08-01-2023, 04:16 AM | #1 |
80
Rep 84
2021 F90 M5 Comp pulling left / rotating anticlockwise under acceleration only
Hey guys. I've fiddled quite a lot with my 2021 Comp. M Performance suspension with an 8mm drop. Front upper camber arms (from BMW direct). Dinan ball joints. JB4 so about 700 or so bhp.
The suspension work was done by a very reputable shop that is basically the go-to place for alignment, and they spent several days aligning it. The car tracks totally straight, all the way to the speed limited, and braking is totally straight too, even on track where I'm maxing the brakes. On track where I feed in the acceleration carefully out of each corner, the car is fine. However if I'm cruising on a fast road or motorway, and then suddenly accelerate hard, the whole car intensely rotates anticlockwise, I have to correct by turning the steering wheel to the right to stay in lane, but that doesn't help because the car keeps rotating and ends up losing traction. If DSC is on it'll sense the rotation and cut the power. If I'm in 2wd then the entire car will end up in a high-speed skid, even at very high speeds. A bit of an obvious question, but I'm guessing everyone else's M5s can just be floored at any point, and they'll boost and go in a straight line, right? I've tried two sets of tyres, so I don't think it's that, and the alignment is rock solid in all other situations, and has just been done by the best shop in the UK, so I don't think it's that. Any ideas for what it might be? |
08-01-2023, 09:14 AM | #2 | |
1540
Rep 2,010
08-01-2023, 10:19 AM | #4 |
5258
Rep 10,632
The OP says the alignment is good because a reputable shop did it. It is possible something is broken that does not show up during an alignment—it takes serious load like the windup from full acceleration to expose the problem. I’d put the car in the air and look and do some testing with a prybar.
If the front to rear tire size difference is not the same ad stock, the transfer case could be a factor. But then I am not sure why there is a problem in 2WD with TC fully off. |
F30Andy1778.50 |
08-02-2023, 01:32 AM | #5 |
80
Rep 84
Yeah the alignment shop is the best of the best, recommended by literally everyone over here. Spent 20 mins on the phone with them today talking it through.
Definitely possible that something has knocked the alignment out. But we talked about how if one of the rear toes was out, it wouldn't be just during the acceleration that it would show up, you'd have a sense of it in general while driving. They said that in 95% of cases it ends up being the tyres, but there's 5% chance that something at the back is amiss, maybe a damper that behaves differently during the squat. One thing they suggested trying is to swap the rear wheels around to see if it changes the dynamic. Would definitely confirm that it's not the tyres, and that there's nothing wrong with the actual wheels. Seems an easy test so going to give that a go. |
08-02-2023, 05:21 AM | #6 | |
2511
Rep 4,381
The rear suspension typically has some static toe-in if OEM. Under acceleration the rear wheels tend to toe-out, reducing the amount of static toe-in...but maintaining enough that the car tracks in a straight line. If the rear wheels have a different static toe-in side to side you can get rear wheel steer...especially under acceleration. If the rear static toe-in is correct but the rear wheels toe-out a different amount under acceleration then that can also cause rear wheel steer. If that makes sense. Wheel swap seems a good idea to start with. |
08-03-2023, 04:10 AM | #8 | |
80
Rep 84
08-05-2023, 09:14 PM | #9 | |
343
Rep 233
Drives: F90 M5 LCI - Aventurine Red
That sounds crazy and dodgy. Sounds almost like the rear subframe is loose and when large torque is applied rapidly or removed, the whole rear axle setup is doing a twist. Carefully have all the rear subframe mounting points checked and also the rear diff mount points, while you're there. PS: I presume you're referring to Centre of Gravity? They are on another level. I hear good things about Suspension Secrets too.
F90 M5 LCI - Aventurine Red/Smoked White-E39 M5 - Modified ESS Supercharger Kit -E34 M5 1995 - Arctic Silver / Black Leather-
E30 M3 1987 - Diamond Black Metallic / Black Leather-996 Turbo - Lapis Blue/Savannah-VW Rallye Golf |
08-05-2023, 09:17 PM | #10 |
343
Rep 233
Yes because top establishments don't mess around. If they deem you require new suspension arms or bushes, for example, they'd have to order them in.
08-06-2023, 02:37 AM | #11 |
80
Rep 84
Yep exactly, Centre Gravity. Suspension Secrets are great too, but newer. They did some stuff for me at a track day once and were very good too. But Centre Gravity are so good they have a 3 month waitlist to book in. And yeah, that's exactly how it feels, something at the rear subframe moves under intense torque, but is totally fine otherwise.
01-31-2024, 05:37 PM | #12 | |
343
Rep 233
