01-24-2020, 01:13 PM | #23 | |
575
Rep 754
I think 20/21 is a little higher than what they run stock. I feel like it's more like 19/20. When I'm running map6 at +6 my average psi ends up being about 25lbs. I'm also using MS109 when doing that with tons of data logging and adjustments before hand. I don't get the crazy good DA's that a lot of guys do so you shouldn't have to push it that far. I know guys that run 10.2 with JB4 that are running e30 setups and only averaging 22/23lbs and others on race fuel that need 24lbs to get a 10.3. So much depends on other mods you have, air temp, humidity and overall DA. Not to mention getting a good launch. Not sure that helped or answered your question but GL
DME: 1848 DA 0-60 2.42 -- 1/8 Mile 6.38 -- 1/4 Mile 9.89 -- 60-130 5.91
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires Last edited by Hockeytyme; 01-24-2020 at 01:19 PM.. |
01-24-2020, 01:23 PM | #24 | |
575
Rep 754
What fuel were you running?
Evolve: 1418 DA 0-60 2.48 -- 1/8 Mile 6.47 -- 1/4 Mile 10.05 -- 60-130 6.48 JB4: 1096 DA 0-60 2.54 -- 1/8 Mile 6.50 -- 1/4 Mile 10.05 -- 60-130 6.18 IG: @hockeytyme All runs on street with no prep on 21 inch wheels and PS4S tires |
01-24-2020, 01:58 PM | #25 |
3619
Rep 4,532
Very impressed with everyone’s results ! On a side note, humidity percentage in the 30f range isn’t good but isn’t a killer like at 80F due to the amount of water grains present. Cold air will not hold as much grains. That’s why DA uses humidity in the calculation.
Hammer down ! |
Hockeytyme575.00 Miko M6655.50 |
01-24-2020, 02:00 PM | #26 | |
208
Rep 622
i was going by the info i found here on stock boost numbers... but i dont know if hes using MAP or Prethrottle Boost for that column. https://f90.bimmerpost.com/forums/sh....php?t=1513840 yeah launching in 28-30 degree weather is tricky. plus i test at an intersection where we drag race so i'm launching over painted white lines. i'm onto trying my 3rd set of tires that finally work now and consistently does 1.62-1.63 60fts, but feels like that's the limit for these poor all season tires im also considering do an intake.... it seems most of the faster cars have them, but it's tough to quantify if they are faster from intakes or extra boost.
997TT 6MT - 205 mph 1/2 Mile , 170+ mph 1/4 Mile , 3.2 60-130 mph , 2.4 100-150 mph , 1500whp
FSociety3812.50 |
01-24-2020, 02:27 PM | #27 | |
575
Rep 754
Assuming intakes help on the F90 it's a wild guess as to which one is the best as everyone has something different and putting up good numbers..haha Looking at those stock numbers that Xfire posted, they averaged 19.6 after taking away the shift which puts it into that 19/20 that I suggested. I'm sure that's not the proper way to calculate it but at least i'm comparing apples to apples as that is how I compute my average.
01-24-2020, 02:39 PM | #28 | |
21
Rep 73
Stock boost is tricky as the DME target is never the same, you can have DME target 16psi one day and 21psi the next (i've seen as high as 22psi personally). I'm sure you know this is why many running the JB4 prefer additive boost over absolute in these situations. Its very DA/weather dependent it seems too. 3 days ago my DME target in 4th and 5th was between 16-18psi for me, it seems thats all the DME thought it needed to reach its torque and load targets. lets say I hypothetically ran +5 and reached 4 psi of that target I was at 20-22psi and ran low 7s 60-130 remember hypothetically .
I think BM3 is great, had it on my F80. if someone knows how to setup a good map 6 on the JB4 and read logs (many dont) there wont be a huge difference if looking at only performance numbers on 93. You and I live close, we could do a compare of the two on 93 maps if people only want to know the performance difference, BM3 has a lot more benefits than just all out numbers too. Is BM3 using a static boost target? or it is using progressive boost based on achieving a load target? Quote:
01-24-2020, 04:20 PM | #29 | ||
208
Rep 622
i never bother with the avg boost just what it hits peak consistently. Quote:
not sure how boost targets work in BM3. assuming its similar to stock.
