11-09-2021, 09:54 AM | #23 |
41
Rep 131
I have also ordered the deleter and still waiting for it to arrive. Can you post some photo to show how is the CAN MIL thing is installed and where does the wire connect to? Thanks!
11-09-2021, 10:35 AM | #24 |
445
Rep 750
11-29-2021, 08:54 AM | #25 |
14
Rep 42
Hi!
Finally I've deleted OPF with akra goodies. However there are some problems with it. First of all LCI exhaust is like in CS, so it means shorter dowpipes and longer link pipe. We had to make extra connector around 20 cm between akra linkpipe and oem downpipes. So it took more time. LEIB is working? Good question - after 10 days with it I had first limp mode today morning, it was after heavy pull on motorway form 120 km/h to 220 km/h. It disappeared after quick reset - switching and off and starting on again engine. I'll try to make some video this week and post it asap! Finally my advice - DO IT!! Exhaust sound is nice and deep, after switching off sport exhaust and in efficiency mode it doesn't bother at all. |
12-03-2021, 03:17 PM | #26 | |
Rep 25
Drives: BMW M5 Competition
12-03-2021, 05:24 PM | #28 |
14
Rep 42
Pops and bangs are still working on it, slightly louder.
Downsides - just one, limp mode after heavy pulls, precisely when you go above 6k rpm on full throttle. You need to make soft "adjustment" to remove it. I will make stage 2 on it - 750hp. |
Slugsy01157.00 |
07-21-2022, 12:52 PM | #30 |
276
Rep 653
07-21-2022, 01:49 PM | #31 | |
14
Rep 42
Do a proper tune If you want to know my advice. |
F30Andy1778.50 |
07-21-2022, 02:44 PM | #32 | ||
276
Rep 653
07-21-2022, 11:41 PM | #34 |
276
Rep 653
07-24-2022, 01:29 PM | #35 |
Rep 25
I have full catback Akrapovic Evolution Line along with the 2 leib boxes - opf delete module and can mil deleter.
First two weeks I had occasional check engines lights, but after that I haven't seen it. I can say they work fine and there is no problem after heavy pulls. There is just only one problem related to the warranty - when you read the car, there is trouble code saying implausible opf data readings. These errors are only visible when the car is not running, since the can mil deleter will deactivate it when you start up the engine. The sound of the Akra is unique - loud and deep, there are no pops and bangs, but on low rpm when you lift the gas you have some mild burbles and also sometimes on upshifting you can get big bang sound 😊 |
Holset275.50 |
01-04-2023, 07:10 PM | #36 |
Rep 8
I also have 2 leib boxes - opf delete module and can mil DELETER I have had check code up few times when flat out and I mean like top end but apart from that it spund and feels absolutely tremendous. Would most definitely recommend it. I will stick up a you tube link.
https://youtu.be/Vy_UA5_Otz4 Few vids on my profile smoking modded lambos and Jap things at York race tack 😉 |
F30Andy1778.50 |
08-27-2023, 09:07 AM | #37 | |
Rep 23
a two pins, and a yellow one is free, it's frustrating. My question is how did you install it? Was it easy or complicated? Help please. Thank you Sorry to see if you can help me,I'll explain my doubt,I am going to install downpipe without cat and I intend to connect the LEIB CAN THOUSAND DELETER.I have read the instructions and I don't see it clear,there are several cables but only one red wire and says q is connected a two pins,and a yellow left free,is fusrante.My question is as intalaste?, if it was easy or difficult?Please help.Thanks |
08-27-2023, 09:16 AM | #38 |
Rep 23
Maybe a kind person can help me.
Someone who has assembled LEIB CAN MIL DELETE, can you tell me if it was complicated, do the pins fit well? Do the cables match the colors mentioned in the instructions? Thank you very much. |
08-28-2023, 03:27 PM | #39 |
Rep 25
08-28-2023, 04:50 PM | #40 |
Rep 23
Thank you. But my question is, if you installed the LEIB CAN MIL DELETER, the 6 cables are coupled to two connectors of the BCD CONTROL MODULE box.? The assembly instructions are exact, the steps to follow are well explained, and the
wire colors? Thanks and apologies. Thank you.But my doubt is, if you installed the LEIB CAN THOUSAND DELETER,6 cables ,are coupled to the two connectors of the box BCD CONTROL MODULE.? The assembly instructions, they are accurate,are well-explained the steps to follow,and match the wire colours?.Thanks and apologies. Thank you.But my doubt is, if you installed the LEIB CAN THOUSAND DELETER,6 cables ,are coupled to the two connectors of the box BCD CONTROL MODULE.? The assembly instructions, they are accurate,are well-explained the steps to follow,and match the wire colours?.Thanks and apologies. |
04-09-2024, 02:20 AM | #41 |
Rep 5
I wanted to do the same thing, installing the LEIB CAN MIL DELETER, after finding out what a headache that might be I contacted Bimmerworks.ro
He basically did it over the laptop, saying that this can mil deleter is a double edged sword sometimes it works, sometimes it doesn't. He did it via software, car has no problems and now sounds as it should. |
