Any qualms on being the first to get a new 335i? Turbo reliable?
05-09-2006, 07:57 AM | #23 | |
181
Rep 883
BMW was the first European manufacturer to race a turbocharged production car on the touring car circuit, and has produced numerous turbocharged gasoline engines, most recently into the mid/late 80s. In fact, the M division was even planning to turbocharge the S14 (E30 M3 engine), but this was abandoned due to lack of development funding from the parent company. |
05-09-2006, 08:03 AM | #24 | |
181
Rep 883
05-09-2006, 08:20 AM | #25 |
Moderator
618
Rep 10,858
Control arm bushings were clearly the achilles heel of the E46, with a high % needing replacement before 100k miles. Brakes and clutches were more contingent upon owner driving style. Most clutches make it past 100k. Most brakes past 50k. AC odor preventable if you shut AC off before stopping for the night, allowing it to dry out.
Overall a simple E46 without a lot of electronic gadgets is a very reliable, long-lasting vehicle, regardless of build year. The E90 has had more issues with software and the runflats. |
05-09-2006, 09:55 AM | #26 |
Rep 71
With any 1st year car, no matter who the manufacturer is, there will be more issues than with later models. Part of the price you pay buying a 1st year car is the greater risk of a systemic problem. There just isn't a way for a manufacturer to discover all the possible problems through their own testing without the benefit of the "beta testing" done by consumers in a wide range of environments after the car is released. This is true in any industry, from software to pharmaceuticals.
That being said, I doubt you will see serious mechanical problems with the turbos. The 3 series, non-M engines are the life-blood of BMW, sort of "ground zero" for the entire company. If those fail, the shockwaves will ripple widely. Therefore, you can bet BMW has the turbos well under control. While you may see some minor issues (things like cold-engine rattles for example) that are later fixed with TSBs, I'd be shocked if you had any kind of a failure rate for the engines themselves. You will probably see other areas that have gremlins as well, particularly on any parts not shared with the E90, but they will likely be minor ones. It won't stop me from ordering one this fall. |
05-09-2006, 12:40 PM | #27 | |
Grumpy
12
Rep 168
Ed
Agh. Construction everywhere. Good for the economy, I guess.
05-09-2006, 12:43 PM | #28 | ||
Grumpy
12
Rep 168
Guess how I know? :mad: Quote:
Ed
05-09-2006, 12:49 PM | #29 |
Moderator
618
Rep 10,858
I would be interested in the differences btw euro and NA maintenance issues. E.g., did euro early E46s have subframe mount problems? Ditto for control arm bushings? Or were these more a local NA phenomenon?
05-09-2006, 03:28 PM | #30 | |
Grumpy
12
Rep 168
Ed
05-09-2006, 04:17 PM | #31 | |
Rep 71
I think the design will be good but if there will problems it will be the quality of the parts they use and how they fit together. I don't get great feelings of the quality of the parts modern German cars use. Yah yah I don't have solid evidence although there have been some reliability surveys in which many German car manufacturers didn't come out high. |
05-09-2006, 05:14 PM | #32 |
890
Rep 7,047
The 3 series is the bread and butter for BMW.
The 3.0 NA engine will be the majority of the next E90, not the turbo. The "lower power" 3 sells at least 2:1. 328 will be the bread and butter engine. But, I agree if the turbo's become problematic it will resonate throughout the line for a bit. The M3 issue was fixed, some with work some with extending the warranty. But, the M3 is a low volume model. I'm wondering how long the oil drain interval will be in the turbo engine with BMW picking up the tab? In NA engines I'm all for long drain and synthetic. In turbo's I cut 30% out of the mileage and go sooner. So, if it's 15k before, then I would go with 10k in the turbo. It'll be interesting to see the BMW oil change. |
05-09-2006, 08:54 PM | #33 | |
233
Rep 384
There are plenty of historical examples out there of what can go wrong with poorly designed turbocharged engines. Audi has a lot of recent ones. Oil gelling and huge coil pack issues on their 1.8T engines, and the 2.7TT V6 engines had poor thermal management which results in a lot of turbo failures. Even Toyota 2JZ-GTE engines from the Supra TT were known for secondary turbo failure on their sequential setup. The more complex you make an engine, the more difficult it is to bulletproof it. It's not easy by any means.
