08-28-2022, 04:38 PM | #23 |
1830
Rep 1,315
Orrrr......
It MIGHT NOT MATTER what "mode" you hold down the "BC" button. Just hold it down after "Diagnostic mode" comes up. Shawn |
PDOT119.50 Chubbiejones890.00 |
09-13-2022, 10:33 AM | #24 |
120
Rep 385
Drives: 2021 M5C
Has anyone run the Carbotech XP-12? I was speaking with the rep and he stated the XP-20 may be a bit to much for the PS4S and Cup 2 Connect
09-13-2022, 11:54 AM | #25 | |
1830
Rep 1,315
And on track, bullshit. The F-90 is a giant beast that needs a heavy duty pad. Just like my GT-R. Given the XP-20's would be better mated to Hoosiers or Toyo R888's on track, but if you're going to a brake heavy track, nothing wrong with XP-20's on a slightly less sticky tire. Only downside is getting into the ABS will happen easier. Shawn |
PDOT119.50 |
10-16-2022, 08:36 AM | #26 |
31
Rep 137
ISweep IS1500 all day.
I put them on about a month ago. Zero squealing, no brake dust, and I would say 20% better braking performance imo. Hit up Ben at RG Sport. He helped me out a great deal.
~Mamba Mentality~ 8/24
josec704062.00 |
10-16-2022, 01:31 PM | #27 | |
1830
Rep 1,315
But 20% better braking? I'd bet you a full set of all the way around brake pads no way. It just doesn't work that way. The best brake pads for stops sound like absolute shit and dust terribly - they always have. But if you think somebody can validate/invalidate this objectively, my wager stands. Shawn |
916_M5363.50 |
10-18-2022, 10:25 PM | #28 | |
100
Rep 185
ps loved the VIR vid you posted had me longing for my track days again!! Enjoy |
shawnhayes1829.50 |
10-19-2022, 12:09 AM | #29 | |
1830
Rep 1,315
Thank goodness. $16,000 brake job seems....excessive. Shawn |
10-19-2022, 06:22 PM | #30 |
222
Rep 319
Swapped out the Textar pads on my F82 M4 to the EDC yellows and much preferred them. The DOT brake codes were better than OEM at GG vs GF. I can't comment on the feel of them on the F90 because I have CCB.
10-20-2022, 06:33 PM | #31 |
30
Rep 67
So lets say I want more fade resistance over the stock M Perf pads on Steel rotors (2018). Since going stage 3 Carbahn, I can't get up my favourite mountain run without a bit of toasty brakes - then when i go down, it gets a bit soft....
Brakes make noise and dust - whatever, I just want to stop this heavy bish. Where do we rank things? RSL29 / M Perf Enduro MX72 Stock M Perf pads I know shawnhayes is a fan of RacingBrake ST600's - but not sure where to rank them here. Re: Fluid wise - I know the gold standard is Castrol SRF - but given the change intervals required, probably looking to go Motul RBF660 as a good interrim. |
10-20-2022, 09:12 PM | #33 | |
1830
Rep 1,315
Did you switch out to EBC yellows on an F82 with CCB's? Have you checked with EBC to make sure they're carbon ceramic compatible? Some pads will FIT on CCB's and brake, but according to the manufacturers some pads are not suitable for carbon ceramics. I can't work that out in my head, unless they get too hot on the surface, or have a matrix material that can damage the carbon, but they DO say it. I would at least email EBC to make sure they approve of using that pad on ceramics. Shawn |
10-20-2022, 09:28 PM | #34 | |
1830
Rep 1,315
Pagid makes the Stock pads (check them, many of them have the pagid logo and trademark printed right on them). On the fluid, you might elaborate to help other folks understand why you'd go for the Motul over the Castrol SRF. There ARE some reasons, but I'd like to hear yours. Shawn |
10-20-2022, 09:34 PM | #35 | |
1830
Rep 1,315
But, what I CAN say is that Castrol recommends SRF be changed (completely) every 18 months. That's not a problem for me, because I need to do a small flush almost every event (and I do it myself). If any water gets into the system, SRF WILL NOT ABSORB IT, and needs to be "bled" out. Regular fluids will absorb the water (right out of the air, honestly), which degrades its vapor resistance. SRF is a different animal. And, a godsend for us track hounds. I'm not sure I'd put it in my streetcar unless I intended to change it like that. Shawn |
10-21-2022, 12:49 AM | #36 | |||
30
Rep 67
shawnhayes did you end up swapping the lines? or adding additional ducting? I found the brakes cooled down pretty quickly - but yeah, definitely lost confidence in the stock arrangement faster than i'd like. |
10-21-2022, 10:25 PM | #37 | |
222
Rep 319
shawnhayes1829.50 |
10-22-2022, 06:37 AM | #38 | |
5212
Rep 10,594
Yes, it is recommended to be flushed at a shorter interval than stock fluid. I agree it is not the best choice for someone who does not know what they are doing and does not maintain their car properly for the mods they have. I also agree it is not necessary for someone who is not coming anywhere close to boiling stock fluid, which is probably 95% of M5 owners. https://www.opmustang.com/store/p113...e_Fluid.html#/ |
10-22-2022, 12:40 PM | #39 | ||
1830
Rep 1,315
Shawn |
10-22-2022, 02:31 PM | #40 |
276
Rep 151
+1 on the isweeps, had them installed a week ago, so far so good. not as much bite as before, but very close. so far no more squeaks.
r33_RGSport12912.50 |
10-22-2022, 10:21 PM | #41 |
222
Rep 319
Shawn,
EBC we're not up to the task years ago. The new formulation are nice. If I had irons on the 5, I would have swapped the pads the those. I liked the yellows and the M4 forum like the blues more than the yellows. |
10-23-2022, 08:50 PM | #42 |
120
Rep 385
Drives: 2021 M5C
EBC Blue on track doesn't hold up. I can tell you from experience
10-24-2022, 12:05 AM | #43 | |
1830
Rep 1,315
"The properties of this formulation are such that in order to derive maximum benefit the use of Castrol React SRF Racing should be restricted to not more than eighteen months before draining and refilling" https://msdspds.castrol.com/bpglis/FusionPDS.nsf/Files/4FFC9E28DDFAE514802585BA00487114/$File/WEPP-BS7LMU.pdf That's why I wouldn't put it in my street car, unless I was going to bleed it that often. I do my track car, but my street car? (Volvo). Not so frequently to replace every 18 months. Shawn |
10-24-2022, 06:50 AM | #44 |
5212
Rep 10,594
Even at less than “maximum benefit,” it outperforms other fluids. It’s more a question of whether you need the benefits it offers in your street car and whether you would be willing to change it regularly — even on the normal BMW 2 year spec it would outperform stock fluid. However many M5 owners won’t bother changing brake fluid even at BMW’s 2 year interval.
