01-19-2020, 02:29 AM | #133 | |||
4425
Rep 4,109
@moderator: what's the story? I'd like to understand the rules a little better. Last edited by limeypride; 01-19-2020 at 03:14 AM.. |
01-19-2020, 09:42 AM | #135 | |
13001
Rep 18,728
But, I dyno'ed my F97 X3MC. The result on California 91RON pump gas is the same as what Germany claimed. 100hp gain at the crank. Yes, it is photoshopped Dyno, like some haters said. Lol.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
01-19-2020, 01:24 PM | #136 | |
4425
Rep 4,109
Mustang dyno: stock pull + map 1 on WA 92 octane pump gas Same Mustang dyno: map 6 on same pump gas (might've been octane booster, too--safer to assume so) … both pulls were taken on the same day within an hour of one another. These are also 4WD pulls as opposed to RWD-only required by dynos with a non-connected front and rear. Last edited by limeypride; 01-19-2020 at 03:35 PM.. |
Hockeytyme575.00 |
01-19-2020, 02:00 PM | #137 | |
21
Rep 73
Can you share what boost settings you used on that map 6 run, and how close to the target were you getting? A log and a screenshot of the user adjustment screen for map 6 would be great...curious if you used the default duty bias too.
Thanks Quote:
01-19-2020, 02:19 PM | #138 | |
575
Rep 754
My 2020 wouldn't even run on map1 when I first installed it. I'm not sure if it was a 2020 thing or the fact that I had intake, DP's, and exhaust. I took a number of pulls and runs and then analyzing logs before we got the duty bias right along with some other changes and different firmware. From there I was able to tinker with the other maps including 6 and then even more duty bias changes were made. I would use the stock ones for a pull or two and then have the logs looked at and make adjustments based on your car.
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires |
01-19-2020, 02:33 PM | #139 | |
21
Rep 73
I’m not looking to use his settings. I more curious to see how much boost and the difference between my settings...and how close he was getting to the additive target. I assume some Booster was used in his map 6...thats a pretty big jump from 1 to 6. I’ve been using map 6 for years...running custom
Firmware with 6 currently. I read my own logs and then work with Terry for custom firmware adjustments. Quote:
01-19-2020, 02:50 PM | #140 | |
575
Rep 754
I run almost as good on map2 (5.3lbs) as I do with map6 at 6lbs so I really only use map6 if I trying to get a super fast run. I feel the sweet spot on this car is around 5.5 to 6lbs. I'm also running intake, dps' and exhaust. He is completely stock and ran a 10.3 on his map6 at 5.5lbs
01-19-2020, 03:09 PM | #141 | |
4425
Rep 4,109
It's way too far back to know since those dynos were taken in May of 2019. I've also completely changed the way I use map 6 since learning last year that it has an additive mode. Back then, I was running map 6 with absolute targets. You might find posts from me with pics of the map 6 setup but, like HockeyTyme, I'm always a little nervous posting them in case someone simply copies and uses them with say $hite gas. Currently, I tweak the targets a little here and there on almost a weekly basis I'd guess. I can say there are no duty bias changes because Terry's never instructed me to change any based on his log reviews and, frankly, I don't understand them well enough to conclude a change is needed myself. I started using octane boosters right around the time these dynos were taken so these runs could be either with it or without it--let's assume with. My current map 6 starts at +3, then incrementally caps at +5.5 lowering back to +5 at 6500 and 7K. I also had to raise boost safety a little to accommodate that. I'm currently running 92 octane pump gas with 6oz of BOOSTane Pro per tank. However, I've been testing map 2 for almost 2 weeks (most of that time wasted because of snow) to see how well it performs with its +5 additive against my map 6 peak of +5.5--as it stands, it's tough to tell the difference except in the lower RPMs--Dragy concurs for the most part. What's your setup: car, gas, other mods, octane booster, etc.? |
01-19-2020, 03:34 PM | #142 | |
21
Rep 73
I’m an 18 base with just drops in...i played with the Gamma intakes and found the filters they provide actually restrict airflow once pushing past 22psi...so back to drop ins... for now. I also ran the AWE catback for a while but the cold start was just becoming too much. I run map 2 for normal use with bias under 35 to 4.5k and then from there i rapidly scale up to 75 by 6.5k. In map 6 I will run + 5.5, have gone to 6.5..rarely will I get to the true target I’m normally under target by about a pound. I’ve found on my car I need to be pretty aggressive on the bias to avoid a spike down low.
