BMW M5 F90 (2018+) General Forums Cosmetic Modifications    3.75" Slip-On Exhaust Tips for F90 - DIY
      05-03-2020, 03:35 PM   #89
mjr24
1657
Drives: M8 Comp GC, X7, AMG GT53
Originally Posted by MSX View Post
I kept the pin and enlarged the slot on the tips as suggested on page 1/2
used a drill and angle grinder to do this
Were the tips you bought like clarkey's where the inlet pipe is smaller than the outlet? Or are the tips the same size on both ends?
2022 M8 Comp GC, 2021 AMG GT53, 2022 X5M Competition, 2021 X7 40i, 2019 M5, 2018 M550I, 2017 Audi Q7, 2014 M6 GC, 2013 Mercedes CLS550, 2011 750LI, 2008 M6 Cabrio, 2008 Porsche Cayenne S, 2004 Mercedes SL55 AMG, 2003 Mercedes SL500, 2000 Mercedes CL500, 1993 Lexus SC400, 1989 525i, 1985 318i
      05-04-2020, 06:00 AM   #90
MSX
100
Drives: X5
Originally Posted by mjr24 View Post
I am confused....so you did cut the centering pins or no?
I only ask because those tips are still out further than stock.....a lot of us do not want that.
MSX's tips look like they are pushed back to where the old ones were. They look more of like a rolled tip, too....like the OEM ones. Is this true? The Burger ones seem to be more blunt at the end.
yep this is true, much closer to the original location
      05-04-2020, 06:01 AM   #91
MSX
100
Drives: X5
Ok, cool.....and that link you posted is definitely the ones you bought? I had emailed that company and they replied today and said they could not verify they would fit the F90 because they had not tried them.
Definitely the ones will have to be modded, as described on page 1 & 2
      05-04-2020, 09:44 PM   #92
mjr24
1657
Thanks mate, you have been very helpful. Last question...the ones you got do NOT look like the ones in my pic below....where the one inlet part of the exhaust tip is smaller than the outside part, correct?
      05-05-2020, 11:34 AM   #93
Clarkey
Clarkey's Avatar
United Kingdom
38
Drives: 340i M Sport Touring
The ones from BMS as picture, have a smaller section, and you screw some grub screw to lock it from falling off. The pipe that is the actual exit in the exhaust for the car widens at the end, so the sleeve slips over, and the screws prevent it from sliding over the thicker part.
No mods required, but I purchased some shorter grub screw as as the ones that came with it poke out a little too much (they are about 14mm long) but only a depth of 6mm is required, then the screw is flush when tightened, effectively using them. Then I added a little thread lock to prevent any rattling loose.
Any more questions just ask. More than happy to post a little video of the fitting if it helps??
      05-05-2020, 06:48 PM   #94
MSX
100
Drives: X5
nope
      05-25-2020, 01:10 PM   #95
notabadname
notabadname's Avatar
Drives: 2019 BMW M5 Competition
2019 BMW M5  [0.00]
Originally Posted by Steeve19M5CP View Post
so on the competition model......you guys think the BMS black tips or chrome look better? I am on the fence
Black
      09-02-2020, 07:04 PM   #96
Amscene
Drives: 2019 GMC Yukon
What is the factory pipe diameter so I can choose a tip?
      10-22-2020, 07:12 AM   #97
leeadam
leeadam's Avatar
United Kingdom
469
Drives: F90 M5 Comp (Evolve Tune)
Ok BMS gloss black larger tips installed what do you all think? pics of oem vs bms below
where did you get gloss black i can only seem to find a horrible matt black finish that im not keen on.
      08-29-2021, 07:22 PM   #98
brad65ford
257
Drives: 2022 M3
Bring up this thread, any options available now for the F90 m5's? Seems its 75mm for the stock exhaust pipe. Really like these but doesn't list it being available for the F90's https://burgertuning.com/products/bi...=3180459753496
Spent a while looking on amazing and searches trying to find something that looks half way decent that will fit.
      09-03-2021, 10:53 AM   #99
FLF92019M5
Drives: 2019 M5
Just threw these on this morning. Only modification was to cut the metal pin on the pipe otherwise they were sticking out more than I cared for. Got them from Bimmer Plug. $600 for the set. Come in blue black or silver.
      09-03-2021, 02:28 PM   #100
jivom5
74
Drives: audi a7, c7 grandsport
Could you please post the dimensions of the tips, looking for something similar
      09-03-2021, 02:31 PM   #101
brad65ford
257
Drives: 2022 M3
Almost purchased the same tips just fo t like how far out they sit.
      09-06-2021, 07:33 PM   #102
FLF92019M5
Drives: 2019 M5
Specs are 76mm and length of 120mm. I have base M5 stock exhaust and they fit.. After looking at them over the weekend, I pushed the two outside tips further in. They were sitting flush with each other but I also thought the outside tip was sitting out too far and looked weird to me. They are staggered now. Looks better in my opinion but I have seen plenty of cars with both setups so just personal preference.
Appreciate 2
M5YER4.50
f90.kar94.50
      09-06-2021, 07:34 PM   #103
brad65ford
257
Drives: 2022 M3
looks better that way, nice work!
      11-10-2023, 08:52 PM   #104
M5YER
M5YER's Avatar
Drives: F90 M5
How did you cut off the alignment Pins off of the inlet exhaust?
      11-11-2023, 06:20 AM   #105
pbonsalb
5267
Use a grinder. Dremel can do it as well but will use up disks.
      11-11-2023, 10:24 AM   #106
f90.kar
@f90.kar
f90.kar's Avatar
Drives: F90 M5C
Anyone find carbon tips that fit on the LCI comp exhaust?
Found these and they say it’s a direct fit
https://www.fjmotorwerkes.net/produc...f90-direct-fit
| M5C | Satin Black | Argon Brown | MAD Primary & Secondary Catless Downpipes | RC GTS Black |
      02-29-2024, 11:59 PM   #107
Em5Comp
Drives: '23 M5C
Did you ever try these out or find one that fits the LCI comps?
      03-01-2024, 03:50 PM   #108
f90.kar
@f90.kar
f90.kar's Avatar
Drives: F90 M5C
Yes I did! They fit great, I had to cut off the alignment pin on the stock piping to make them work. It cuts off easily using a sawzall
