03-08-2023, 04:58 AM | #331 |
2940
Rep 2,538
QUESTION
10X20 et 14 285/35R20
11X20 et 23 295/35R20 I know for a fact there are people here that know the exact answer to my question so I’m really hoping someone chimes in. Right now my car is coming with the stock 20 inch wheels. If I go with the above sizes how many millimeters closer to the fender will the front and back wheels be? How many millimeters further out will they be? I don’t even know the stock size wheels and offsets other than I know they’re at 20 inch wheels. Thanks in advance |
03-08-2023, 07:41 AM | #332 | |
Perennial PFC
338
Rep 1,275
03-08-2023, 07:46 AM | #333 |
Perennial PFC
338
Rep 1,275
03-08-2023, 09:52 AM | #334 | |
2940
Rep 2,538
03-08-2023, 01:21 PM | #335 | |
IG: @M5RCY_
365
Rep 318
I am running 21x10.5 and 21x11.5 with slightly more aggressive offsets and i am VERY happy
Autotecknic.com - code: M5RCY for 12% off
Project Gamma - code: M5RCY for 5% off Dura-Coating - code: M5RCY for 20% off |
Patton2502939.50 |
03-08-2023, 01:47 PM | #336 |
2940
Rep 2,538
Cool. So you are happy with the specs I provided? They will work and not stick out too far or cause any rubbing?
03-08-2023, 03:20 PM | #337 |
IG: @M5RCY_
365
Rep 318
They will poke out slightly, but I went for that look. I am lowered on 285 F and 295 R tires with no rubbing anywhere
03-08-2023, 03:24 PM | #338 |
2940
Rep 2,538
So you are saying you have the exact same specs I’m thinking about doing? I wish you had a picture of looking right down the side of your car so that you could see exactly how far the wheels stick out. Also, in the pictures you provided those tires looks stretched on those rims. What are your thoughts?
03-08-2023, 05:11 PM | #340 | |
IG: @M5RCY_
365
Rep 318
If your worry is that it will rub - rest assured ZERO rubbing issues and again i am lowered on F90 H&R Springs. The rear 295 does stretch more than I wanted but I wanted to be safe that I would NOT rub since i am lowered or ELSE i would have gone with 305 in the rear. Another reason I did NOT go with 305 in the rear is because I would not be able to fit 295 in the front with my wheel specs. The 285 just BARELY clears inside the fender liner when the wheel is turned fully either way. I was told and read that we should keep tire widths only "1 size wider" from front to rear to match OEM ratios (OEM is 275/285, I went with 285/295). I cannot confirm this but I was told than running 2 sizes wider, it can "throw off" or eventually cause some sort of damage with the xdrive...how and why? I do not know. BUT I DO personally know another F90 in LA, CA even lower than me running 275 in the front and 295 in the rear (2 width size difference). My fear for you is that 305/35 is more meat than 305/30, and I am running 30 profiles, you will be running 35. Just trying to understand your concern here. Are you worried about rubbing, because you should not worry about it, you'll be fine! And asking people here about a 1-2-3-4-5mm difference on wheel/tire specs might be harder than you think, even if the platform has been out and modded since 2018. Ill be back with photos from the top later this week
Patton2502939.50 |
03-08-2023, 05:28 PM | #341 | |
2940
Rep 2,538
03-08-2023, 06:26 PM | #342 | |
4148
Rep 3,701
Drives: 2022 M5C
Not a BMW guy...but certainly an M5 guy.
Patton2502939.50 |
03-08-2023, 06:29 PM | #343 |
2940
Rep 2,538
ResIpsaLoquitur4148.00 |
03-08-2023, 06:55 PM | #344 |
28
Rep 39
Drives: 2002 CB M5, 2020 DG M5
Here's my setup with a 2020 Base, no modifications and no rubbing even at full lock entering the garage.
Dinan DC3 matte black 20x10 et +26 22.5 lbs 20x11 et +31 23.6 lbs Michelin PS All Season 4’s 295/35/20 305/35/20
2020 F90 M5 & 2002 E39 M5
2020 F97 X3MC 2018 G01 X3 M40I 1990, 1995, 2003 M3's |
Patton2502939.50 TheCookieMonster294.00 |
03-08-2023, 08:23 PM | #345 |
IG: @M5RCY_
365
Rep 318
To avoid stretched look, stick with 21x10 F and 21x11 R.
My set up looks stretched due to the wide rim in the rear 11.5" over 11". My previous set up was 21x11 and I had NO stretch on 295/30/21. And no problem, I am glad my input is able to help
Patton2502939.50 |
03-08-2023, 08:28 PM | #346 |
4148
Rep 3,701
Drives: 2022 M5C
You can have a better daily tire (PS4S) and avoid the stretched look.
Have your cake, and eat it, too. Life is too short.
Patton2502939.50 |
03-09-2023, 05:53 AM | #347 | |
2940
Rep 2,538
Here we go- Stock front wheels (if you order 20” wheels) are 20X9.5 et28 correct? So if I go with a 20X10 that immediately adds roughly 12mm or 1/2 inch to the overall width of the wheel and roughly the equivalent of using a 6mm spacer on the stock wheels as far as pushing the wheel out towards the fender correct? So if I go with a 20X10 et 14 that would be equivalent to using a 20mm spacer on stock wheels? Is my math correct here? I don’t really understand how manufacturers make wheels, so maybe when you get to a wider wheel offset the math changes? |
03-09-2023, 11:00 AM | #348 | |
4148
Rep 3,701
Drives: 2022 M5C
Patton2502939.50 |
03-09-2023, 02:05 PM | #350 | |
1571
Rep 29,202
Patton2502939.50 |
03-09-2023, 02:36 PM | #352 | |
1571
Rep 29,202
Your fitment in question is like putting 20mm spacers front, and 11mm rear. Many go with 15f/12r and they’re often lowered. Lowering will tuck the wheel in, especially in the front, so if you’re not lowered, et14 will look quite aggressive.
