BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    Finally!! I swapped my F90 H&R Springs for M550i's!! Pics
      11-19-2019, 05:58 PM   #67
Hockeytyme
Hockeytyme's Avatar
575
Drives: 2020 M5C
Originally Posted by Vic55 View Post
Weight is close but as you stated the rates could be higher on the M5 but then again these are aftermarket springs not OEM where we could check part numbers on the F90 vs the G30. The dampers really have alot of control here and Im actually down to Sport now vs. Sport Plus because the drop is more aggressive than stock or the F90 H&R's.
prodigymb
Id say its more bouncy on bad undulations for sure as the compression and rebound distances have been reduced and that hinders the damper. But the gain in form is great and in reality the OEM springs are bouncy too IMHO. On flat surfaces- the springs are great in Sport and the car feels fine.
I agree, the rebound is kinda bouncy so you have to be careful on faster roads with transitions to bridges and things that will bounce you up. On flat ground there is pretty nice and the compression is good overall.
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48
JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18
IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires
      11-19-2019, 07:06 PM   #68
Used2be
Perennial PFC
Used2be's Avatar
Drives: F90 M5 DG/Aragon
100% M550i springs.
I misunderstood then, I thought you meant stock M550i springs.
      11-19-2019, 07:25 PM   #69
Vic55
Vic55's Avatar
19361
Drives: 2023 BMW M8 Competition Coupe
No--- 100% H&R's which drop the car 1.3/1.2
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      11-20-2019, 01:08 PM   #70
prodigymb
208
Drives: V10+ R8, 997TT, Plaid, G550
Why would the ride be stiffer? Stock 550i springs for a car that probably weighs slightly less than the M5, and isn't a performance model from BMW, would more than likely have a lower spring rate.
couldnt tell if serious or trolling. these are not stock bmw springs. they are H&R that are meant for the 550
997TT 6MT - 205 mph 1/2 Mile , 170+ mph 1/4 Mile , 3.2 60-130 mph , 2.4 100-150 mph , 1500whp
      11-20-2019, 01:19 PM   #71
Used2be
Perennial PFC
Used2be's Avatar
Very definitely serious. I misunderstood Vic's description of the springs as "!00% M550i" to mean they were stock M550i springs. If he had said H&R for the M550i I wouldn't have been confused.
      11-20-2019, 04:42 PM   #72
Vic55
Vic55's Avatar
19361
Yeah I can see where you would have inferred as such. I guess because of so many others pushing me to get the H&R M550i's that I just figured most, if not all, would have known.
Anyways, Im glad we got it cleared it up. If you are on the fence, I would say "go for it!!!!"
r33_RGSport12967.50
      12-14-2019, 05:46 PM   #73
Ehloo
549
Drives: 15 x5 m
Posting this on the f90 forums cause the f92 m8 forums is extremely slow
So am I am looking to lower my m8. Car is too new for any released parts. HR has a M850i spring already and kw has a gas kit for the M850i also. I am concerned with too much drop with the HR. But as reading all these forums assuming the f90 chassis is that similar to the f92 I’m feeling I might take the risk. Or do you think the KW HAS would be a better option of height is an issue.
Sorry looking for advice. There is like 5 members on the 8 and m8 forum.
      12-14-2019, 10:43 PM   #74
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
I would say HAS would be better.
Because worst case scenario, you'll be able to adjust it to the way you like it.
But, not sure is the KW HAS for M850iX will fit due to the spring perch diameter.
I may have to do more research for you.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
      12-15-2019, 12:27 AM   #75
Ehloo
549
Drives: 15 x5 m
If the spring perch is different sizing that would mean the HR M850i springs wouldn’t fit also right
      12-15-2019, 12:52 AM   #76
r33_RGSport
Call me on Monday. I'll explain to you.
They are different.
      02-15-2020, 11:51 PM   #77
p.mf10
16
Drives: 2020 M5
Hey Vic,
have the same front lip as you and looking into lowering my car with M550i springs as well. Have you had any issues with the front lip scraping often ?
      02-17-2020, 09:23 AM   #78
Vic55
Vic55's Avatar
19361
Originally Posted by p.mf10 View Post
Hey Vic,
None at all but I do have pretty good roads where I live without a lot of weird angled drive ways when going places.
p.mf1015.50
      03-02-2020, 11:53 AM   #79
IncurveWheels
IncurveWheels's Avatar
Drives: M5 Competition
did you receive any warning messages? i'm receiving a "chassis warning, continued driving still possible" message.
      03-02-2020, 11:57 AM   #80
Hockeytyme
Hockeytyme's Avatar
575
Drives: 2020 M5C
Turn around and go back. They did something wrong and need to redo it. Probably have to pull the seat and redo one of the rear springs
      03-02-2020, 12:39 PM   #81
Vic55
Vic55's Avatar
19361
None here ever. As Hockeytyme stated, bad install.
r33_RGSport
      03-02-2020, 12:50 PM   #82
r33_RGSport
Installation problem there.
Here are the possibilities:
- Leveling sensor got damaged or unhooked
- EDC connector didn't properly plugged in
- G sensor got damaged or not plugged in
I may miss some, but those are what I remember currently.
      03-02-2020, 03:28 PM   #83
IncurveWheels
r33_RGSport
Appreciate the response - had it on the lift and all connectors looked ok but going to take the rear section apart and check again. Was riding fine and then all of a sudden came on. I had called H&R direct and they said they were unsure but could be due to the springs not being made for this specific car - so we shall see - hope it's something simple.
      03-02-2020, 10:04 PM   #84
euro*
euro*'s Avatar
1658
Drives: F90 M5
r33_RGSport
Did you have problems as soon as you installed the springs? I remember seeing something like the car drove very bad by your description. Maybe the malfunction is related to that also?
Also, scan the car, it will give you exact code and why it's on, which can better guide you to where something is wrong
      04-29-2020, 03:55 PM   #85
Vic55
Vic55's Avatar
19361
During these times a good drop remains positive:
Appreciate 2
r33_RGSport12967.50
saveywil1230.50
      04-29-2020, 04:13 PM   #86
JAY55
JAY55's Avatar
Drives: ///V10 ///F90 ///F10DOGMA
You're still my hero
      01-19-2021, 09:12 PM   #87
FSHNGRY
FSHNGRY's Avatar
Drives: INDIVIDUAL F90 M5C LCI
Originally Posted by windtendo View Post
I'll chime in here... Your's is certainly lower than mine on the KW HAS setup. However, I could definitely go lower than I am now and I'm confident that mine could reach that same look.
Eurohorses you've got a great setup, and now I'm contemplating dialing it down just a bit more
@Eurohorses SICK. .THAT is the stance and look I want on my LCI. I have had KW HAS on my m4 for over 5 years, no issues whatsoever. Hoping the same goes with the F90.. maybe you can share any thoughts or issues? do you have spacers? . whats the difference w these and the MPE HAS kit?
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED
GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED
GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG |
IG: @FSHNGRY
      04-02-2021, 06:14 PM   #88
BrntRubber
BrntRubber's Avatar
United Kingdom
70
Drives: 991 Speedster and F90 M5
Great Thread!
Do you guys think with aftermarket 21"s the m550iX h&rs would be too aggressive?
