BMW 5-Series (G30) Forum iDrive, Audio, Bluetooth, Phone, Cameras, Electronics + Coding G30 - ASS Coding
      12-10-2017, 03:31 PM   #23
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
Originally Posted by gizmonder View Post
There are 19 ECUs in Esys and ISTA. And there is no DME_BAC2 (and any DME at all).
I've tried to read data in diagnostic mode, with running engine, with just ignition on - same result - no DME.
UPD:
Screenshot attached
Which version of E-sys and Launcher are you using? If premium, which chassis are you selecting and which E-sys connection target?
      12-10-2017, 09:57 PM   #24
gizmonder
Belarus
Drives: G30 530i
Esys 3.28.1 + Launcher Premium V2.7.1.135
S15A, Connection via VIN, G30
      12-10-2017, 10:05 PM   #25
Almaretto
Almaretto's Avatar
2374
I have never seen a G-series with that few number of ECUs. Unfortunately, I am also not sure what is causing car to not read them all.
      05-30-2018, 04:55 AM   #26
maxpavlov
maxpavlov's Avatar
Drives: 540i xDrive G30
He needs to turn the ignition on, read the ECU(s) (he will see around 17) and then edit fdl. Turn the ignition off and Code FDL. This way he will not have the engine turn off while codes being applied, and will still see the "sleeping" ECU's as per his screen shot above.
Max Pavlov
      05-30-2018, 04:56 AM   #27
maxpavlov
maxpavlov's Avatar
The only really tricky part is to code ACC memory for Eco Pro. Mine still has ASS on every time I switch to Eco Pro, but I remember seeing this setting somewhere.
Max Pavlov
      11-16-2019, 09:07 AM   #28
Sasquartch
606
Drives: 520i G30
I had exactly this problem, only 6 ECU's detected
I just turned engine on and then off.
Then all ECUs became visible and I could code the stop/start setting in the DME_BAC2 module without problem
      07-01-2020, 01:00 PM   #29
PeteM5
Drives: M55i 2017
Hi
After upgrading the DME at the BMW workshop (20200622), I will not be able to access the DME ecu.
Do I need to upgrade E-sys?
M550i 2018
      07-02-2020, 10:44 AM   #30
Bandoul
Bandoul's Avatar
Drives: 2020 M550i xDrive
Originally Posted by PeteM5 View Post
Hi
M550i 2018
Which version of E-Sys/Launcher are you using? You will also need the latest PSdZData lite.
      10-21-2020, 11:27 AM   #31
bydusan
Drives: bmw e60 535d
Originally Posted by pemz View Post
Ok, so leave the engine off and contact on. Gonna try again in a few.
EDIT:
It worked. Thanks again Almaretto, you're a big big help! vkoprivica too!
Next step is, enable start in ECO PRO mode... :-)
That anyone knows how to code this (to work in eco pro mode)?
      01-31-2022, 03:13 AM   #32
iliannavy
Drives: bmw f10
EDIT:
Hello.Do you mean to start remotely by keyfob or.....?
If you start remotely car by keyfob in comfort mode could you share info.
Thanks
      01-15-2023, 02:30 PM   #33
Pyro1992
Pyro1992's Avatar
Germany
Drives: G30 540i xDrive 2019
i´ve coded tcm_msa_memory to wert01 in dme but the memory always turn "off" after turn off ignition. also it dont remember...Any Idea? I-Step is 21-03-520....Ive completly disabled MSA but with 2 engine errors this is stupid :/
      01-16-2023, 12:24 AM   #34
Bandoul
Bandoul's Avatar
Hi
M550i 2018
Did you figure it out? If not then I am sorry to tell you that with the new firmware, your DMEs are now locked and they need to be bench unlocked by a professional tuner shop in order to permit coding again.
      01-16-2023, 12:27 AM   #35
Bandoul
Bandoul's Avatar
Any I-Step newer than July 2019 and your DMEs are locked. BMW decided to many warranty claims for kids that don't know what their doing and blow up engine parts.
BTW, does your 540i have 1 or 2 DME's
      01-16-2023, 03:26 AM   #36
Pyro1992
Pyro1992's Avatar
Germany
As MHD Flasher readout, my dme is not locked (tested last week). Ecu date is 2018-xx-xx
And i only have 1 dme. Coding works fine on dme
      01-16-2023, 08:58 AM   #37
Bandoul
Bandoul's Avatar
I should have been clearer, production date of July 2019 and newer (Bosch DMEs).
      01-16-2023, 03:44 PM   #38
Pyro1992
Pyro1992's Avatar
Germany
I've coded the DME to default. (tcm_msa_memory =wert00) and then Change it again to wert01. After coding its sucessfull set after read the ncd again..... But it doesnt remember my setting ��
Seems to be I-Step relevant :/
      02-02-2023, 05:12 AM   #39
Almaretto
Almaretto's Avatar
2374
Never seen an integration level where it could not be coded. Also not sure why you coded it twice.
      02-05-2023, 02:00 AM   #40
G30M
G30M's Avatar
3792
Drives: BMW M550i; Kia EV6 GT
not sure if it helps i turned it completely off in bimmercode
      04-16-2024, 02:20 AM   #41
Curamrda
Curamrda's Avatar
Drives: F13
can anybody confirm that ASS can be coded with esysx for G30 LCI?
5post
