08-01-2022, 12:13 PM | #1 |
159
Rep 223
Anyone with input on this sound car makes at startup. It doesn't happen after car is fully warmed up and has been drives.
https://youtube.com/shorts/Dgos6uvMqLw?feature=share |
08-01-2022, 12:41 PM | #2 |
586
Rep 575
Drives: 2022 M5 CS & 2022 X5M
you should upload the video to you tube or something
08-01-2022, 12:46 PM | #3 |
159
Rep 223
08-01-2022, 02:20 PM | #4 |
719
Rep 785
I’m sorry, it could be my phone’s speakers but I don’t hear anything abnormal in that video. Perhaps you can have some one hold it where you believe the nose is coming from while you start her up?
08-01-2022, 03:08 PM | #5 |
159
Rep 223
08-01-2022, 03:46 PM | #6 |
586
Rep 575
I can hear it. No idea what that is, but between my cars, my dads, we've had 3 M5s and I've never heard this. I don't believe it to be normal, I'd take it to the dealer.
08-02-2022, 07:48 AM | #8 |
2281
Rep 3,305
sounds like mirror motor, see if they fold and unfold properly, there is a button you can push on the door.
Mike
08-02-2022, 09:46 AM | #10 |
159
Rep 223
08-02-2022, 10:09 AM | #11 | |
44
Rep 134
08-02-2022, 10:12 AM | #12 | ||
159
Rep 223
08-02-2022, 12:18 PM | #13 |
2281
Rep 3,305
does door have 'soft close'? that has a motor too. if drivers door not fully closed it will auto close.
Mike
08-02-2022, 12:29 PM | #14 |
159
Rep 223
08-03-2022, 12:41 PM | #16 |
586
Rep 575
I get a similar sound upon start up that I believe is the fuel pump or something similar. It doesn't sound like that though, so maybe whatever your issue is, is the same thing but its on its way out?
08-03-2022, 12:42 PM | #17 |
159
Rep 223
It gives a judder in brake pedal. So im not sure what exactly is it. Some said its a brake booster but im not sure.
08-03-2022, 08:37 PM | #19 |
159
Rep 223
08-04-2022, 03:24 PM | #20 |
230
Rep 299
All normal sounds.
I can even tell that was a cold start up turn off and another cold start up - since the lifters and pump are making those noises and they go away after about 1 minute correct ? |
08-04-2022, 03:33 PM | #21 |
159
Rep 223
That noise only comes up few min after cold start. If you restart the car or after being warmed up RPM dips below 600ish the humming start again.
08-04-2022, 06:10 PM | #22 |
1543
Rep 2,022
Sounds most like your hpfp or transfer case to me, could be abs or something else though. When you hear the noise does it change anything if you give it some gas or is the noise irrespective of engine rpm?
