02-28-2024, 08:30 PM | #1 |
Rep 15
How much poke is too much poke?
I just swapped out my 792M (19x8.0, 225/40 front and 19x8.5, 255/35 rear) for some BBS wheels (19x9.5 ET25, 255/35 front and 19x10.5 ET35, 275/35 rear).
The extra rubber has definitely helped transfer the power to the asphalt much better, but do you think there's too much "poke" in the back"? I've never really understood the "ideal" place for the tires to meet the fender. Or is it the wheels? I don't even know what angle to take these photos. I'm thinking the rear might look better if I add side skirts and a diffuser that wraps around to the side. Might make it look like it pokes less? I'd love your input. You can be honest, I can take it. |
02-29-2024, 12:31 PM | #3 |
Rep 15
No spacers, and so far, no rub. I have Dinan lowering springs.
I like how the front looks, but the rear looks like it “pokes” a bit, but again, I’m not sure how much is acceptable. |
02-29-2024, 02:13 PM | #4 |
Rep 17
I have a 330i, have a chance to buy vossen hf-5's from a guy who had them on his 340i, they are 9.5 all around, ive been killin myself trying to figure out of they will fit on the fronts on my car.
they are ET35 all round also |
02-29-2024, 02:35 PM | #5 |
201
Rep 353
Drives: 2021 M340i xDrive
I have 19x9 HF5s on my M340 with a 245/40/19, and I think I'm rubbing on the strut. I'm going to take a look underneath, but I think it rubs about 70% wheel turn.
02-29-2024, 03:13 PM | #6 |
103
Rep 148
I tend to prefer a conservative approach to wheels and tires.
In my opinion, both ends poke more than I would like. In addition the tires seem stretched. You went 1.5" wider on the front wheels, 2" wider on the rear, but only 30mm(f) and 20mm(r) on tire width. But - your opinion matters the most. |
02-29-2024, 03:19 PM | #7 | |
Rep 15
02-29-2024, 09:29 PM | #8 | |
Rep 17
If i believe him...since i cant find any info out there on this set up, would that even fit the 330? are they the same as the 340? noob here sorry lol |
02-29-2024, 09:50 PM | #9 | |
Rep 15
My car has Dinan springs, the front wheels are 19x9.5, ET25, tires are 255/35, and I don’t have any rubbing. 2020 M340i |
02-29-2024, 11:59 PM | #10 |
3798
Rep 4,144
does poke mean the sidewall sticking out past the fender line, or does it mean the rim sticking out past the fender line
usually the sidewall is wider than the rim i have 18x9 ET25 (it's actually ET35 but with 10mm spacers) square set up running 245 40 18 i'm not sure i like the look of it, looks like a boy racer. i don't think the rims are past the fender line but the sidewall of the tires are PS 9" is perfect for the Michelin PS4 245 40 18, they are not even the slightest stretched, these rubbers are wide! |
03-01-2024, 01:39 AM | #11 | |
Rep 15
03-02-2024, 06:00 PM | #13 | |
119
Rep 96
Drives: 2021 bmw m340i xdrive
Tires 245/35 /20 95Y XL FRONT 275/30 R20 97Y XL REAR Should give u an idea what yours would look like but my front offset is 25 and flushed no poke and clears the thicker shocks Sorry I don’t mean to bombard the post just helping OP out. |
bimmertaco6.00 kulfon4813.50 |
03-02-2024, 06:34 PM | #14 | |
Rep 17
03-03-2024, 05:59 AM | #15 | |
2723
Rep 3,337
I just did a quick calc using Apex wheel fitment guide. Their 10" rear wheel is ET38. A 10.5" wheel is 0.5" or 12.7mm wider; dividing that by two gives 6.35mm extra width on both sides of center compared to a 10" wheel. So their 10" rear front spacing (side facing outward) would be 3mm + 6.35mm less than your 10.5" wheel. The 3mm is offset difference (38-35). So the perceived "poke" on an Apex 10" rear wheel would be 9.35mm less (further in) than your setup. Aesthetically and perhaps functionally (i.e clearance with full range of suspension travel), Apex is likely in the right spot.
Current Stable:
2024 G20 M340i Melbourne Red/Cognac 2019 F87 M2 Competition 6MT, LBB, slicktop, exec pkg 2007 E91 328i Silver, slushbox, Eibach fr/E93 M3 rear sway bars, ARC-8 Last edited by CSBM5; 03-03-2024 at 06:08 AM.. |
M340I///M118.50 |
03-03-2024, 10:36 AM | #16 | |
119
Rep 96
CSBM52722.50 |
03-04-2024, 10:47 PM | #17 | |
Rep 15
I'll update the photos once I put these side skirts on. I'm hoping it'll help in some sort of optical illusion type of way. LOL. |
CSBM52722.50 |
