BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    2021 BMW M5 LCI Competion Help
      01-06-2021, 01:39 PM   #1
Principe
Drives: 2018 F90 M5 1st Edition
Hi every one i have a little situation and want you guys help or input
Car:
2021 BMW M5 LCI Competition
Mod:
Catless downpipe
Mid section delete (race pipe)
Akraprovic exhaust
Full intake Lusso Performance (Front Bumper)
JB4 w/Bluetooth adapter (suck)
Problem:
Ck engine is on code are
180001 catless downpipe detected
180101 catless downpipe detected bank 2
I have JB4 with the latter firmware and to be hones suck don’t delete i been talking to them no help what so ever upgrade the chip the Bluetooth adapter and no luck
Try to have the MHD have the adapter but look like the ECU is lock my car is built in 8/2020
What option i have or what to do
Thank in advance
Quick note i have all that on my 2018 M5 1st edition and work perfect now JB4 telling me that JB4 from 2016 and older don’t deleted the ck engine light note person was (Ando) to confirm thank
      01-06-2021, 04:04 PM   #2
josec70
josec70's Avatar
Drives: 22' Individual Chalk M5C
Car:
Mod:
Catless downpipe
Akraprovic exhaust
Problem:
I have JB4 with the latter firmware and to be hones suck don't delete i been talking to them no help what so ever upgrade the chip the Bluetooth adapter and no luck
Thank in advance
Quick note i have all that on my 2018 M5 1st edition and work perfect now JB4 telling me that JB4 from 2016 and older don't deleted the ck engine light note person was (Ando) to confirm thank
CEL has to be removed via flash tune or remove DP's .. JB4 will not remove CEL.
The early JB4's did remove but latter versions did not ..
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO
GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY
GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND
LONG GONE: 09' E60 M5|02' E39 M5
      01-06-2021, 06:38 PM   #3
Principe
I understand that but no flash tune yet on the 2021 M5 yet that why I’m need help
I don’t know if a o2 plug extender will help or fix it or some one else have the same situation and have it resolve it I don’t want to remove the cat delete yet ??
      01-07-2021, 04:37 PM   #4
Kponti
111
Drives: 2023 M8C comp
Are you noticing any acceleration improvements with the JB4 on the 2021?
      01-08-2021, 06:58 PM   #5
Principe
Nop to give you a example i ran 10.8 with the M5 2018 1st edition JB4 exhaust downpipe filters and i ran 10.9 M5 2021 Competition Stock
      01-11-2021, 01:27 PM   #6
Kponti
111
Not sure you understood my question so let me rephrase.
Is your 2021 M5c faster after you installed the JB4 or did it stay about the same?
BTW 10.9 stock is pretty fast!
      01-11-2021, 05:59 PM   #7
Principe
Same I don’t see diferent i try map 1, 2 and 3 but i keep you update when i get back to the track after i resolve the ck engine problem
      01-12-2021, 12:04 AM   #8
euro*
euro*'s Avatar
1654
Drives: F90 M5
There is no flash tune available on 2021 right now, and jb4 will not remove check engine either.
You either have wait until the ecu is cracked so you can flash, or take off downpipes.
You will not get any further help from the forum, as there is no solution available as of now.
      01-12-2021, 08:54 AM   #9
Kponti
111
Got it. Thanks for the current and future updates.
Seems even Piggys are being affected by this new updated software. Time to look into the M8c and stay stock
      01-14-2021, 12:41 PM   #10
Principe
Nice option i will maybe trade it for a Huracán 2021 will see i have this lock ECM
Search this Thread:
Advanced Search
