09-24-2022, 11:18 AM | #111 |
1788
Rep 3,495
As I type this I am sitting on my driveway waiting for roadside because this is the third freakin time this has happened to me.
On of the bottles was replaced less than six weeks ago and has failed already! For those of you that do not know, this is common in F90s. Symptoms will be as follows One or both coolant bottles will fail When you switch the car off you will notice the smell of coolant You may notice very tiny drops under the car on the floor If left long enough coolant will piss over the coils corroding them and will eventually get to the injectors and plugs After this you may notice a misfire and/or lack of power at very low revs You may also notice the car running rough when idling You will see coolant residue on and around the bottles You will either call roadside or take it to the dealer who will do a half arsed job just to get it out as quickly as it came in. BMW will possibly cross thread the lids when replacing them BMW will pressure test the coolant system and assure you everything is ok when in reality it probably is not. BMW will advise you to call it back in if it persists. This is the kind of thing you need to look out for.... |
09-24-2022, 11:35 AM | #112 | |
4154
Rep 3,705
Drives: 2022 M5C
I hope this gets sorted for you soon.
Not a BMW guy...but certainly an M5 guy.
F30Andy1787.50 |
09-24-2022, 12:57 PM | #113 | |
989
Rep 1,807
What is the year of your M5? |
09-24-2022, 01:19 PM | #114 |
1788
Rep 3,495
09-24-2022, 04:51 PM | #115 |
5285
Rep 10,682
Did you clean the radiator coolant tank at all? If not, I wonder whether the intercooler tank sprayed coolant over to the radiator tank. I did not think the intercooler tank got much over 100F or developed much pressure so I am surprised. Looks like the cap is where it leaked.
09-24-2022, 07:08 PM | #116 | |
94
Rep 75
Drives: 2019 M5, Ram 1500
09-25-2022, 04:15 AM | #118 | |
271
Rep 425
I did notice that the car sounded a bit rough at idle before I’d topped it up as well. |
09-25-2022, 05:19 AM | #119 | ||
989
Rep 1,807
09-25-2022, 06:29 AM | #122 |
5285
Rep 10,682
My 2018 had blue coolant. When I changed the thermostat, I added about 1.5 gallons of green.
If it takes a 600 ml loss to trigger the light, that seems like a bit much. I’d rather have it triggered at half that loss. It looks like the difference between the min and max indicators inside the tank is pretty small. I just ordered new caps for both tanks and a new intercooler tank. I replaced my radiator tank earlier this year as preventative maintenance. I also recently installed a 90C coolant thermostat and previously did some serious heat reduction and heat shielding in the turbo area under the tanks. |
09-25-2022, 07:54 AM | #123 |
989
Rep 1,807
09-25-2022, 08:02 AM | #124 |
271
Rep 425
09-25-2022, 08:15 AM | #125 |
989
Rep 1,807
BMW changed the coolant from blue to green recently, 2020 or 2021. I do not know for certain, but I suspect the change was made for a reason. Maybe to address this issue. Since I have been following this issue, I regularly monitor my coolant levels. About a month ago I notice my coolant is a little low. So, I call the dealership to see if they have any. I was first sold the blue and then when I called back after noticing they gave me blue when I asked for green, told there is a difference and the guy made it seem like it was a big deal to get the green.
09-25-2022, 08:16 AM | #126 |
Rep 37
Thinking about using teflon tape on threads to prevent leaks and hopefully ease removal of caps. BMW must address this problem and train there service techs not to cross thread. My caps were corroded and hard to remove, I used WD40 silicone on threads and removal now is easy. Not sure how long this will last.
09-25-2022, 08:17 AM | #127 | |
271
Rep 425
“ Green is backwards compatible with blue and can be used on cars before 2018. However, BMW does not advise using the older blue formula on cars made after January, 2018. The green coolant includes silicates, which add extra protection for cooling internals but the coolant must be replaced every two years” |
ResIpsaLoquitur4154.00 |
09-25-2022, 09:04 AM | #129 | |
4086
Rep 5,237
Nothing so far on the 22' luckily, but it feels like it's just a matter of time tbh until we have an actual solution in place.
M5Neededi94.00 |
09-25-2022, 11:01 AM | #130 |
94
Rep 75
If all the under warranty fixes they are having to make is not sending a message I do not know what will. You'd think they would look at recurring and common issues like this and take corrective action.
10-04-2022, 07:43 AM | #131 |
4151
Rep 7,165
Drives: F90 M5 / F15 50i
Well just got my first "low coolant" warning this morning. So exciting. 2020 16k miles. Was hoping they fixed this with the 2020. Off to get topped off at the dealer on my way to work.
Edit: was a "cup" low according to the girl. Crazy that would trip the warning. Also just realized she didn't check both reservoirs. Only the main one.
'07 Yamaha R1 (sold)
10-04-2022, 02:52 PM | #132 | |
345
Rep 322
Anyone confirm that these take the green HT12 coolant? Want to get some delivered to the house before I get home. Car goes in for service in 2 weeks.... add this to the list.
Current - Second 2023 XM (first one was taken back by BMW) and 2023 X7 40i
Past - 2009 X5 35d, 2011 MB E350, 2011 740i, 2015 X5 35d, 2018 M550i, 2019 X5 40i, 2021 M5C |
