10-22-2020, 05:43 PM | #89 |
405
Rep 380
Peter is correct. ET 45 9.5 rear is aggressive even with 255. That is my street setup. 43 is a poke with 265s. My 255s on 9.5 at 45 is at the very edge.
10-22-2020, 05:49 PM | #90 | ||
7
Rep 74
Are you rubbing at all? Would probably be possible with about 2° camber you think? |
10-22-2020, 07:27 PM | #91 |
405
Rep 380
No rubbing. My rear offset and 255 tires are known to be a safe fitment. To run 265s you will need to be in the 53 offset range.
10-23-2020, 07:44 AM | #92 |
JY01
697
Rep 303
Got some Apex EC-7s yesterday, digging this new setup
18x8.5 ET45 with 5mm spacer, 235/40/18 18x9.5 ET58 with 5mm spacer, 265/35/18 Tires are Bridgestone S04 Pole Positions, they seem to run wide but the 5mm spacer gives me just enough room to clear the shocks |
10-23-2020, 11:44 AM | #93 |
405
Rep 380
Looks great!
10-23-2020, 04:48 PM | #94 | |||
3587
Rep 6,818
This guy is running 19x9.5 ET43 in the rear. The angles of these photos make it tough to see, but it will definitely poke as others have pointed out and may rub under suspension compression especially with wider tires. Quote:
-Tom
925-245-0773 /// info@apexraceparts.com
Wheels /// Accessories /// Vehicle-Specific Fitment Guides /// Careers |
10-23-2020, 07:42 PM | #95 | ||
7
Rep 74
On one of his post he said no camber, no spacers, no rubbing and just a slight poke. So seems doable. He's on M Performance Springs, I'm on Dinan Springs. Also, I wasn't planning on running wider tires, I was aiming for 255. I guess my main goal is to try and avoid using a 5mm spacers. If I can add a little negative camber and maybe stretch the tires more (245?if that's even advisable) to fix the tiny poke, I'm willing to do it if it's a slightly more aggressive and dialed in fitment. Forgot to mention, I plan on tracking this car so I would end up with around -2.25° negative in the rear, which I believe should clear roughly 8mm or so. Therefore, the more aggressive ET43 should not really be poking at that point based off how I calculates everything and imagine it would be. |
01-05-2021, 06:46 PM | #96 |
3587
Rep 6,818
We seem to never have enough 2 series content. Lets see your photos with APEX wheels if you have them!
I found some old pics from one of our customers from back in 2015. His F22 was on a staggered set of APEX EC-7 wheels in Race Silver finish. APEX Wheel Fitment Specs:
01-08-2021, 07:32 PM | #97 |
261
Rep 559
Here's mine with EC-7s in anthracite with Michelin A/S 3+:
Front: 18x8.5" ET45, 5mm spacer, 235/40 Rear: 18x9.5" ET58, 5mm spacer, 265/35
My 2017 M240i: MHD, xHP, Modded OE Intake, AA GESi 400 CPSI Cat DP, Dinan Mid-pipe, M Performance LSD & Rear Diffuser, BMS Exhaust Tips, Apex EC-7 Wheels, M-Tech Front Lip, iND Painted Mirror Caps, Smoked Reflectors
Expert@ApexWheels3587.00 MassNerd173.00 |
01-15-2021, 06:35 PM | #98 | |
3587
Rep 6,818
-Ian
PeterWT261.00 |
02-02-2021, 01:12 PM | #99 |
3587
Rep 6,818
Checkout our customer Jared's 2 series on a set of 18" APEX EC-7 wheels in Anthracite finish!
APEX wheel fitment Specs:
helloelectro175.00 MassNerd173.00 |
02-07-2021, 08:08 AM | #100 |
261
Rep 559
No spacers?
02-13-2021, 12:43 PM | #101 | |
175
Rep 336
PeterWT261.00 Expert@ApexWheels3587.00 |
02-14-2021, 03:14 PM | #102 |
261
Rep 559
Thanks for the confirmation. Looks nice!
helloelectro175.00 |
02-23-2021, 06:27 PM | #103 |
3587
Rep 6,818
The Fully Forged APEX ARC-8R and EC-7R feature a profile 2 medium concave design in all sizes. This allows even the F2x chassis to have some concavity despite the high offset requirements.
03-18-2021, 02:45 AM | #104 | |
Rep 13
03-18-2021, 11:07 AM | #105 | |
3587
Rep 6,818
We produce a large number of 18x8.5 ET35 wheels for other BMW chassis as this is a very versatile width and offset combination that works as either a front fitment or square fitment on other non-M cars. 18x8.5 ET45 was developed specifically for the high offset requirements of the 1 series chassis and is really only used on the 1 and 2 series. Its offset is slightly higher than ideal for the 2 series front fitment but can be compensated for with a spacer and is ideal for the rear fitment of the 2 series. There isn't enough demand for a 3rd 18x8.5 ET40 wheel that would slot between these 2 wheels specifically for the 2 series market front fitment. -Tom
03-23-2021, 01:43 PM | #106 |
33
Rep 43
Not my first bimmer but my first to wear Apex-es
FL-5 18x8.5 ET35 square wrapped in 235/45 MPS4S. I am running Dinan springs and the fronts rub the fender lip just slightly under rapid compression, but it occurs so infrequently it's no biggie for me.
Current - '15 228i
04-03-2021, 04:55 PM | #107 |
Too many cars, not enough time
43
Rep 73
Updated pics now that I've installed ST XA coilovers... Wheel/tire spec in sig.
FOR SALE: 2017 ///M240i, 6 speed, slick top, Estoril Blue. https://www.2addicts.com/forums/show....php?t=1865469
Expert@ApexWheels3587.00 BBM135i0.00 |
04-04-2021, 05:36 PM | #108 | |
502
Rep 696
Drives: 2015 f80 M3
What camber are you running and do you like the Millway Streets? I am thinking B16 and the Millway as a combo. Anyway, great looking ride. Looks like are in the same area code as well... josh |
04-05-2021, 09:35 PM | #109 |
43
Rep 73
Thanks! Millway Streets have minimal NVH, no problems with them at all! -2.5 front and -2 rear, love it so far on the street.
And yeah, I'm in Dublin. Don't drive it much though, just random trips on the weekends and whatnot. Last edited by SkyeC; 04-05-2021 at 10:04 PM.. |
04-11-2021, 08:02 AM | #110 |
130
Rep 274
@Expert@ApexRaceParts would you guys ever be interested in developing an aerodisc like product that could be fitted to some of your existing wheels?
