BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    What size wheel spacers did you put on your M5?
      05-14-2019, 10:55 AM   #67
Vic55
Vic55's Avatar
19365
Drives: 2023 BMW M8 Competition Coupe
Originally Posted by dardeca View Post
So is spring rate and damper valving (or programming) unaffected by the change in springs? What I don't want to happen is change some other characteristic/performance of the car (other than stance) by switching springs.
Its minute to say the least and this is not a track car. If you are the least concerned I would just keep it OEM.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White
2022 Porsche Carrera GTS Coupe Shark Blue
2020 Audi R8 V10 Performance Suzuka Gray
2012 Mercedes Benz C63 AMG Black Series Obsidian Black
      05-14-2019, 11:05 AM   #68
r33_RGSport
r33_RGSport's Avatar
Drives: G09 XM, G05 X5 40, 991.2 T
Spring rate will change since you are changing to different spring.
But, damper valving will not since you are still using stock damper.
So, you will still be in control on your dampening via the driving mode.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com
PM for Everyday DEALS!!
MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri
Active Autowerke • KW • H&R • Ohlins • Remus • and more...
dardeca499.50
      05-14-2019, 11:11 AM   #69
dardeca
dardeca's Avatar
Drives: 2019 M5 Competition
I'm probably not saying this correctly. I'm not so concerned about any changes in "feel"...this would be my first suspension modification...so I don't understand all the terms and features/differences.
What I'm trying to confirm is whether a change in springs will impact the electronic features/adjustability of the suspension. Sounds like "no", but just wanted to make sure I have a full understanding before doing a switch. I don't want to find out later that a spring switch eliminated comfort mode or something else.
E92 M3 Supplemental manual p.38: "The laws of physics cannot be repealed, even with DSC."
      05-14-2019, 11:18 AM   #70
windtendo
windtendo's Avatar
1716
Drives: 2023 M5C
2023 BMW M5C  [0.00]
1989 BMW M3  [0.00]
Changing springs alone will not affect the electronic features and adjustability from inside the cabin. You can go with springs or KW HAS at the moment. Now, if you went to a KW coilover, then you’d lose your in-cabin adjustability.
Appreciate 2
dardeca499.50
r33_RGSport12971.00
      05-14-2019, 11:49 AM   #71
Vic55
Vic55's Avatar
19365
Thanks for the clarity and as Wintendo stated, you are not going to lose any EDC functionality. The main intent of the springs, to me, is form over function. You want a better eye sight of the car when parked as did I. I still wallow over going to the M550i set up but for several reasons I hold off:
1. When I back out of my garage in my other cars the F90 looks plenty low but then again I backing in an R8, GTS, Porsche or an NSX and they are all much lower
2. Im lazy and dont want to go and lose a day for lowering further and then realigning.
3. I dont like Ben LOL aka r33_RGSport and he does my local work
4. Im lazy
r33_RGSport12971.00
      05-14-2019, 12:05 PM   #72
dardeca
dardeca's Avatar
4. Im lazy
So a realignment is necessary after the spring change?
r33_RGSport12971.00
      05-14-2019, 12:18 PM   #73
Vic55
Vic55's Avatar
19365
100%
You are changing the geometry of the oem specs and will need to reset the camber, caster, and toe. Most shops will have the OEM specs and can get the car back to range. If you dont do this you will possible have excessive tire wear and handling issues plus other issues like steering pull.
r33_RGSport12971.00
      05-14-2019, 12:35 PM   #74
r33_RGSport
100%
It would depends on how low you are going.
1" or less usually is not a big deal.
But, again, it will depending on the suspension setup.
In this case, the suspension design is double wishbone / multilink.
Where the alignment doesn't change much.
Camber, usually on double wishbone (front on F90 M5) is not adjustable.
While on the rear, multilink, is adjustable both toe and camber.
On McPherson suspension design though, like 2/3/4 series (include M), there is camber adjustment on the front.
What kills the tire is mainly the toe setting.
Appreciate 2
Vic5519365.00
dardeca499.50
      05-14-2019, 01:37 PM   #75
dardeca
dardeca's Avatar
Ummm...what? So are you saying I should drive it and see what happens afterwards? While clearly I'd be able to tell if it was pulling, not sure I'd notice any other issues around excessive tire wear (until it was too late).
I'll need to get my 1200 mile service done in the not too distance future, so could probably have an alignment done at the same time at my dealership.
      05-14-2019, 02:32 PM   #76
r33_RGSport
You can get it aligned right away.
But, usually I recommend to have the spring settled for 1-2 weeks before alignment.
      05-14-2019, 04:16 PM   #77
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Good to know. Also, I assume the springs just lower the stance...but don't affect any of the adjustability of the car? Meaning, comfort, sport, sport plus suspension settings and all the other features in the car aren't affected by the change in springs????
Not affected.
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
dardeca499.50
      05-16-2019, 06:15 PM   #78
dardeca
dardeca's Avatar
Ben - thanks for answering all my many questions and for the great customer service! Can't wait to get the springs and spacers installed.
r33_RGSport12971.00
      05-16-2019, 06:38 PM   #79
r33_RGSport
Thank you for your support.
      05-16-2019, 07:47 PM   #80
Vic55
Vic55's Avatar
19365
I deserve commission.
Appreciate 3
dardeca499.50
r33_RGSport12971.00
      05-16-2019, 08:19 PM   #81
r33_RGSport
I got your beer if you are coming over this Saturday.
      05-16-2019, 08:21 PM   #82
Vic55
Vic55's Avatar
19365
No, I want springs and install and you need to pay me to show up.
r33_RGSport12971.00
      05-16-2019, 08:31 PM   #83
r33_RGSport
      05-20-2019, 11:18 PM   #84
mtndog
mtndog's Avatar
117
Drives: F90 M5c, 992GTS, x5 M60
I have installed 11/11 on Quickburn7 and 15/11 on my other local customer with Nardo Grey.
H&R doesn't make 10mm unfortunately.
Some is using 12mm on the rear.
I would say 15/11 or 15/12 is perfect setup.
Let me know if you need to get a hold of them. Got them in stock.
PM sent
      05-20-2019, 11:22 PM   #85
r33_RGSport
PM sent
Replied.
mtndog116.50
      05-21-2019, 06:49 PM   #86
MThree_Forty
MThree_Forty's Avatar
48
Drives: 2020 Dravit Gray M340ix
Spacers
12 Front
10 Rear
      05-21-2019, 09:26 PM   #87
dardeca
dardeca's Avatar
Decided to go 15 front/11 back + H&R F90 Sport Springs. Car is going to the shop tomorrow for install. I'll post some before and after pics so people can get an idea of the drop on a M5 Comp.
Appreciate 2
r33_RGSport12971.00
BocaM50.00
      05-21-2019, 10:27 PM   #88
mtndog
mtndog's Avatar
117
Replied.
Thanks for hooking me up!
r33_RGSport12971.00
