06-21-2014, 08:51 PM | #1 |
372
Rep 1,698
ACC Braking Question
Has anyone with ACC ever seen their car (using this feature) from behind during operation? I'm curious how braking is handled.
For instance, do the brake lights always light up under ALL braking conditions? I would imagine the answer is yes (for safety reasons), but I'm curious if anyone knows for sure. It made me wonder since sometimes the car is only slowing down 1 or 2 miles per hour to match the car in front, and it may need to do this off and on in traffic. Normal drivers may just lift off the gas and coast a bit, letting the distance between the car in front become slightly variable, but it avoids jumping on and off the brakes. Since ACC seems to more strictly maintain that distance, it uses the brakes often, even to compensate for 1 or 2 mph. If the brake lights are constantly on and off for these small adjustments, I wonder if it drives the party behind a bit nuts... as you'd probably appear to be a terrible driver off and on the brakes constantly. Anyone with experience riding BEHIND their F10 with ACC?
2017 BMW 650xi Gran Coupe | MSport | Exec Package | Driver Assist Plus | ACC Stop & Go | Adaptive Drive | B&O | Night Vision | Cold Weather | Active Seats
2015 Audi R8 V10 | Brilliant Red on Black | S-Tronic | Carbon Sideblades | Carbon Trim | Full Leather | Sport Exhaust | Illuminated Doorsills | I-Pod | Contrast Stitching Previous: '14 550xi, '07 335i, '01 325i |
06-23-2014, 09:25 AM | #3 |
372
Rep 1,698
It may call for an experiment, AP. I may see if I can get someone to drive the car with ACC on and ride behind them to check it out. It's more of a curiosity thing, but I know I get annoyed when I drive behind someone constantly tapping their brakes on the highway (for minor speed variations) - usually a sign they're either (a) following the car in front too closely, and/or (b) just a poor driver.
06-24-2014, 03:31 AM | #4 |
Rep 23
I have ACC and have tested this with a follow-car and cellphone
The car acts just like it would if you operated the brakes. As soon as you feel the car brake the lights come on. I've also been checking for my self when driving at night. You can often see the reflection of your brake light light up road signs behind the car and from my experience the brakes is activated almost every time you see the engine go into "regen" mode. (Blue efficient dynamics bar in the cluster) So to sum it up... when you feel the car brake the lights come on. So in some situations the following car will see your brake lights a little more often than if you operated the car yourself. And yes... cars with ACC will eat the brakepads a little faster than cars without ACC. |
06-24-2014, 06:26 PM | #5 | |
372
Rep 1,698
06-24-2014, 08:28 PM | #6 |
285
Rep 634
I asked BMW about this.
The reply I got was that when the car regulates the speed by lifting the throttle, with the gears or coasting nothing happens. But when the car applies the brakes, the brake lights come on as if you was pressing the brake pedal. |
06-24-2014, 09:11 PM | #7 |
372
Rep 1,698
Hmm... interesting. I guess the car DOES coast sometimes to regulate speed, but it doesn't appear to really happen in traffic but rather during "wide open road" use where going down a slight incline or something with no obstacle ahead.
06-25-2014, 02:27 AM | #8 | |
285
Rep 634
in slow traffic I guess the brakes are used a lot more, so I guess you are right about your assumption. I asked BMW this question because before I had ACC, when I was coasting, or braking using a gear down an incline, I would tap the brake, or just put my foot on the brake to get the brake lights on without actually braking to inform others that I was slowing down. |
06-25-2014, 05:58 AM | #9 |
2782
Rep 5,093
as we're talking about ACC , those of you who have this know that you can set 4 levels of distance from teh car in front. On my car it defaults to 3.
I've thought about this and on a dry road at say 60-70mph, I feel 4 bars is the closest I want to be to the car in front. If the car in front were to suddenly 'slam' on their brakes, could you stop your car in time. I think yes but Its pretty close. Anyone else had thoughts on this? Always thought eh rule of thumb was (at least for a dry road) , "only a fool breaks teh 2 second rule. namely allow 2 seconds between your car and the one in front. ACC set to 4 bars seems to be just about that, 3 seems a bit close. Asusming acc has the car in front 'radar locked' so to speak, if it did stop suddenly, I assume emergency break assist would kick in, not sure if it would be enough though. I think the 2014 models are improved in this respect. It can be quite frightening when a car in front stops suddenly, the distance between you and it decreases very rapidly indeed. |
06-25-2014, 09:52 AM | #10 | |
285
Rep 634
On motorways at 60mph I use 2 bars as with 3 the gap is so large that other cars constantly cut in. At 40-50 mph I use 3 or 4 bars. |
06-25-2014, 10:56 AM | #11 |
372
Rep 1,698
I was going to raise the point on the number of bars, as well, as this may heavily play into when coasting is used versus braking to regulate the speed. Perhaps the more bars (further distance) you're using, coasting is a more acceptable option for regulation of speed. The closer you are, perhaps braking is more necessary?
I tend to use only 1 or 2 bars. My car defaults to 4 bars, and the distance on the highway is tremendous. Even at 1 bar, it appears to be at least 2 seconds behind the car in-front. At 2 - 3 bars, it encourages a lot of people to cut-in... but this is in heavier traffic. At 2 or more bars, I've never experienced an issue with emergency braking. The car seems to respond well and can bring the car to a complete stop - and take off again when the car in-front begins to move. However, with only 1 bar, I've experienced the collision warning system kick-in when using ACC under emergency braking at higher speeds. My understanding is that ACC can only apply "some portion" of the car's braking force - and it's quite substantial from what I've seen. However, in true emergency braking situations, under very heavy braking of the car in-front, the collision warning system has blinked and beeped at me, and I've responded by applying the brakes myself. Would ACC have stopped the car regardless? I don't know - and I didn't want to find out. After re-reading the manual on the above subject, it appears that if the collision warning kicks on, you need to manually press the brake pedal - the car may not be able to apply enough braking force alone via ACC. I've had this scenario happen a handful of times, and each time I was able to safely stop without using all of the cars braking force - no squealing tires or ABS kicking-in, etc. So, I'd probably conclude that more bars may allow the car to regulate speed more frequently via coasting versus braking, but less bars may cause the brakes to be used more heavily to more strictly maintain the smaller distance. Obviously, I don't know this for certain, but I may experiment with it to see. I also believe 1 - 4 bars are all completely safe, but clearly the 1 bar setting may result in situations as I've explained above, where collision warning kicks on and causes you to intervene.
