Injector code
06-26-2014, 11:27 AM | #1 |
Rep 35
Injector code
Hi.
I had all my injectors tested recently and all came back ok but one came back with a new code?!?! Not sure why this is but thats what they told me. Can someone tell me whether I would need this coding bearing in mind it is the same injector just with a new code. ANy advice much appreciated. Cheers Steve |
06-26-2014, 12:51 PM | #2 |
33
Rep 650
If the code has changed I would say it needs coding again, as they are normally coded to the corresponding cylinder. Did they rebuild one? Just odd how its changed
06-28-2014, 06:37 AM | #3 |
Rep 35
Thanks for the reply dan.
No not rebuilt, just tested, so have no idea why it has a different code ?? Thanks for the response, guess I'll have to take it to the dealer for coding. cheers steve |
06-28-2014, 04:48 PM | #4 |
33
Rep 650
Or ring the injector place up and ask why coding was changed? I assume the spray pattern or quantity has changed compared to the original coding.
From what I know the coding is unique to every injector so I assume the code is for a certain injected quantity at a certain duty cycle on the injector if that makes sense?, |
