BMW M5 F90 (2018+) General Forums Engine, Exhaust, Drivetrain, Tuning Modifications    Are S63TU engines still bending rods/blowing up a lot?
      06-18-2021, 12:20 PM   #1
MuffinFlavored
79
Drives: 2014 F10 M5 MT
The tuning scene here seems kind of dead. Looking to get into an F90, curious if tuning it is just going to make the engine a ticking time bomb.
      06-18-2021, 01:06 PM   #2
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Are you a betting man?
      06-18-2021, 01:21 PM   #3
MuffinFlavored
79
Do you know of any F90 engines failing? Stock, stage 1, or stage 2?
      06-18-2021, 01:29 PM   #4
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Yes. Most won't come here and talk bad news. Forums are for sharing good stuff so you won't see it much. Most don't know the perfect storm that makes them let go either. Custom tunes where u can tune out that initial hit and ramp in TQ are your best bet for the motor. JB4 is your best bet for if it goes boom, you're "covered"
2018 M5 Singapore Grey CCBs/Utku Noa E45 ECU/xHP TCU/PG-Intake/PG-Lower Downpipes
      06-18-2021, 01:30 PM   #5
MuffinFlavored
79
That's a myth.
Go read how they use GPS telemetrics and ABS settings from an actual engineer: https://g20.bimmerpost.com/forums/sh....php?t=1834548
Appreciate 3
      06-18-2021, 01:40 PM   #6
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
That's a myth.
That's a myth.
ok lol
      06-18-2021, 01:55 PM   #7
MuffinFlavored
79
Is it most commonly bending a rod or not?
      06-18-2021, 04:08 PM   #8
bpma
155
Drives: M5C Stage 2
I blew my engine on a stage 2 tune.
      06-18-2021, 07:06 PM   #9
PaLaKaT
71
Drives: 2022 X6M
Give a little more info, what did u? What tune? What were the numbers being pushed? What car year/model?
      06-18-2021, 10:39 PM   #10
TrevorM3
3322
Drives: 6.3 AMG
you are asking a question with way too many variables.
TTV8M122.50
      06-19-2021, 12:24 PM   #11
19M5
Drives: 2019 BMW M5
Yes. Most won't come here and talk bad news. Forums are for sharing good stuff so you won't see it much."
Really? You would think there would be some on line chatter if a mod engine blew.
2019 BMW M5
2016 Dodge Charger HC
2005 E55 AMG Wagon
      06-19-2021, 01:38 PM   #12
DrivenAgain
MFJWADE
120
Drives: 2018 BMW M5
Forums are for sharing yes, but there can be a bit of shame that can go along with a motor letting go, and that can lead most to not share. There are also legal implications that rule many decisions.
Appreciate 2
VPRKLR63.00
TTV8M122.50
      06-20-2021, 01:45 PM   #13
MuffinFlavored
79
I agree. I think 85% of blown F90 engines are going unreported on these forums.
      06-20-2021, 03:24 PM   #14
bpma
155
Drives: M5C Stage 2
2018 model, done 35k kms. The tune was custom, 800 hp, 960 nm. In retrospect, it was inevitable.
It blew when I floored it with 2-3 liters of RON95 petrol left in the tank, I ALWAYS got the RON100 at Shell, this was the only time I was on the road and it wasn't available. Welp.
Appreciate 2
PaLaKaT71.00
TTV8M122.50
      06-20-2021, 04:01 PM   #15
Mcc420
Mcc420's Avatar
475
Drives: G80 M3CX
2023 g80x  [0.00]
  [0.00]
Looks like you lost the tip of a spark plug.
G80 Comp, Hcp custom e50, 9.69@141
F90 Comp, Hcp custom e40 meth, 9.76@143, 174ml/h 1/2ml 60-130 5.53
F10 M5, HCP Tune ,BM3, 10:8@137, 166.05 1/2ml.
Ig @mcc420
FSociety3812.50
      06-20-2021, 06:07 PM   #16
onfireX5
3619
Drives: F90M5,F85X5M
Piston and Rod failure due to lean/knock ?
      06-20-2021, 09:02 PM   #17
pbonsalb
5234
Most common failure in modified factory turbo motors.
      06-20-2021, 11:49 PM   #18
PaLaKaT
71
Drives: 2022 X6M
Thanks for the info! Did you build it up after? Or just replaced the engine and kept it stock?
      06-21-2021, 02:38 AM   #19
bpma
155
Drives: M5C Stage 2
I'm currently driving a replacement engine (slight tune to Stage 1 / 700hp), the old motor is being built. Once it's done, I'll try to get it to 1000hp. Not sure how long that will last, but since I already have a second engine if things go south, I don't have many excuses.
Also apparently MY20 engines are more durable - one of the changes is that the cylinder liners are made from cast iron.
Appreciate 2
      06-21-2021, 01:34 PM   #20
PaLaKaT
71
Drives: 2022 X6M
Very nice! What are you running now? BM3 stage 1 93 oct or DME?
      06-21-2021, 11:12 PM   #21
MuffinFlavored
79
What about the rods? I was under the impression the engine effectively has glass rods and a little detonation/knock with higher-than-stock boost and it's game over.
      06-28-2021, 04:18 PM   #22
Tak M5
Drives: F90 M5C
So based on your comment, you believe that even stage1 off the shelf maps are dangerous?
