10-24-2020, 06:12 PM | #23 |
1247
Rep 4,088
Do you think more tire (via wider wheels) would even the odds, or still wouldn't be enough to compensate for the weight? I'm fine not being the fastest on the track, but I'd like to be in the top third so I'm not just pointing everyone by and messing up my rhythm.
10-24-2020, 06:16 PM | #24 | |
Perennial PFC
335
Rep 1,274
You posted the Eastwood retractor tool, and perhaps you already know this about the EMF actuator, but I ran into this post years ago and it was helpful for me. Post #42 has pictures. https://f10.5post.com/forums/showthr...=634891&page=2 |
10-24-2020, 06:18 PM | #25 | |
1816
Rep 1,304
if you're getting the competition, you'll be getting the better suspension, so it will do better. Very likely I need the KW of BMW M performance suspension for my track duty. Lowering might help, but I like the ride height where it is. Shawn |
10-24-2020, 06:33 PM | #26 | |
Perennial PFC
335
Rep 1,274
Also, I installed the Dinan HAS on my base model F90 and have liked it for the street. Haven't tracked it yet, but the springs feel more like the stock Comp model. Plus, you can fine tune the height if you wish. https://f90.bimmerpost.com/forums/sh....php?t=1759732 |
10-24-2020, 06:33 PM | #27 | |
1816
Rep 1,304
But, the last time I had to do it, I had to do it at the track between sessions. I thought "there has to be a better way". I think this tool will do the job, but of course the question is whether it will wind the motor/piston properly without removing the motor. Shawn |
10-24-2020, 06:40 PM | #28 |
Perennial PFC
335
Rep 1,274
I don't think it will do anything for the electronic adjustment part of a pad replacement. It will only push them back to where the last setting of the worn pads was. I think manually turning the adjuster back is necessary. Or, perhaps some sort of coding electronically that a service tech might know of?
10-24-2020, 06:42 PM | #29 | |
1816
Rep 1,304
My wheels are far from standard, as they are square. And the Toyo RR's have a pretty big sidewall, which is what touches. So, each fitment is unique. Shawn |
10-24-2020, 06:44 PM | #30 | |
1816
Rep 1,304
Shawn |
10-24-2020, 06:49 PM | #31 | |
Perennial PFC
335
Rep 1,274
10-24-2020, 06:52 PM | #32 | |
1816
Rep 1,304
Shawn |
10-24-2020, 07:00 PM | #33 |
Perennial PFC
335
Rep 1,274
Yes, good video. The only thing that comes to mind is rotating the piston and what that might do to the seal? I don't know how many full rotations it will take from a fully worn pad (like I saw on one of your posts...down to the metal!) setting to allow a fully thick new pad to be installed, but the bore is smooth, it shouldn't damage it.
10-24-2020, 07:20 PM | #34 | |
1816
Rep 1,304
Shawn |
10-24-2020, 07:28 PM | #35 | |
Perennial PFC
335
Rep 1,274
I keep thinking in terms of hydraulic actuation, in and out, rather than a small electric motor turning things, funny. |
10-26-2020, 06:15 PM | #36 | |
41
Rep 82
(I didn't track my times as I'm normally driving my Viper.) I did hit 163 mph before hammering the brakes on the back stretch and was able to stay in front of C7 Z06's. It was awesome. Brakes with street driving are very grabby (initial bite) but on the track they felt pretty squishy. Applying more brake force helped but not confidence inspiring. The Michelins also jumped 10 -11 psi after 3 laps - then only got worse (greasy). Would love to run out there with some real brake pads and some Hoosiers! |
11-07-2020, 04:01 PM | #37 |
1816
Rep 1,304
New track pads tested. Great braking, and great endurance. So far better than stock.
I ALSO think they are less noisy than the stock pads. But I don't really care so long as they brake well. Details coming as soon as the manufacturer lets me. Shawn |
ashmostro1246.50 |
11-08-2020, 01:02 PM | #39 |
1816
Rep 1,304
A pretty aggressive compound. Not metal on metal squeal like I'm used to, but better than the stockers. Fade is less. Wear is less. I have to gauge the noise on the way home since I finally have a nice pretty blue transfer layer
Shawn |
11-08-2020, 01:10 PM | #40 |
1247
Rep 4,088
Yep, agreed with last bit.
Given the obnoxious rear calipers on this car that make pad swaps more than just a simple matter, I’m particularly interested in any pads that can passably serve double duty. Thanks for the updates! |
12-27-2020, 05:59 PM | #41 |
1816
Rep 1,304
Have now used the RacingBrake pads on track. Superb wear. They have now made some additional compounds, and are working on rotors. I highly recommend this company. I have a lot of experience with them from my Nissan GT-R with tons of track use.
Pads: https://racingbrake.com/f90-2018/ Working on Rotors: https://racingbrake.com/m5-m6-1/ I have to tell you, the pads and rotors this company made were HEAD and HEELS above the stock Nissan stuff. The front rotors I have tested already are MUCH, MUCH better than the stock pads. I think I'll have more to say as I get more pads and they get those rotors ready. My rears are looking BAD. Shawn |
ashmostro1246.50 |
12-27-2020, 06:13 PM | #42 |
1247
Rep 4,088
This is super cool news Shawn. Thank you for paving the way for the rest of us.
I’m glad to see they are working on rotors too. I’ve used theirs in the past and had great results with them. Do you know if RB recommends either new rotors, or removal of previous transfer layer in order for these to work? In my experience, it’s not necessary with track pads if you first drive on the street for a week and let them “polish” the rotors on their own. Let me know if this is something that was discussed. Thanks again. -Ash |
12-27-2020, 06:16 PM | #43 |
1247
Rep 4,088
Just looked at the link for the pads. Those look like street pads, per the description. Will there be another product drop for track use, still coming up?
01-03-2021, 07:46 PM | #44 | |
1816
Rep 1,304
I have never done it. Everything has always been fine. I think it's for people who are inexperienced with new pads, and the fact that the braking can be unexpectedly crap for the first five applications or not. Shawn |
