BMW M5 F90 (2018+) General Forums iDrive, Nav, Stereo, Bluetooth, Electronics    Help with jammers
      11-14-2020, 06:45 AM   #1
lsal
We are all Longwong
lsal's Avatar
Drives: F90 CP LCI
2013 BMW M3  [10.00]
Looking to put in a stealth laser/radar detector/jammer setup on my LCI. Any recommendations for setups that work well and placement of control unit(s)?
Thinking of ALP + RCM and build the controller into the panel to the right of the shifter.
      11-14-2020, 06:58 AM   #2
TheGrinch
47
Drives: BMW
Weird I was about to put up a similar post. Are detectors/jammers still a thing? Back in the day it was Passport. I know about Waze, are any devices any more effective? Thanks.
      11-14-2020, 07:05 AM   #3
lsal
We are all Longwong
lsal's Avatar
Drives: F90 CP LCI
2013 BMW M3  [10.00]
Depends how you drive I use Waze regularly, but lots of units go unreported, and you never know who you pass along the way.
I used to have a really nice stealth setup on my e92, so trying to do something similar.
      11-14-2020, 07:07 AM   #4
TheGrinch
47
Drives: BMW
Is stealth a concern because electronics are illegal in some states? I'm really out of the loop on these haha.
      11-14-2020, 07:10 AM   #5
lsal
We are all Longwong
lsal's Avatar
Drives: F90 CP LCI
2013 BMW M3  [10.00]
Radar is legal almost everywhere I believe, but jammers are really a stare by state thing. Honestly less of a concern about getting caught with the jammers, and more of an esthetics thing... I really like the OEM look.
      11-14-2020, 07:11 AM   #6
TheGrinch
47
Drives: BMW
I'm with you there. Who are the main players? I should start doing research before my car gets here.
      11-14-2020, 07:16 AM   #7
lsal
We are all Longwong
lsal's Avatar
Drives: F90 CP LCI
2013 BMW M3  [10.00]
Escort, r cm, al p...
      11-15-2020, 04:52 PM   #8
subterFUSE
subterFUSE's Avatar
564
Drives: 2023 Audi R8, 2023 Audi S8
For laser defense, ALP is the leader because it's the only system that reliably counters the most modern threats like VPR guns. Placement and installation of the equipment is CRITICAL if you want your system to work. Hiding sensors in aesthetically pleasing locations rather than the recommended locations will mean the difference between a system that works or doesn't.
For radar, you must first decide if you want an installed stealth system or a window mount unit.
Escort and Radenso are leaders in the radar market, and definitely worth considering. Just don't waste your time with the Escort laser defense, it's not up to the standard of ALP.
The new Valentine 1 is highly rated for a window unit, but seems to have issues with BMW cars featuring the gesture control. Radenso has been working on a fancy new window unit called Theia, but it's still not available and I don't think there is a definitive release date.
Stay away from K40 like the plague. They are junk.
      11-15-2020, 09:02 PM   #9
lsal
We are all Longwong
lsal's Avatar
Drives: F90 CP LCI
2013 BMW M3  [10.00]
Have you seen any nice stealth placements for the controller unit (or at least flush)?
      11-16-2020, 06:12 AM   #10
subterFUSE
subterFUSE's Avatar
564
Not in the M5.
I have an ALP in my Mercedes, but we did a major stereo installation there and the ALP control pad was flushed into a custom center console armrest we built for that. Probably not something most people here would be attempting.
      11-16-2020, 07:09 AM   #11
lsal
We are all Longwong
lsal's Avatar
Drives: F90 CP LCI
2013 BMW M3  [10.00]
Not in the M5.
That's sort of what I'm looking for See my pic above from my last setup. Looking for that kind of quality. I don't want to sacrifice the wireless charger (otherwise that would be perfect), so leaning towards cutting into the panel near rite shifter (bottom right). So far that's the beat option I can see.
      11-16-2020, 08:53 AM   #12
subterFUSE
subterFUSE's Avatar
564
Not in the M5.
Here is what we did in my Merc.
It's a custom arm rest with iPad Pro, controls for the new stereo and the ALP all flushed in at your fingertips.
      11-16-2020, 09:45 AM   #13
lsal
We are all Longwong
lsal's Avatar
Drives: F90 CP LCI
2013 BMW M3  [10.00]
Not in the M5.
Really nice work!! Did you essentially sacrifice the arm rest?
      11-16-2020, 05:26 PM   #14
subterFUSE
subterFUSE's Avatar
564
Not in the M5.
No. We removed the top section and kept it so I can return the car to original condition.
      11-16-2020, 07:03 PM   #15
lsal
We are all Longwong
lsal's Avatar
Drives: F90 CP LCI
2013 BMW M3  [10.00]
Not in the M5.
Very nice work.
      02-07-2021, 07:45 AM   #16
5tony
Drives: '21 M5/'15 X5 35i/'88 M3
For those of you running the ALP, are you using two or three sensors up front? Any suggestions on where to tap in to the car for switched power? Thanks!
      02-07-2021, 08:07 AM   #17
13M5F10
Hide! My wife's coming!
13M5F10's Avatar
Drives: 2013 BMW M5 | MSR Stage 3
Best setup will be two heads and the TX so 3 total sensors up front.
*** SOLD *** 2013 BMW M5 | Space Grey | MSR Stage 3 Tune | Catless Downpipes | MSR Intake and Charge Pipes | MSR Exhaust (Prototype) | Vorsteiner Rear Diffuser | RW Carbon Front Lip | RW Carbon Trunk Spoiler| Vorsteiner VS-310 Forged Wheels | Escort 9500CI w/Laser Jammers
lsal134.50
      02-08-2021, 07:50 AM   #18
subterFUSE
subterFUSE's Avatar
564
To counter the most modern threats, 3 sensors are required. And you must have ALP. No other laser system works. Period.
The preferred setup is two Rx sensors and 1 Tx sensor. To use this arrangement, the sensors MUST be inside of the kidney grills. The Tx has to be near the center of the car.
If you cannot install in the kidneys, then your alternative setup is 3 Rx sensors. This setup will not protect as well as the above alternative, however.
5tony145.50
Search this Thread:
Advanced Search
