08-26-2022, 11:31 AM | #1 |
31
Rep 137
Handling before and after spacers
What's up everyone.
Just installed 15f/12r spacers on my 2021 comp. (not lowered). I noticed that the car slides out more ripping around turns. Before the spacers this thing was on rails. I would think with spacers it's a wider stance so handling should be better. Anyone else experience less traction around turns with spacers on ? Thanks
~Mamba Mentality~ 8/24
08-26-2022, 12:40 PM | #2 |
317
Rep 516
Adding spacers still changes the overall suspension geometry from factory, not limited to just a wider stance.
Many things can change when changing one variable. |
08-26-2022, 12:52 PM | #3 |
551
Rep 638
as he said^ it changes things.. How much, negligible to be felt on the street.
I just put spacers on two weeks ago, car feels the same. Did around 145 in Mexico car felt the same as prior. |
08-26-2022, 12:55 PM | #4 |
317
Rep 516
I suspect you weren’t cornering at the threshold doing 145 though. Lol
Current: 2021 Oxford Green over Caramel M5C
2022 Ford Mustang Mach 1 : 2021 Yukon Denali : 2011 Ti Silver 128i 6MT, Koral Gone: 2021 Carbon Black X7 M50i : 2018 SG M5 2016 Med Blue 650ix GC : 2008 BSM 535i 6MT 1999 Jet Black 528i |
08-28-2022, 02:53 PM | #7 |
5234
Rep 10,614
I noticed no changes from installing spacers. If you did the typical 11 or 12 mm front and 15mm rear, you are adding around 1” of track and that should not make a difference the average person can feel on the street. Maybe an experienced track driver could feel it or maybe lap times would show a change.
08-29-2022, 03:51 AM | #8 | |
876
Rep 1,319
08-29-2022, 10:30 AM | #9 | ||
31
Rep 137
I will look into that. Thank you
08-29-2022, 10:34 AM | #10 | ||||
31
Rep 137
Thanks for the input.
08-29-2022, 11:05 AM | #11 |
1716
Rep 1,909
Drives: 2023 M5C
To those feeling vibrations -- did you use longer wheel bolts to account for the spacers? Did you use a grease/paste to mate the *clean* surface of the hub and spacer?
IG @windtendo_m5
08-29-2022, 11:13 AM | #12 | ||
31
Rep 137
I had 12f/10r on my 2018 m5 and didn't have any issues. You think it's the size of the spacers ? Do I have to get an alignment done ?
