2010 2011 BMW 5 Series Forum F10 Steering Wheel retrofit from Non-Sport to M-Sport |
06-22-2014, 01:58 PM | #1 |
18
Rep 77
I looked everywhere and failed to find any information that will clearly state what it will take to change from Non-Sport (regular) to M-Sport steering wheel on 2013 535XI pre-LCI. If someone has done it or knows, please share the information.
My car has heated steering wheel but a non-sport, regular steering wheel. I don't want to put M-Performance or M5 but just update to a steering wheel if the car was originally ordered and sold with M-Sport package (downside of buying used vehicle) . I don't have any other fancy features (i.e lane departure, etc..). I looked on www.realoem.com and found many different options and after doing the research identified that I will need to get the following, as none can be reused from my wheel: 1. Steering Wheel itself 2. Vibrator Generator 3. Control Button module 4. Bottom decor plastic cover with M logo 5. Air Bag, Double Stage for US. My car has Automatic Transmission and I believe it is a Sport AT (I do have a button Sport/Comfort/ECO). I am not sure about options www.realoem.com provided in regards to 'Sport AT' and 'Sport AT=No'. Are there Non-Sport AT in US models? Can some one confirm if that is it? Is wiring harness connector the same between None-Sport and M-Sport models? Thank you for your help in advance.
2013, 535 XDrive, 112k miles
1997, 328is, 335k miles - Retired 1998, ML320, 200k miles - Sold 2018, Q5, 100 miles 2005, XC70 AWD, 160k miles |
06-22-2014, 02:12 PM | #2 |
G-MAN
44
Rep 241
hope this helps; i successfully changed my non-M sport steering wheel to the LCI M-sport. Mwpos did the paddle shift coding also!
http://f10.5post.com/forums/showthread.php?t=948806 |
06-22-2014, 09:04 PM | #3 |
18
Rep 77
Thanks sgt_gman2005. I guess it is very doable. I see you have done it to your car but you went wit the latest wheel design. I want to stay with pre-LCI M-Sport. Yours looks awesome but I am not sure I want to go this route. In either case I will have to get all of the components either way.
Did you reuse the original Vibrator Generator or purchased wheel came with one already?
06-23-2014, 08:48 AM | #5 |
Rep 28
Drives: F10 525d
If you have neither Active Blind Spot detection nor Lane Departure Warning you don't need the vibration generator. I believe the steering wheel P/N will be different as well.
06-25-2014, 02:50 PM | #6 | |
83
Rep 553
Regards,
MWPos |
06-25-2014, 03:07 PM | #7 |
121
Rep 211
Drives: 2015 F82 M4 DCT
I am trying to do this retrofit as well (to performance steering wheel 2).
The list of parts I was told to get includes: - Steering Wheel - Connecting Line/Cable (32307848331) - Rear Cover (32307848267) - Airbag (32307845798) - Multifunction Switches (61317849407) - Control Unit (61317848638) - Screws (32307848333) Currently waiting on the connecting line and screws to become available. I supposedly had the wrong connection line/cable before.
2015 F82 /// M4 DCT - BBS FI-R | Macht Schnell EVC | Eisenmann Performance | RKP GTS Lip | RKP Diffuser | IND Cosmetic Package | CF Seats Cover
2012 F10 528i xDrive - BC Forged HB05S | Meisterschaft GTC | 3D Front Lip | Vorsteiner Diffuser | MP Mirror Covers and Spoiler | ACS Springs |
