09-11-2021, 09:09 PM | #45 | |
213
Rep 548
09-11-2021, 10:01 PM | #46 |
5258
Rep 10,632
That is why you use a tune with safeguards in case the meth stops.
DrivenAgain120.00 |
09-12-2021, 08:44 AM | #47 | |
MFJWADE
120
Rep 351
JB4/Project Gamma Intake E40 No other mods This is just a screen shot. I suggest you download Datazap.me and I can send you the full .csv and you can scroll thru run to see various data points. DA216
2018 M5 Singapore Grey CCBs/Utku Noa E45 ECU/xHP TCU/PG-Intake/PG-Lower Downpipes
09-12-2021, 09:38 AM | #48 |
213
Rep 548
Your timing is huge!! I’d be lucky to hit 15degrees for a tiny bit. I’m usually around 8-10 degrees.
Your boost is nice and smooth too. When my car shifts, the boost spikes, it’s sample before the throttle, curious why yours doesn’t spike, it drops and climbs again. Also, your fuel trim is rock solid at 44, no adjustment… what’s with that? Last edited by AngryInch; 09-12-2021 at 09:45 AM.. |
09-12-2021, 10:53 AM | #49 | |
MFJWADE
120
Rep 351
This a custom written Map 6 and it addresses the overall power delivery including ramped in boost, each gear has its own boost profile. Good catch on the fuel trims. This is an indication that I'm maxed out on injector at this DA. I have to dial back to about E35 or add meth, which is coming next. |
09-12-2021, 11:31 AM | #51 |
MFJWADE
120
Rep 351
My IAT started at 65f. The ECU can only advance timing to stay within a safe range, your 94 octane is limiting that advance, although 15deg at top of 5th is great! You're also still on Map2 which is a conservative 93oct file. Youre on par for a pump gas car.
09-12-2021, 12:14 PM | #52 |
213
Rep 548
I think I figured out/understand now how guys are running e30+. I keep thinking in terms of AFR and stoichmetric, however, the ecu uses lambda. So the ecu is targeting lambda values regardless of the fuel. Lambda 1 is 14.7:1 with pump gas, which is a complete burn. If e30 is used, ecu will add fuel to reach lambda 1, which is a complete burn of that fuel and a different stoichmetric value, likely closure to 13:1…
I think what was screwing me up is the JB4 reads out in AFR, which is actually a conversion of ecu lamdba readings. Lamdba 1 of e30 is not 14.7:1. Is 44 the max fuel trims on our cars? What I don’t get is how a CEL isn’t popped for maxing out fuel trims… usually 25% increase will pop a code for too rich on most ecus. I’m going to get some e85 and mix it up to e30, let it adapt and run some logs to see the timing and trims. |
09-12-2021, 09:12 PM | #53 |
213
Rep 548
Well I’m not having much luck here. My fastest time was JB4 with pump gas and stock exhaust.
Now with DPs, and mixing e98r with 94 pump to make e30, I’m even slower, I lost a couple mph in 1/8 and 1/4… damn. Timing doesn’t look much better. Wish there was actual tunes for the 21s.. It feels like it’s pulling in 4th and 5th but has a bit of a hesitation… not perfectly smooth. Think I might just run it with pump 94 and leave it alone till someone cracks the ecu. |
09-13-2021, 05:44 AM | #55 | |
257
Rep 764
09-13-2021, 05:57 AM | #56 | |
MFJWADE
120
Rep 351
09-13-2021, 09:27 AM | #57 | |
213
Rep 548
I’ve notice my boost is a bit higher since dps. However, when the boost is higher, the timing drops more as well. |
09-14-2021, 09:28 AM | #58 |
213
Rep 548
So I will keep this going as my log of how things are going for my mods. If anyone else has similar issues please chime in.
I’ve been reading over past logs and noticed before downpipes boost was around 18-20 psi ecu.. Now after downpipes, the ecu is calling for 20-22psi, I’m seeing a rise in ecu calling of around 2psi… Anyone know why the ecu would be calling for more psi? I’m running JB4 map 2 so it’s adding 4.4psi, I’m hitting 25-26psi which is quite high and likely why my timing is not the best. |
09-14-2021, 10:51 AM | #59 |
213
Rep 548
Air is good this morning. So I did some testing… I turned down the JB4 to map 1 since the boost was way too high on map 2, causing my timing to take a beating.
Way way better. Gained 2mph in 1/4 and did a 10.48 spinning all 4 tires through 1st gear. Not sure why the factory tune and ecu started calling for more boost, but it has been up 2 psi since downpipes. So JB4 users really need to keep an eye on their ecu boost and select the proper map. For me with comp package, downpipes. Map 1 works better snd keeps my throttle boost at around 23-24, which lets the timing come up to where it should be. I’ll need 100octane race gas to run map 2… which I have and will try later on. Next mod, Dinan inlets. Arrived today, will install shortly and report back if any improvements with draggy. |
09-14-2021, 11:47 AM | #61 | |
87
Rep 315
2020 BMW m5 with some bmc filters, charcoal filter delete, and Dinan turbo inlets.
Previous BMW model 2018 bmw 340i FBO custom e50 tune 500 wheel |
09-14-2021, 11:52 AM | #63 |
87
Rep 315
heard they make a bit better noise throttle response and some power we shall see tho
09-14-2021, 12:41 PM | #66 |
87
Rep 315
what drop in filters do you have you deleted the charcoal filters too right?
