01-01-2021, 03:36 AM | #1 |
59
Rep 114
Battery issue or alternator issue?
I replaced the battery cause of this issue 3 times so far. Originally battery was bad i knew that. It said to replace the battery so i swapped the battery with my other car which is compatible. And programmed successful. But that battery went bad too and i ended up with 2 bad battery.
This is the problem im experiencing, when battery is plugged to the charger voltage goes upto like 18-19 randomly and voltage doesnt seem steady. It goes up snd down so bad. Because of this issue so far cluster had to be replaced because cluster got fried also. If alternator is bad can battery voltage can go up and down crazy? |
01-01-2021, 07:46 PM | #2 | |
974
Rep 1,795
02-24-2021, 03:00 PM | #4 |
51
Rep 30
Drives: 2021 M8 F93 comp
Have you a special LiFe charger?
Gretz
Dawid K |
02-24-2021, 03:02 PM | #5 |
51
Rep 30
Max voltage for charging this battery is 14,4 V. When you have used higher voltage you probably damage the battery
Gretz
Dawid K |
02-25-2021, 01:47 PM | #6 | |
268
Rep 380
