BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    2021 Mod's... tune, air filters, etc.
      09-14-2021, 12:45 PM   #67
AngryInch
213
Drives: 2021 BMW M5 Comp
Originally Posted by eric97hoh View Post
what drop in filters do you have you deleted the charcoal filters too right?
BMC filters I believe and yes, charcoals are removed.
      09-14-2021, 01:34 PM   #68
eric97hoh
Drives: 2020 bmw m5
ya same love them good upgrade
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel
      09-14-2021, 05:41 PM   #69
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Map 1, Catless DPs, E30 mix, drop in filters. Spinning through first gear.
Now we're talking. Way to go buddy!! What was your 60-130?
2018 M5 Singapore Grey CCBs/Utku Noa E45 ECU/xHP TCU/PG-Intake/PG-Lower Downpipes
      09-14-2021, 06:08 PM   #70
AngryInch
213
7.31 don’t think that is too great?
      09-14-2021, 06:17 PM   #71
brad65ford
257
Drives: 2022 M3
Wait till you have low temp's with neg da, sadly this is how a lot of people do best times.
BTW have you run with and with the jb4 stage 1 to see what the difference is? I forget what my stage 1 bm3 93 tune gave me but its similar to your performance.
My dp's and plugs go on Friday, will be able to post some stage 2 93 BM3 times afterwards, hopefully i see at least another mph or so in the 1/4.
      09-14-2021, 06:19 PM   #72
99540
20
Drives: 21M5comp;20x4mcomp;95m3;03cob
Hi where did you guys get the BMS drop in filters? I checked burger site but didn't see it for 2021 m5..
thanks
      09-14-2021, 06:27 PM   #73
brad65ford
257
Drives: 2022 M3
btw just for shits... give a look at what it takes weather conditions wise to run good numbers. Any time you get the ability to run neg da's your going to run damn good numbers. Personally I wouldn't sweet it bro, your car like mine doesn't like high da/temps which not many do. Be happy your running as well as you are in these conditions.
for reference these are good numbers but he is running in 36 degrees and -1600 da, stage 2 E30! You will not run similar times unless you have weather conditions that will allow your timing/boost to increase like this weather does. https://f90.bimmerpost.com/forums/sh...16&postcount=1
Personally I think you are spot on for what mods and weather you have.
      09-14-2021, 06:37 PM   #74
AngryInch
213
I’m at 2400ft elevation. It was 7c this morning and the da was 1900ft. Some of the best DA we will ever see here. Typically da is around 2500-3500ft.
I still have light weight titan wheel coming this week, nee michelin tires, ms103 race gas and turn it up a bit more… hoping for a low 10 if I can get the DA!
      09-14-2021, 06:38 PM   #75
AngryInch
213
thanks
I ordered mine from my local performance buddies shop…
Check BmC website. I think it’s bmc not bms.
      09-14-2021, 06:39 PM   #76
brad65ford
257
Drives: 2022 M3
You see better times with the wheels for sure like I did. BTW for reference, my rs3 would run 4-5 mph faster between 80 degrees w/ 2000 da and 50 degrees w/ -300 da. Its just how it goes, I get pissed when I see people having awesome air. Only consolation is if your running someone in the same air it doesn't matter since you both have shit weather. .... Unless its a tesla and weather doesn't matter lol.
      09-14-2021, 06:40 PM   #77
brad65ford
257
Drives: 2022 M3
BTW what tires/sizes did you go with on the Titan's?
      09-14-2021, 08:39 PM   #78
AngryInch
213
I went with the factory size as to not mess with the xdrive. Also wanted to keep the weight down and not have a heavier tire. These Michelin’s feel pretty light, I’ll weight them mounted vs the factory wheels and tires before they go on.
I went with Michelin sport cup 2. They are softer than Pzero, 240 treadwear I believe.
      09-14-2021, 08:43 PM   #79
brad65ford
257
Drives: 2022 M3
If it’s 275 and 285 I just had the same and had the company that sold me them send 295 since they looked stretched, barely any tire lip. Went with ps4s’s. I didn’t like the look. Tomorrow I’m picking them up , it will be 285 on the front and 295 on the back. Remember the rims are wider than stock and it shows.
      09-14-2021, 09:42 PM   #80
AngryInch
213
Ahh shit! I had to order these from across the country took 10days to get in, so they won't work? Thought the titan rims are the same size?
      09-14-2021, 09:43 PM   #81
AngryInch
213
Couple pics of the intake vs stock and installed.
Appreciate 2
Jamesmick131.00
Holset275.50
      09-15-2021, 05:52 AM   #82
brad65ford
257
Drives: 2022 M3
Its not that they wont fit it just going to look stretched. I was upset as soon as I saw them once delivered. Even though I did my research prior purchasing from a well known vendor as well as shared multiple posts / threads and pic's with them, they still suggested 275/285 combo. Regardless, yes the Titans are larger wider front and rear rim width, its very noticeable imho.
      09-15-2021, 06:10 AM   #83
99540
20
thanks
Thanks
      09-15-2021, 09:00 AM   #84
AngryInch
213
Can you send me a pic of them with the stock tire size if you have and if you have a current pic? Would love to see. What model tires??
      09-15-2021, 09:03 AM   #85
brad65ford
257
Drives: 2022 M3
still waiting to pick the swapped over 285/295 up today, assuming they are better. attached photos for your reference.
      09-15-2021, 09:24 AM   #86
AngryInch
213
Is that stock size or the larger size?
      09-15-2021, 09:25 AM   #87
brad65ford
257
Drives: 2022 M3
stock tires size on Titan's.
      09-15-2021, 09:25 AM   #88
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
def stretched a bit, some like that look tho lol. Im going lightweight wheels next, these are an option.
