04-12-2021, 05:44 PM | #1 |
BimmerPost Supporting Vendor
2944
Rep 21,753
▀▄ eas - Antigravity Drop-in LiFePO4 Lithium Batteries for BMW M3/M4
While widely known for their MicroStart Jump Starter accessories, Antigravity Batteries has changed the game again with their latest Lithium-Ion Car Batteries. The newest RE-START line of batteries offers built-in WIRELESS Remote-activated Jump-Starting, plus a full Battery Management System (BMS) for the safest, longest cycle life possible. They come in exact-fit OEM sizes for most all modern Performance and Passenger Cars/Trucks. Antigravity also features full BMS and RE-START technology. All this at half the cost of the very-expensive-to-replace OEM ($1800+) battery.
Install Procedure https://f80.bimmerpost.com/forums/sh....php?t=1809127 Specs - H8/Group 49 OEM Automotive Case size (directly replace stock battery). - LxWxH: 14 x 7 x 7.5 inches. - Amp Hour Options: 60 or 80 Ah - Half the cost of OEM BMW battery ($1800+) - High Power: 60Ah=1800, 80Ah=2000 Cranking Amps - Exclusive RE-START Technology with Wireless Remote Built-In Jump Starting! - Complete Battery Management System built-in - Ultra Lightweight: Drop to 11.5 lbs instantly over OEM BMW battery! - Safest Battery Technology using full BMS and LiFePO4 Lithium chemistry H8 Group-49 Battery NEW! Lightweight Lithium Car Batteries with Wireless Remote Built-In Jump Starting! The first Intelligent Lithium-Ion Automotive Battery that won’t leave you stranded. Antigravity Batteries has changed the game again with their latest Lithium-Ion Car Batteries. The newest RE-START line of batteries offers built-in WIRELESS Jump-Starting! That means if your battery is ever discharged, simply press the Button on our provided Keyfob, start the car and drive away! No need for a Jump-Starter, or Roadside Assistance. You don’t even have to open the hood of car to access the battery, and can do it from the safety of sitting in your car! RE-START TECHNOLOGY: BUILT-IN JUMP-STARTING AG's amazing RE-START Technology is the first battery ever to offer Wireless Remote-activated built-in Jump Starting. (Can also be activated manually by pressing Restart button on top of battery.) So it won’t allow you to get stranded with a dead battery! For example if you left your lights on, the intelligent Battery Management System (BMS) in each RE-START battery would put itself to sleep before being drained dead, yet save just enough energy to start your vehicle again and get you out of that emergency. And with our WIRELESS REMOTE KEYFOB you can activate the Jump-Starting without ever opening the hood of the car. Simply press the Keyfob Button, start your car and drive away. FULL BATTERY MANAGEMENT: BUILT-IN BMS FOR SAFETY AND LONG LIFE The Antigravity Batteries RE-START system offers the latest technology for the safest, longest life cycle possible. Our superior on-board Battery Management System (BMS) offers Safety Circuitry to prevent Over-Discharge and Over-Charge, and has Short-Circuit protections, while additionally offering Cell Balancing and Thermal protections. These advanced features of our BMS make the battery not only as safe as possible, but also extend the life of the battery by keeping the battery in the prime operating zone and not allowing damage to the battery. Therefore creating the longest possible Life Cycle. From 7-9 years are expected from the Antigravity RE-START Batteries depending on use and climate. PERFORMANCE BENEFITS Weight: The ultralight 60Ah Antigravity RE-START Batteries weigh 18.5 lbs. The weight savings will lead the road in increasing your vehicle’s performance in several key areas such as handling, allowing shorter braking distances, improved acceleration and even better gas mileage. H8/GROUP 49 Models Available in 60Ah & 80Ah - both feature better cranking performance than a 90Ah Lead Battery FEATURES & BENEFITS - First Battery with WIRELESS Built-In Jump-Starting! Wireless Keyfob Remote actuated Emergency Jump Starting. So you won't be stranded by a dead battery ever again! - FULL Battery Management System (BMS) including Over-Discharge, Over-Charge, Short Circuit, Thermal Protections