Completely different car - WITH DYNO! (351whp/390wtq) [updated] |
09-01-2014, 11:18 PM | #89 |
10
Rep 246
I pulled the trigger tonight as well, changing from map 5 to map 7!!! I run 4.5 gal of E85 with 9.2 gal of 91......roughly 95.5 octane.
Initial impressions: Accelerated at stop light from a stop, making right turn (another car inside lane) did 60% or so throttle and OMG rear pushed out and I did short drift!!!!! Car feels faster on Map 7 than Map 5 (spent month plus running).
M235i (Black) Auto, JB 4 (Stage 2 / Map 7 with EWG & FF wires) ER DP, resonator delete, running E35, BMW Performance LSD, Hankook Ventus R-S3's (255/35/18 & 235/40/18) ATE Super Blue Racing brake fluid, 35% tint, black grills!
09-02-2014, 08:16 AM | #90 |
What goes here?
454
Rep 1,356
Drives: 2019 G30 M550i
Garage List 2019 BMW M550i [0.00]
2021 BMW M3 Competi ... [0.00] 2019 BMW M5 Competi ... [0.00] 2016 BMW M3 [0.00] 2014 BMW M235i [0.00] |
You shouldn't be mixing more then 30% E85 with the EWG JB4 setup. It is not designed for this and you risk running super lean!!!
2019 G30 M550i
GBNF: 2021 G80 M3, 2019 F90 M5 Competition, 2016 F80 M3, 2014 F22 M235i |
09-02-2014, 01:39 PM | #91 | |
10
Rep 246
Link to calculator: http://www.intercepteft.com/calc.html 4.5 gal E85 / 9.2 gal 91 95.6 octane 27.9% ethanol (or E28)
09-02-2014, 01:58 PM | #93 | |
What goes here?
454
Rep 1,356
2019 G30 M550i
09-02-2014, 02:49 PM | #94 | |
2731
Rep 3,437
I don't think carbon buildup is a concern and I have seen nothing indicating it produces more or less than standard gas. There are no real risks when mixing E85 in such low concentrations like this (as in only 4 gallons to our 15.9 gallon tanks). It's effectively 105-110 octane, burns a lot cooler than standard gasoline, and provides for more performance and knock resistance than Sunoco or VP 100-octane race fuel (pretty much the highest level unleaded fuel). It is however more corrosive than gasoline and is significantly less efficient, requiring 25-30% more fuel. This inefficiency is where problems may arise when you are using too much E85 at higher power/boost levels where the factory fuel system will not be able to flow enough fuel. |
09-02-2014, 02:56 PM | #95 | |
183
Rep 926
Great info thanks!
09-02-2014, 03:56 PM | #96 | |
34
Rep 171
I was thinking about running a HFS-4 along with E30. Overkill? |
09-02-2014, 07:11 PM | #99 |
What goes here?
454
Rep 1,356
I'd expect near what I got given that exact setup is what this thread is about!
Just remember to buy and install the flex fuel wiring harness with the ewg harness. |
09-02-2014, 08:01 PM | #100 |
2731
Rep 3,437
09-02-2014, 08:41 PM | #101 | |
Rep 100
That mixture would be about 35% . |
09-02-2014, 11:07 PM | #102 |
10
Rep 246
Station I get 91 at has no ethanol in the gas, some station put in E10 and others don't add any. Key is to ask station manager and consistently go to same station.
09-03-2014, 04:41 AM | #103 |
34
Rep 171
09-03-2014, 11:31 PM | #105 |
10
Rep 246
Station I go to is not a chain...... plus closest one to me for E85.
09-04-2014, 05:53 AM | #106 | |
GuidoDoc
17
Rep 211
Drives: Jeep Wrangler JKU
'11 335i xdrive Performance Edition BSM/Black
09-04-2014, 01:07 PM | #107 | |
Rep 100
See my numbers for gain with JB4 with MPE alone. 403/450 on E30/map 7 ET 12.39@112 with 2900 DA No Dyno stock but it ran 13.4@104 so at least 80-100 rwhp gain Definitely worth it for $600 bucks |
09-04-2014, 04:33 PM | #108 | |
1406
Rep 5,262
my best was 13.159 stock |
09-04-2014, 11:05 PM | #109 |
Rep 100
