01-22-2021, 07:59 AM | #1 |
3524
Rep 1,004
Rust? No, Cosmoline
I just washed my M5 (2018 bought new in Sept 2018, 8500 miles, always garaged, hand washed, ceramic coated). While drying the doors I noticed a small spot (triangle) of rust? at the bottom of the front passenger door, front edge, inside. The bottom front corner of the front door. I checked the other door and it is the same: surface rust? showing on the bottom, front corner from the inside of the door.
Is this common? Has anyone had BMW repair under warranty? Mods: after searching and finding nothing I decided to post here, please move to appropriate sub forum if this ain’t the place. Last edited by 2000cs; 01-22-2021 at 09:21 AM.. |
01-22-2021, 08:25 AM | #3 |
3524
Rep 1,004
Have been in central KY (never driven in snow or on salt), now in Florida on east coast. I keep it very clean and hand wash and dry thoroughly whenever it shows dirt. Always garaged.
I’m going to check to be sure it isn’t cosmoline... |
01-22-2021, 09:19 AM | #4 |
3524
Rep 1,004
It is a hard spot to get my fingers into, but with a bit of effort I was able to scrape some off and examine it more closely. Pretty sure, and relieved, that it is cosmoline. In my experience cosmoline is yellow, and this is brown and very much looks like rust. But maybe they use brown cosmoline or it darkens with age.
Weird that it just showed up there now, must have slowly oozed to that spot. I can’t clean it off, but I suppose it won’t hurt anything as long as it doesn’t block the water drains. |
01-22-2021, 12:54 PM | #10 |
3524
Rep 1,004
Cosmoline is a greasy stuff that is used to prevent corrosion/rust. Porsche has used it for a long time on engines, so they have that yellow hue unless it is washed off. I didn’t know BMW was using it in the doors, but apparently they are.
