BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Auto Talent | Gruppe M Intakes for F90 M5
      05-31-2021, 12:03 AM   #67
FSHNGRY
FSHNGRY's Avatar
Drives: INDIVIDUAL F90 M5C LCI
Originally Posted by AutoTalent View Post
[SIZE="4"]
[img]
View post on imgur.com
[/img]
If you're searching for an increase in engine performance, look no further. GruppeM air intake systems are precision-engineered to provide an increase in horsepower and torque.
[img]
[/img]
[img]
[/img]
The GruppeM BMW M5 F90 carbon fiber ram air intake system was designed with K&N to dramatically improve airflow across the entire RPM range while also reducing intake temperatures. Every intake system comes with a proprietary filter element made exclusively for GruppeM by K&N. The result is a tremendous improvement in horsepower and torque throughout the entire power band of the engine by utilizing the "ram air effect" which forces a greater volume of air into the engine and increases the density of the intake charge.
Each intake application is custom engineered for your vehicle using the highest quality carbon fiber weave and is designed to fit perfectly with minimal installation difficulty. The result is a carbon fiber ram air intake system that looks as good as it performs.The large capacity filter case was designed to make use of engine room capacity to the maximum.The carbon filter case inhales running wind from the front directly, while intercepting heat in the engine room.
As a result of repeating the chassis dynamo test and the actual running test, the performance is improved in the whole area including the torque-up of the low speed range, the sharp rise of boost, the response up at high rotation speed region, etc. All of it is made of real carbon of Japan production.You will be satisfied with the feeling of presence in the engine room and also powerful air intake sound when you open the bonnet.[/SIZE]
Price? Availability? Gains? Let me know!
CURRENT: '21 M5| FSHNGRY | TARTUFO | CCB | MPE | KW | IND | EVENTURI | EISENMANN | DINAN | LOADED |
GONE: '15 F82 M4 | YMB | IND | MPERF | KW | BM3 | LOADED
GONE: '11 E92 335IS | BLKSPHR | OYSTER | LOADED
GONE: '05 E46 ZHP | LOADED | DINAN STG3 PKG |
IG: @FSHNGRY
      06-21-2021, 08:23 PM   #68
AutoTalent
AutoTalent's Avatar
2312
Drives: e92 M3 6mt | e60 M5 6mt
Visit our website by clicking HERE. Please feel free to reach out with any questions or inquiries!
      07-07-2021, 05:41 PM   #69
AutoTalent
AutoTalent's Avatar
2312
      08-18-2021, 08:57 PM   #70
AutoTalent
AutoTalent's Avatar
2312
      09-13-2021, 08:06 PM   #71
AutoTalent
AutoTalent's Avatar
2312
Tags
autotalent, cold air intake system, f90 intake, f90 m5, gruppe m, gruppem
