12-27-2020, 06:04 PM | #1 |
210
Rep 323
Drives: BMW X5 G05 30d/BMW M5 F90 Comp
Loose side trim
Hi,
The side trim on my M5 is not clipped in properly. I wont be back at the dealer for at least a few months. Is there a DIY solution? I dont want to break the clips as it probably wouldn't be covered by warranty anymore. Are there instructions for taking it out or is it safe to push it in? The issue is only on the right side, the left is fine. See photos. |
12-27-2020, 06:25 PM | #2 |
377
Rep 541
From the pics I don't see anything loose? Anyways, I replaced mine with carbon fiber ones and it's dead simple. To install them you just line it up and push it in. So, if you feel anything loose pushing the clips back in is definitely what you should do. In case you need to remove them just put some painter's tape around the vents (to protect the paint against the pry tool) and use a pry tool to pry it out.
12-27-2020, 06:28 PM | #3 |
210
Rep 323
12-27-2020, 10:20 PM | #6 |
210
Rep 323
12-27-2020, 10:26 PM | #7 |
3323
Rep 8,083
12-27-2020, 11:07 PM | #8 |
1105
Rep 1,607
Drives: 2020 M8 Comp First Edition
GT
2020 BMW M8 Comp First Edition 2019 Panamera Turbo 2021 BMW X6M Comp 2019 BMW M5 2018 Maserati Ghibli SQ4 GranSport |
01-13-2024, 11:10 AM | #10 |
233
Rep 553
Drives: 2018 M5 / 2011 X5 35d
Did you get this fixed? I’m having the same issue on both sides. The entire trim (2 pieces) are just lose from the body of the car. I have to assume it is supposed to fit tightly in there.
01-18-2024, 03:07 PM | #12 |
228
Rep 298
The side grills are so easy....
You can literally pull them off by hand and just click them back in. I did that to swap them to black form the OE chrome. Just pull them out don't be shy ,,, then snap them back in |
