03-01-2022, 11:02 AM | #1 |
2274
Rep 3,300
Front differential Oil change - anyone DIY yet?
I got a message from my dealer who said the "Car called them" and said it needed an oil change and a differential oil change for the front differential.
Anyone DIY this yet?? Mike
03-01-2022, 11:54 AM | #3 |
2274
Rep 3,300
as per this, the Front, Rear and Transfer case oil is supposed to be changed every 90,000 km. So why is my car asking for only the front? This is very odd.
Mike
Egrunt553.00 |
03-01-2022, 01:30 PM | #5 | |
2274
Rep 3,300
The PDF for the front diff says 600 ml, but the PDF for the rear diff has a 'broken' link to a table. So I have to figure out the proper volume of fluid for the rear diff. I have that special oil already for the rear. Front uses less fancy fluid. LOL. Mike
03-01-2022, 02:14 PM | #6 | |
1543
Rep 2,021
03-01-2022, 10:09 PM | #7 | |
292
Rep 605
OCDoningtonF9039.00 |
03-02-2022, 04:37 AM | #8 |
21
Rep 48
I actually went to have secondary dp installed and shop noticed front diff fluid seeping and lower oil pan gasket seeping/leaking. They said diff looked to be over fill and There was oil stains all over the bottom of the pan. After my last oil service I noticed oil drops on my garage floor the next day, took it back they said spillage and cleaned it up. Now it's at the dealer for this, they are waiting on approval to change the gasket. Any thoughts on what would cause lower oil pan gasket to leak. Over fill of oil? The car is really babied with couple pulls here and there. 9k miles on it.
Thanks |
03-02-2022, 04:41 AM | #9 | |
1543
Rep 2,021
03-02-2022, 04:46 AM | #10 | ||
21
Rep 48
03-02-2022, 05:43 AM | #11 | |
2274
Rep 3,300
Interesting update in the Manual says now to use the G1.
03-02-2022, 05:49 AM | #12 |
2274
Rep 3,300
The section on the front diff SPECIFICALLY says 600 ml. Second picture.
The section on the rear diff has no such specification, only that the stuff comes in 1 liter bottles. So I can see how the techs would overfill using the old school, fill until it runs out. This is shown on videos, but APPARENTLY not supposed to are done with the M5????? ODD. Mike
03-02-2022, 05:53 AM | #13 |
2274
Rep 3,300
I have 4 of these (500 ml each) so I'm good to go for the next two changes LOL. Unless it's true that the G1 "Should be used"
I'll bet if you ask the dealer they will have no idea which is now the correct oil to use in the rear. Mike
Maverik2594146.00 |
03-02-2022, 07:41 AM | #14 |
1543
Rep 2,021
The g1 is for non m vehicles ( says it in the pdf) the thing with ista is it gives you the info for every car and you have to piece together what's for what lol...
03-02-2022, 08:02 AM | #15 | |
2274
Rep 3,300
I have the G4 and plan on using that for the rear. I am getting other materials together. The transfer case is much more involved though, as per the PDF you need to disconnect the drive shaft to have access to the drain plug. Nice design. Mike
03-02-2022, 08:35 AM | #16 |
2274
Rep 3,300
This the kind of BS that just pisses me off.
The 'F90 Complete Vehicle' PDF has this.... SPECIFiCALLY calls out the volume of fluid for the front differential but neglects such information for the Transfer case and Rear Differential. Lame.... Mike
03-02-2022, 08:44 AM | #17 |
2274
Rep 3,300
F )U*(__()_)*()_&_* I found it...my bad.
1 liter. LOL
03-02-2022, 10:21 AM | #18 | |
1543
Rep 2,021
03-02-2022, 10:26 AM | #19 |
2274
Rep 3,300
Everything ordered, engine oil, filter, air filter, carbon air filter, diff fluid for front, 14 mm wrench, 4 new plugs, transfer case fluid and plug, oil transfer pump...$$557.....
Mike
03-02-2022, 10:33 AM | #20 |
983
Rep 1,801
03-02-2022, 10:38 AM | #21 |
2274
Rep 3,300
03-05-2022, 08:01 AM | #22 |
2274
Rep 3,300
Bought all the supplies from FCPEuro. What is with their INSANE warranty?...I return the oil and filter (engine oil and diff oil etc) and pay the return shipping and they send a new setup for free? WHAT THE HELL? It's real. But it's insane. LMAO
Mike https://www.fcpeuro.com/products/5-8...arwrench-80546
