2010 2011 BMW 5 Series Forum F10 BMW 5-Series (F10) Forums General 5-Series Sedan and Wagon (F10 / F11) Forum Powertrain Malfunction- post exhaust install
      07-03-2014, 02:38 PM   #1
WhiteWalker
16
Drives: BMW
Question Powertrain Malfunction- post exhaust install
Recently installed a Meistershaft GTC on my '11 550i Dinan S2.
Under medium+ and steady throttle-- 5th and 6th gear , the car delivers a POWERTRAIN MALFUNCTION since installing my exhaust.
The boost seems to vanish and the car is not lifeless, but certainly running with significantly less power.
Recently had it at BMW where my mechanic advised of a potential vacuum left open when the new exhaust was put on. It was supposedly corrected and I also upgraded to Dinan S3.
First time out of the shop where I had the room, same result Powertrain Malfunction.
Any advise or thoughts would be appreciated.
      07-07-2014, 04:10 PM   #2
Dhu
Drives: 2011 550
same thing
Had a very similar thing happen when I installed the dinan exhaust. Ultimately 10 months later, the check engine light came on and I took it to the dealership. They replaced all 8 fuel injectors...haven't a problem since....
_______________________________________________
Dinan Stage 5 550i, Dinan springs, Dinan Exhaust, Shockware
      07-07-2014, 08:13 PM   #3
ferrarif1
Drives: F85, G05, E46M3
Does this happen with the exhaust valve open? When I had my M5 exhaust, I forgot to connect the vacuum valves and the increased back pressure caused a reduction in boost / drivetrain malfunction. Reconnecting the valves to allow full flow solved the problem.
      07-07-2014, 09:22 PM   #4
WhiteWalker
16
Drives: BMW
Actually figured this one out with out a trip back to the dealer.
The seal on the vacuum bypass hose under the hood failed and was leaking air. I cut the hose down a 1/2" and resealed.
No further problems and back to full power!
Very strange feeling driving with 0 turbo assist, all motor.
5post
