiFi-Helix DSP - JLAudio HD/XD-Morel - CD changer trim - AE optical out
      06-27-2015, 09:20 AM   #11
PichaDis11
PichaDis11's Avatar
Drives: E90 N52
That one in the fender is for left or right alignment.. Both alignment screws handle High/ low beams.
Retrofits: 322, 609, 6FL, 6NR, 6VC, 2TB..
Upgrades: Bilstein B8 Eibach Spring kit
      07-01-2015, 08:43 PM   #12
cdgatti
cdgatti's Avatar
255
Drives: e90 328i
Thanks!