In terms of fuel I almost always run sunoco 93 with a mix of GT260(100) from the pump...normally it puts me around 96 octane. I do this as I ran into poor fuel in my area twice over the years and its just not with the risk. I used boostane for a bit and it ended up killing my O2s and really ate my plugs, I was aggressive on the mix so I wasnt too surprised. I’ve been on here for a while, but had to change username as BMW gave me some issues over a non-related issue, they spent 30 days fixing the issue and went digging into the data to try and point the cause to me. Long story short the JB4 left no trail, they even documented no evidence of piggyback found, and thats after having Corp out twice and the homeland look into the data. They did give me a lot of hassle over the 10+ uses of launch control...they log each time we use it and will try to use it against us it seems. Quote:
01-19-2020, 03:39 PM | #143 | |
4425
Rep 4,109
Do you have any timeslips or Dragy numbers? lol on the launches! That's absurd--why give a car a feature if it's frowned upon to use it... makes no sense. I launch this car every reasonable chance I get--suffice it to say, I'm well over 10 . The 2020s have a trick that the earlier F90s don't (as far as I know): in MDM mode and using manual shifting, if you brake boost, the transmission uses that special shift mode it typically reserves for full Launch Control scenarios--I use this a heckuva lot. Last edited by limeypride; 01-19-2020 at 03:44 PM.. |
01-19-2020, 03:51 PM | #144 | |
21
Rep 73
I had to fight with the BMW case manager over and even refernce them to the owners manual listing how to use LC...they gave up after that.
I’ll post some dragy runs in a few. normally on map 2 only reaching about 4psi of the target I’ll see a 10.6-10.7@133-134, thats without using LC and just mashing the throttle ( 1.75-1.78 60’) with LC I’m sure 10.3-10.4 are where it would end up. Once I’m back on summer tires I’ll get some LC runs in. 60-130 have been high 6.8s to 7.2s, Dragy does drive me nuts anymore as the elevation is never accurate. It will vary almost 2% in elevation on the same exact road from time to time. The shift feature is really what I loved about LC, ultra fast and better timed full boost shifts. I wonder if there will be an update to the 18-19 Quote:
01-19-2020, 03:56 PM | #145 | ||
4425
Rep 4,109
My faster runs are almost all 1.57s 60ft and a 0-60mph between 2.59s and mid-high 2.6s. Best 1/4 is 10.33 at 133 but that's on a farm road and I'm losing a lot on the higher end as the car takes flight from the undulations. I'd expect mid-high 10.2s in more optimal conditions. The launches are good, though, just need to nail it at both ends. |
01-19-2020, 04:07 PM | #146 | |
21
Rep 73
As you can see by the 60 here no LC, this was on my snow tires running map 2 and reaching about 4psi over stock. Even when I would use LC I never got into the 1.5s, 1.63 was my norm. I wish dragy used the same slop error margin Vbox did, I should see how Vbox reads for me...if it will even work after all these years sitting in a box. Quote:
01-19-2020, 05:11 PM | #147 | ||
4425
Rep 4,109
Your elevation changes are rendering those runs invalid—is that what you meant by the altitude problems? |
01-19-2020, 05:32 PM | #148 | |
21
Rep 73
01-19-2020, 07:06 PM | #149 | ||
4425
Rep 4,109
01-19-2020, 08:08 PM | #150 | |
21
Rep 73
I have not compared to the car. Oddly it wasnt that bad till about 6 months ago, I’m thinking about just getting a new Dragy and see if that helps. I dont know about you but its battery doesnt last anymore, I have to keep it plugged in.
01-19-2020, 08:33 PM | #151 |
4425
Rep 4,109
EXACTLY the same problem, yup.
