02-05-2016, 02:25 AM | #67 |
231
Rep 656
I see for the GT3 the FI-R do a 20 x 9 Fr and 20 x 12 in Rear.
Would the 20 x 12 fit the F82, and at what offset? I run 305/30/19 on stock ten at rear. Could I run a 315 or 325 on the 12?
///M4 | AKRA Evo & DP's | Brembo GT BBK | MSR CAI & CP's | MPSC2 |
Suspension : | KW CS 3-way | Dinan Toe Links | GC ARWJ & End links | IND Shims | SPL Control arms & End links | aFe Bars | |
02-21-2016, 01:54 PM | #68 |
Law Enforcer
25281
Rep 22,318
Drives: '22 Chalk Gray Porsche C2S
Ilia,
If I wanted to run a rear wheel square set-up of OEM E92 ZCP M3 wheels on my F82, would I have an issue up front? I know the wheel offsets put it flush with the fender in the rear, but how would the offset fare up front? |
02-22-2016, 10:46 AM | #69 | ||
BimmerPost Supporting Vendor
9604
Rep 10,891
You'd need to use a spacer in the front, to gain the inboard clearance necessary for a 10" wide wheel. The spacer size would change depending on which suspension you're using. The best solution would be to use an 8-12mm spacer, with a coilover suspension and an adjustable camber plate. Then you could have about 3 degrees of front camber, and use a 275/30/19 front tire. The only trick is, if you use a 10" square setup all around, you're stuck with a 275/30/19 rear tire as well, which is not optimal.
02-22-2016, 11:28 AM | #70 |
Law Enforcer
25281
Rep 22,318
02-23-2016, 11:15 PM | #71 | |
231
Rep 656
11 would be perfect, and maybe 9.5 upfront ?
01-02-2018, 08:41 AM | #72 |
Super modder
104
Rep 1,973
BBS LM-R 20x9 +8 and 20x10+ 18
This might be a stupid question but wanting to see if these will fit an F80 aggressive or not....have a buddy who wants my wheels badly but before going through the process of exchanging wheels get your professional input on the fitment.
Thanks for setting the E90 M3 up so well! Its been an enjoyable 3 years! Michael
SOLD - 2005 E46 M3 ZCP - I/B on black CURRENT - 2011 E90 M3 - meticulously modified 2015 X1 Xdrive 28i |
01-02-2018, 09:52 AM | #73 |
1274
Rep 1,290
I heard through grapevine that BBS will be offering a 20x9.5, 20x11 2-piece wheel with the right offsets, but only the LM-R. Any way you can convince them to also offer the timeless LMs with the same specs? Extra ask is to offer a factory black finish in either satin or gloss with black assembly bolts?
Thank you.
Dry sump flat six
08-15-2019, 12:01 PM | #75 |
2093
Rep 2,152
That fitment can work but not ideal. Fronts are too conservative and rears are very aggressive. Will look off unless u start adding spacers. And yes it would need a drop
08-18-2019, 05:47 PM | #76 |
1274
Rep 1,290
IND, do you find any side to side wheel gap variation on the F8X chassis? I'm referring to not suspension height gap; rather, how the wheel/tire sit flush to the fender.
This is becoming more apparent visually as correctly fitting aftermarket wheels push the tire much closer to the edge of fitment as folks try to get that extra width and poke sans rubbing. I'm seeing a 2-3mm variance where my passenger side is more in-board than the driver side. It's either the chassis is a smidge off from factory or my aftermarket wheels weren't cut correctly. Thanks!
Dry sump flat six
08-18-2019, 11:48 PM | #77 | |
65
Rep 129
08-19-2019, 01:55 AM | #78 | ||
1274
Rep 1,290
https://www.e90post.com/forums/showt...775&page=2 Trying to see if there's any documented instances of the above but for the f8x.
Dry sump flat six
kdotma3.00 |
12-18-2020, 01:25 AM | #79 |
Rep 29
Drives: 2016 BMW M4 Coupe
Looking to purchase apex sm10 rims for the M4
19x9.5 front 22MM offset 19.20.5 rear 22MM offset The current tire size on the car is 265/35/19 295/35/19 Would this wheel and tire set up be ideal? If I go with this would I need a 5MM space in the front and 13MM in the rear? My other alternative is 18x9.5 22 fronts and 18x9.5 35 rear. What would be the ideal tire size for this? Any other suggestions for somewhat aggressive set up? |
01-04-2022, 07:24 PM | #80 |
Rep 3
Reading through this post I want to confirm that 19x9.5 +27 front and a 19x10.5 +35 rear will be the "perfect" flush fitment without rubbing? And the "perfect" tire setup for that setup is 275/30/19 front and 295/30/19 rear? I don't imagine that having a stretch and if it does it's a very slight one. I definitely don't want the stretched look but a little is OK if clearance is needed.
I'll be lowered on EMD springs. Thanks! Last edited by han23le; 01-04-2022 at 07:30 PM.. |
01-04-2022, 07:29 PM | #81 | |
Rep 3
From what Ilia mentioned in the pages before your fronts should work fine with 19x9.5 +22, though it'll be aggressive. The rears will work with 275 tires and it'll be pretty stretched. |
01-20-2022, 04:14 PM | #82 |
65
Rep 173
Drives: 2017 BMW F83 M4 Competition
Spacer sizing
Hello, new to the site.
need to know what size spacers to install on my 2017 F83 Comp M. the tires look ok on it but I want to fill the wheel wells much more and possibly eventually lower it. The car is completely stock and the tires on it are 265/30 ZR20 285/30 ZR20 and they are Michelin Pilot Super Sports. Any recommendations as to who makes the best spacer and do I need to increase the stud size or not. S
2017 M4 Competition F83 MW/SO
01-20-2022, 04:35 PM | #83 |
65
Rep 173
Spacer sizing
01-21-2022, 06:39 PM | #84 | ||
151
Rep 548
