01-12-2021, 02:26 PM | #1 |
53
Rep 31
Kidney grill removal
Does anyone know how to remove the kidney grills on an LCI competition? I was looking at pre LCI instructions and they show the how to remove the grills separately but I noticed on the LCI that both grills are in one piece.
AG
01-12-2021, 07:42 PM | #2 |
377
Rep 541
On pre LCI they're held in by clips. So you take a flathead screwdriver to push the clips out on the top and out she comes. I imagine it would be pretty much the same method? Just pop the hood and check for the clips.
01-12-2021, 07:56 PM | #3 |
53
Rep 31
I was able to push the clips in from the top but I felt like it's held in tight by something else on he buttom, I was hesitant and didn't want to break anything so I put it back together until I get some more insight.
AG
01-13-2021, 12:35 PM | #4 |
41
Rep 109
yes, it can be a bit tough, give it a pull. you won't break it. Just did it a few weeks ago. Can put some painter tape around the grilles to protect the paint, bumper, etc.
01-13-2021, 04:48 PM | #5 |
53
Rep 31
I will definitely give that a second try. Thank you
AG
01-13-2021, 06:23 PM | #6 |
249
Rep 2,084
Please update this once you get it figured out! I have a black grill on order for my LCI non-comp as I preferred the ride of the non-comp as a daily. Just getting rid of the chrome asap.
2012 Audi R8 V10TT| 6MT| Suzuka Grey
2015 Ferrari 458 Speciale| Rosso Scuderia 2020 BMW X7| Mineral White 2022 992 GTS| 7MT | Shark Blue |
01-14-2021, 08:49 AM | #7 |
41
Rep 109
so when you push those big tabs in, should be noticeably movable on the top. However, there are clips on the bottom and sides as well. You don't want to pull too hard, as you may break. But, you can wiggle a bit and feel those clips move, then give it a bit of a pull. I do suggest the painter table around that i mentioned, don't want to scratch. The same process when you put the new grille back in.
01-18-2021, 09:05 AM | #8 | |
249
Rep 2,084
01-18-2021, 09:55 AM | #9 |
41
Rep 109
good point. pre LCI. I imagine they are similar, but I have seen other grilles have different clip locations. Let's see some pics when you get it, We can compare and figure it out.
01-21-2021, 03:58 PM | #10 |
53
Rep 31
Update
I finally got a chance to give this a second try, so I used painters tape on the bumper like you guys suggested, pushed the tabs from the top and gave it a good yank. It came off
Btw the two kidney Grills on the LCI are one piece. I added some photos
AG
01-22-2021, 10:27 AM | #11 |
41
Rep 109
Look at that. One piece now. Photos look great. Nice job!
02-01-2021, 01:08 PM | #12 |
249
Rep 2,084
I swapped the chrome grill on my LCI to the black one. Pushed down on the top clips with a screw driver, wiggled it out on top slightly, then worked on the sides and a nice firm yank got the bottom ones out. Just be careful as the front camera is in there, just need to undo the two tabs to take the camera out and then put into the new grill by just pushing into place. Car looks so much better with the black grill then the chrome, though wife liked the chrome one better haha.
02-03-2021, 09:55 AM | #13 |
41
Rep 109
I guess the chrome is simply taste. Honestly, i blacked out all of the chrome bits simply because of the bluestone color and the black wheels. If they were the bi colored wheels, i likely wouldn't have.
02-14-2021, 06:51 PM | #14 |
146
Rep 498
Have a non-Comp LCI on the way. Can anyone recommend a place to order black kidney grills? Are you just ordering the Comp grills or is there another option? Thanks!
02-15-2021, 10:26 PM | #15 |
125
Rep 76
I got my car on Saturday. Just had the kidney grill surrounds and lower rear bumper above the diffuser wrapped today. Was easy for the wrapper to do; no need to remove the parts. Why not just wrap your kidney grill surrounds?
02-26-2021, 11:42 PM | #16 |
125
Rep 76
What LCI splitter is that? Looks great.
12-07-2021, 09:32 AM | #18 |
59
Rep 120
I just swapped my base M5 chrome kidney grill with a IND black one. Only took 15 minutes to do the swap.
In my case the two bottom outside plastic clips broke off but since it was a replacement swap it isn't an issue. If you plan on reusing the kidney grill you need to be careful not to break the bottom clips. |
07-07-2022, 12:38 PM | #19 |
41
Rep 131
The LCI Comp has updated softer and more comfortable suspension, is it still noticeably harder than a LCI base?
06-23-2023, 09:23 PM | #21 | |
105
Rep 1,435
M5
What front lip ur car is a lci ? |
