BMW M5 F90 (2018+) General Forums Wheels | Tires | Suspension | Brakes | Chassis    ACM| JRZ Performance Coilovers for F90 M5!!!
      12-29-2020, 02:51 PM   #1
jeff@autocouture
jeff@autocouture's Avatar
966
Drives: 2002 E53 X5 4.6is
Working with JRZ, ACM developed the RS One Touring Coilovers for the F90 M5. ACM is the exclusive dealer for this new coilover system. Knowledge gained from racing is integrated in the JRZ RS ONE Touring system. The use of the large shaft creates an optimum fluid displacement through the preset compression blow off valve to control the unsprung mass. A special designed piston is used to filter out the large, high velocity movements seen with suspensions on street applications.
No need to compromise on performance/comfort due to the large adjustment range. The suspension allows adjustment between smooth street use and aggressive track use. With every click (counter clockwise) you increase the damping forces in both compression as rebound making the suspension stiffer. With every click you will notice direct influence on the handling of the car. Therefor adjusting the suspension is very quick and easy.
-Single Adjustable
-Includes Plug & Play Error Cancelers
-Adjustable damping
-21 clicks
-Ride height adjustable
-Uses spherical bearings
-Valved for more chassis control and performance
-Fits aftermarket topmounts
-Every click noticeable change
-Made in the Netherlands
Please Email Jeff@autocouturemotoring.com OR Matt@autocouturemotoring.com for further details, pricing, availability and installation quotes!
GranitM5366.00
      08-27-2021, 07:48 AM   #2
Matt@AUTOcouture
Matt@AUTOcouture's Avatar
4163
Drives: V8 tricycle
Some more JRZ eye candy
GranitM5366.00
      08-27-2021, 03:44 PM   #3
FatRear08
FatRear08's Avatar
1427
Drives: F90 M5
Absolutely scrumptious…🥰
