09-29-2022, 09:19 PM | #45 |
5234
Rep 10,616
I would not bother with race gas. Experiment to find your ideal E85 mix without a tune (or buy a tune). Race gas costs too much. E85 is cheap. Performance has to be easy and sustainable. Otherwise you will find yourself when challenged to a speed contest with hood competition to decline or say, “no, I don’t actually have a car that will run 10.3 at 135 right now — let me go get some E85 and let the computer adapt….” I use meth because there is no E85 locally and I don’t want to buy 55 gallon drums and pump myself into every tank.
09-30-2022, 08:01 AM | #46 | |
Rep 15
09-30-2022, 08:14 AM | #47 |
5234
Rep 10,616
You are just adding octane for consistency unless the tune is designed to be flexible (Carbahn claims its tune will adapt). How you add a little octane is up to you. Race gas is a waste in my opinion since it has about $10 per gallon. Mixing in some E85 is the way to go if it is readily available in your area. Even a stock tune can handle a little E85.
If you really want to add more performance through octane, you need a tune for that octane. Otherwise it is just a safety device to ensure the tune performs as expected. Most tunes are conservative to start with. |
10-01-2022, 10:17 AM | #48 | |
1416
Rep 1,564
10-02-2022, 02:43 PM | #49 |
Rep 15
Have not tried ethanol or race gas yet. Hoping to get to the station today or tomorrow, but did run my personal best 60-130. I am just happy the Noelle was not a complete waste of $3K (More like a waste of $1500). Wondering what little upgrades to do next. Do not want to get too nuts as it is my daily.
10-02-2022, 02:54 PM | #50 |
5234
Rep 10,616
That is fast. You can’t add any more boost with that tune and the tune is made for 93 so more octane probably won’t help much. It will make performance more consistent, such as not dropping power on a hot day.
I would remove the charcoal filters if you have them in your air boxes, buy the Dinan turbo inlet pipes, and swap to catless secondary downpipes. Leave it at that — a tiny bit less restriction into the motor and a tiny bit less restriction out. Last edited by pbonsalb; 10-04-2022 at 07:08 PM.. |
10-04-2022, 04:25 PM | #51 | |
Rep 15
10-04-2022, 07:09 PM | #52 |
5234
Rep 10,616
If you do want to go further, you could buy a JB4 and meth kit and add more boost when the meth is flowing. I do this but with a BM3 OTS Stage 2 tune for 93 pump.
10-05-2022, 05:12 PM | #53 |
146
Rep 279
Drives: F90 M5
So Noelle Tune is legit then? In the 6s and low7s suggest 850 crank hp
10-17-2022, 08:47 AM | #54 |
Rep 28
10-17-2022, 08:52 AM | #55 |
5234
Rep 10,616
It could be most tunes do because the ECU talk to each other. I am think my BM3 flashed both ECU. But that may be different from an actual trans tune like XHP.
03-13-2023, 09:57 AM | #56 |
Rep 28
https://www.roadandtrack.com/car-cul...e-performance/
Would R&T stake their reputation on it? This, Noelle says, reduces the reliability problems that tuned cars sometimes face. That's why the company backs up its tuned cars with warranties. Should you experience a powertrain component failure that BMW won't cover due to the modifications, Noelle will fix it within the duration of the original factory warranty. |
03-13-2023, 10:08 AM | #57 |
Rep 28
others are also using. I am not for or against, i look at the data and personal experience. and i get that folks who have gone thru great lengths to achieve the same or better, i chose for simplicity, and big picture.
https://f87.bimmerpost.com/forums/sh...1681415&page=2 https://www.bmwblog.com/2019/11/15/n...-ft-to-f10-m5/ |
03-13-2023, 03:05 PM | #58 | |
5234
Rep 10,616
