BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    NEW RELEASE: Dinan F90 M5 Cold Air Intake & Turbo Inlet Pipes
      09-23-2021, 04:49 PM   #89
brad65ford
256
Drives: 2022 M3
haven't driven it yet but the parts looks quality. Wishing Dinan offer a intake scoop as well separately similarly as AWE or Eventuri does. That is next on my list
      09-23-2021, 04:54 PM   #90
Dinan_Engineering
Dinan_Engineering's Avatar
Drives: Any BMW
Our intake scoop is part of the front section of the intake so I don't foresee a seperate piece developed.
      09-23-2021, 04:54 PM   #91
brad65ford
256
Drives: 2022 M3
understood
      09-23-2021, 05:55 PM   #92
SGMM5
SGMM5's Avatar
116
Drives: 2020 M5, 2001 Lexus IS300
Only tip I'd add on the install is to watch the hose clamp on the left intercooler pipe. Mine was rotated a little counter clockwise from where it prob should be and it's really tight to the new inlet at that point. I had to rotate the clamp a little to keep it from hitting and scratching the new inlet.
      09-23-2021, 06:04 PM   #93
brad65ford
256
Drives: 2022 M3
Really like the look, kind of OEM'ish.
      09-23-2021, 08:42 PM   #94
AngryInch
213
Drives: 2021 BMW M5 Comp
How’s everyone figment over the turbo? Do you find them slightly looser than stock? I can rock mine from and back very slightly, curious if that is normal?
      09-23-2021, 08:43 PM   #95
brad65ford
256
Drives: 2022 M3
My driver side was like that then I realized i forgot that 1 gasket to put on. Take off the side that is loose see if the gasket is still there.
      09-24-2021, 07:02 AM   #96
SGMM5
SGMM5's Avatar
116
Mine are both pretty tight. Similar to the stock pieces. At first one wasn't fully seated cuz the clip wasn't all the way down. One of the "legs" wasn't in the slot.
      09-24-2021, 09:01 AM   #97
GTATX
GTATX's Avatar
Drives: 2020 M8 Comp First Edition
Now I need to check mine lol. I don't remember any gaskets. I thought all I had to do was add clips on top and that's it.
If anyone has pic of gasket that be great. Thx
GT
2020 BMW M8 Comp First Edition
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
2018 Maserati Ghibli SQ4 GranSport
      09-24-2021, 09:16 AM   #98
AngryInch
213
You better do that right away, you are likely sucking in dust.. the gaskets are in the stock pieces, you pull them out and insert into the depression inside the new inlets. Those gaskets seal the inlets to the turbo housing and are pretty critical.
      09-24-2021, 09:54 AM   #99
GTATX
GTATX's Avatar
Got it I'll get it done today.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      09-24-2021, 09:56 AM   #100
Dinan_Engineering
Drives: Any BMW
Gasket in question is pictured on page 6 of the installation manual linked a couple posts back. It's the reddish O-ring looking things.
      09-24-2021, 09:58 AM   #101
GTATX
GTATX's Avatar
My bad oversight on my part. I'll get it done today
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      09-24-2021, 04:20 PM   #102
GTATX
GTATX's Avatar
So i was able to add the gasket and everything clipped fine but Inlet still doesn't sit flush specially on driver's side. There is a little space in between. Can someone share their pic please. Thanks
I'll add mine as well.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      09-24-2021, 04:25 PM   #103
brad65ford
256
Drives: 2022 M3
Mine doesn't go all the way back as well but it clips in so not worried. BTW glad i mentioned the seal
GTATX1105.00
      09-24-2021, 04:50 PM   #104
GTATX
GTATX's Avatar
Thanks a lot bud if it wasn't for u I thought I was good to go lol but no harm done. Just did a 10.24 at 139mph almost 2500 DA and 75.F lol
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
Mcc420475.00
      09-24-2021, 08:00 PM   #105
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
That trap is 🍌 fast!! Do you launch in 4wd or 4wdSport?
2018 M5 Singapore Grey CCBs/Utku Noa E45 ECU/xHP TCU/PG-Intake/PG-Lower Downpipes
      09-24-2021, 08:08 PM   #106
AngryInch
213
I wish!! What’s your mods? I can’t get above 133mph fml.
Can you post a log and time slip?? I want to see your timing.
      09-24-2021, 08:14 PM   #107
GTATX
GTATX's Avatar
4WD
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      09-24-2021, 08:41 PM   #108
brad65ford
256
Drives: 2022 M3
4WD
Interesting, i've never run in 4wd mode.
      09-24-2021, 08:44 PM   #109
GTATX
GTATX's Avatar
4WD
How do u launch then?
I thought LC minimum requirements are:
Engine Sport Plus
Transmission S3
Dsc off
4WD
Rest I keep suspension condor
Steering sport plus
Both those parameters don't matter
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
      09-24-2021, 08:50 PM   #110
GTATX
GTATX's Avatar
I wish!! What's your mods? I can't get above 133mph fml.
My mod list is as follows:
Evolve utkunoa
Custom E30 Meth Stage 2
TCU Custom Stage 3 utkunoa
Keller 3inch downpipes
Remus cat-back
Dinan intake and inlet
Autotechnik Front air scoop
Snow performance stage 3
70/30 meth mix
RK Meth Adapters
90C thermostat
Redline 5W50 Motor Oil
NGK 2 Step colder plugs
BBS Fi-R 21inch with 285 Fr- 295 Rr
H&R M550i springs
JB4 for just data and logging.
GT
2019 Panamera Turbo
2021 BMW X6M Comp
2019 BMW M5