01-24-2020, 04:46 PM | #30 | |
3619
Rep 4,532
01-24-2020, 08:23 PM | #31 |
IG: @88jae88
1621
Rep 1,734
Bm3 platform is great and I don't see myself running anything else, it's super convenient and I love the fact that I can switch maps with my phone pretty quickly.
Every bimmer platform I get I will run it.. tbh bm3 kinda stopped me from going back to Audi in a weird way lol. For those that have been patiently waiting I know it's annoying but bare with them and you'll be happy when they finally deliver.
IM POOR..
01-25-2020, 07:16 AM | #34 |
4067
Rep 4,985
Well done!
I know it's a little OT, but I'm considering moving up to the F90 from my F80 ZCP. Were you happy after going to the AT and more weight? Do you miss the F80 much?
<b>2023 M5C SRG|Aragon || 2018 Macan GTS</b>
2019 F90 Comp MBB|Black (sold) 2018 F80 ZCP TB|SS (sold) 2015 F30 335 AW|CR (sold) 2015 F31 MG|CR (sold) 2011 E90 JB|Oyster (sold) |
01-25-2020, 07:38 AM | #35 |
461
Rep 524
Thanks for the write-up. The bm3 platform is new to me, so I appreciate the detailed results, screenshots of the interface, and general description. Looks powerful and a great idea. I tend to collect ecu files....this seems to make that a whole lot easier to do. The other features are nice as well.
edit: and car is moving. great stuff |
FSociety3812.50 |
01-25-2020, 01:01 PM | #36 | ||
208
Rep 622
i had the F80 ZCP for 2 years and it was a good car, never had any issues with it. i do miss driving manual daily but i don't miss the F80 at all. M5 is better all around, it is more boaty in offramps if you have it in comfort mode but I dont find my self taking them any slower than i used to. m5 is faster, more comfortable, much nicer interior, engine sounds much better. M3 did look better and mre aggressive though.
01-25-2020, 03:48 PM | #37 |
4507
Rep 1,862
Drives: powered by bootmod3
YouTube Channel [NEW] | Facebook User Group (20,000+ members) | Tech Support Website | Wiki | FAQ | iOS App | Android App | bootmod3 Web
Sales Support Email: sales@protuningfreaks.com | Tech Support Email: support@protuningfreaks.com |
FSociety3812.50 |
01-25-2020, 04:55 PM | #38 |
What goes here?
454
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
Is the F90 tune going to have adjustable overrun levels?
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
01-25-2020, 05:01 PM | #39 | |
294
Rep 456
2018 BMW M5
2018 Porsche GT3 2023 Porsche Macan S 2023 Porsche 911 Turbo S |
Mcc420475.00 |
01-25-2020, 11:25 PM | #40 | |
7779
Rep 2,602
Drives: MW Vespa w/pink racing stripes
I do once in awhile miss rowing my own gears, which is why I find myself shifting using the shifter more often than not, lol... |
spuntyb4066.50 |
01-27-2020, 05:56 AM | #41 |
Licensed Professional Slacker
1280
Rep 794
Drives: 2024 M2 and 2023 Mazda CX-30
I am simply amazed at the numbers that are possible with a "family sedan" such as this.
FSociety3812.50 |
01-27-2020, 09:24 AM | #42 |
239
Rep 978
It seems like we are on the very edge of 9's. When this can be done reliably, depending on whether it is on race gas or E fuel, more supercars will be left in our wake.
2021 M340i
2020 X3 M40i - her car 2019 M5, AW, DP's, MSR CAI, BM3, SOLD 2020 Chev. ZR2 Bison truck, Daily Driver |
Mcc420475.00 |
01-31-2020, 08:59 AM | #43 |
Cowboy Astronaut Millionaire
2317
Rep 2,887
Great results obviously. OP any particular reason why you decided on going with ER DPs as from other brands? Thanks
01-31-2020, 01:58 PM | #44 |
208
Rep 622
Price. I paid just over $1k for all 4 pipes on black friday deal. I didn't think the others were worth the premium to be honest.
JK-M562.00 |