and Cell Balancing. - RE-START TECHNOLOGY: The RE-START Battery has self-restarting capabilities. It intelligently monitors its status and if it senses over-discharge it will put itself into a sleep mode, yet saves enough energy to allow you to RE-START your vehicle. Simply press the wireless keyfob or activation button on the battery. - OEM FITMENT: Exact Lead/Acid Replacement sizes. No additional modifications or trays necessary to install. - LONGER LIFE: 2x to 3x the lifecycle of lead/acid and other Lithium batteries due to full Battery Management system. - HIGH POWER: Up to 3x the Cranking Amps of similar sized lead/acid battery. Better Starting and higher voltage at start-up. - ULTRA LIGHTWEIGHT: The Antigravity RE-START Battery can be as much as 70% lighter than the Lead/Acid equivalent. This equates to roughly 40lb or more lbs of instant weight-loss just by changing out the battery! That makes the Antigravity Lithium-Ion Battery the most cost-effective weight-loss product hands-down, while offering better starting, handling and braking! A real performance value! - LOW SELF-DISCHARGE: The RE-START Battery does not self-discharge like Lead/Acid Batteries. It offers a longer storage time provided there are not excessive parasitic drains on the battery. - DURABILITY AND CAR SAFE: Much more resilient to vibration than Lead/Acid. Incredibly shock and vibration resistant; no liquids or acid inside to spill or drain out. Will not release dangerous Hydrogen while Charging and will not leak liquids that are damaging to your finish or chassis such as acid. - ENVIRONMENTALLY SAFER BATTERY: No Acid or Heavy Metals such as Lead, Cadmium, or Mercury. Always remember to Recycle your batteries responsibly! Models Supported 2015-2020 BMW F8X M3/M4, including Competition, CS and GTS Ordering: Phone: You can reach us directly by calling 866.669.0705 x31 to place your order over the phone. Payment: Credit/Debit Cards: Visa, Mastercard, Discover, PayPal, Google Checkout (available online & over phone) Other Payments: Money Order/Cashier’s Check & Bank Wire Transfer are also available. Please contact us to pay with either of these methods. Shipping: All orders will be shipping via UPS. If you are interested in shipping to Hawaii, Alaska, or internationally, please contact us directly, as you will be charged additional shipping fees. Hours of Operations: Monday - Friday from 9AM to 5PM PST Saturday - 9AM-2PM PST Sunday - Closed Retail Location/ Installation Center: Come check out our 8000 square foot facility in Anaheim, CA. We install everything we sell. Contact Info: Phone: 866.669.0705 x31 Email: kevin@europeanautosource.com Website: http://www.europeanautosource.com Feel free to contact me via PM, email, or phone if you have any questions.
Kevin S. | european auto source (eas)
email: kevin@europeanautosource.com · web: https://europeanautosource.com· tel 866.669.0705 · ca: 714.369.8524 x31 GET DAILY UPDATES ON OUR BLOG · FACEBOOK · YOUTUBE · FLICKR · INSTAGRAM |
04-22-2021, 05:50 PM | #2 |
2944
Rep 21,753
Antigravity battery kits ready to ship
PM today to get yours
04-29-2021, 06:26 PM | #3 |
2944
Rep 21,753
08-30-2021, 06:13 PM | #7 |
2944
Rep 21,753
Antigravity Batteries ready to ship
09-20-2021, 06:32 PM | #8 |
2944
Rep 21,753
Antigravity batteries ready to ship
10-18-2021, 06:30 PM | #9 |
2944
Rep 21,753
11-04-2021, 06:25 PM | #10 |
2944
Rep 21,753
Antigravity batteries ready to ship out
11-30-2021, 06:31 PM | #11 |
2944
Rep 21,753
01-18-2022, 06:50 PM | #12 |
2944
Rep 21,753
Antigravity battery kits ready to ship out
03-14-2022, 06:11 PM | #13 |
2944
Rep 21,753
04-05-2022, 06:41 PM | #14 |
2944
Rep 21,753
05-11-2022, 06:20 PM | #15 |
2944
Rep 21,753
Antigravity Battery kits ready to ship out
06-08-2022, 06:38 PM | #16 |
2944
Rep 21,753
07-11-2022, 06:55 PM | #17 |
2944
Rep 21,753
07-27-2022, 06:12 PM | #18 |
2944
Rep 21,753
Antigravity kits ready to ship out
08-08-2022, 05:54 PM | #19 |
2944
Rep 21,753
10-05-2022, 03:58 PM | #20 |
2944
Rep 21,753
11-08-2022, 06:20 PM | #21 |
2944
Rep 21,753
01-10-2023, 06:01 PM | #22 |
2944
Rep 21,753
Antigravity battery kits in stock and ready to ship