2022 G05 X5 40i Phytonic Blue / Ivory | 2011 E93 335i Deep Sea Blue / Oyster | 2012 E70 X5d Deep Sea Blue / Sand Beige (ret)
2018 Chevy Suburban Premier 4x4, Pepperdust / Cocoa, Adaptive Cruise, HUD, 3.42 gears (the full circus long-hauler) |
05-10-2006, 12:55 AM | #34 |
60
Rep 804
how reliable do you think the turbo will be?
so im looking forward for the 335i to come out but how reliable do you think it will be? i know we should probably be trusting bmw with the turbo since they probably tested it out for quite a while but what does everyone else think about the turbo?
05-10-2006, 01:21 AM | #35 |
BMW, can I have some LSD please?
88
Rep 1,591
Should be reliable, but first year may require some debugging.
Turbos have been around a while in European cars in Audi/VW, Volvo, Saab, etc. Not much problems, other than some recalls for placing heat shields to protect some oil lines in Audi's 1.8T. Having said that, however, I don't trust pre-owned cars with turbos because I don't know how the previous owner has taken care of the turbo. Especially with turbos requiring some cool down time before shut down, I shudder at the thought of someone driving spiritedly home in the last 10 minutes only to shut down in the garage immediately after, with the turbo still red hot.
2006 330i | TiAg | Black | Al | 6MT | Sports Package | Logic 7 retired
2008 335i | AW | Black | Al | 6MT | Sports Package | Logic 7 retired 2013 328xi | Red | Gray | Al | 8AT | Sports Line | Premium | Executive | Heat Pkg retired 2017 340i xDrive | Estoril | Black | Al | 8AT | M Package |
05-10-2006, 05:31 AM | #38 |
363
Rep 5,984
BMW have been selling turbo cars for years already.
What do you think the diesels have bolted onto them, and they last for years and hundreeds of thousands of miles. What they will be like when they are tuned and the boost is increased is another matter, but can't wait to find out!! |
05-10-2006, 05:35 AM | #39 |
S0THPAW
8723
Rep 7,847
I had a turbo Impreza and a 1.8 turbo Audi S3 with 270BHP tuned. The Audi engine was blown to pieces.
I think Japanese car manufacturers know more about turbos than german manufacturers. Turbos do worry me a BIG bit because of what happened with my Audi. I think turbo engines are not made for trackday and severe use, only EVOs and Stis. IMHO. |
05-10-2006, 05:37 AM | #40 | |
S0THPAW
8723
Rep 7,847
So you have a DMS 535d? 320BHP? Read some tests. Great drive. I love turbodiesels in general. I used to own a E46 330d too. |
05-10-2006, 05:45 AM | #41 | |
20
Rep 294
I think it is no wonder that your Audi's engine blew up after you have chipped(?) 100 hp more than the standard engine has. Depends of course what other modifications were done to the engine. |
05-10-2006, 06:01 AM | #42 | |
S0THPAW
8723
Rep 7,847
I dated 2 Danish girls in my life.No Swedish ones The first Danish girl I met in Spain lots of years ago. She was a cutie. |
05-10-2006, 06:09 AM | #43 |
106
Rep 310
Let get this right - you tune a 180 - 220BHP designed 1.8 ltr 4 pot to produce 270 and wonder why it blows up ?????
If Audi had done this they would have put a tougher crank in, better bearings etc etc... stronger gearbox to handle the power. If you do as an after market change then you can only expect trouble at some stage. I have had two turbo's in the past and these days there are no reliability issues as long as you stay with the standard spec. Sure you can always abuse a car but you can do the same with a non turbo and the chances are you will thrash the non turbo a lot more trying to keep up with a moderately well driven turbo of equivalent capacity. |
05-10-2006, 06:14 AM | #44 | |
20
Rep 294
I'd like to have one Danish girl as well |
