04-30-2023, 05:47 PM | #1 |
72
Rep 65
New tire bubble!
Bought the car used this last Monday, and now I’ve got a bubble on the driver side front tire. The tires were new.
I don’t recall hitting a pot hole or anything in the last week, so I’m wondering if it was already on the wheel when I bought it. Anyway, I’ll replace the tire and call it a day. Just wondering if anyone else has experience with a bubble like this? |
04-30-2023, 05:59 PM | #2 | |
4094
Rep 3,675
Drives: 2022 M5C
Not a BMW guy...but certainly an M5 guy.
Autoregression71.50 |
04-30-2023, 06:02 PM | #3 |
1471
Rep 1,308
See if you can find the photos from when it was posted or if you took any pics before you drove off. If you can see it in a pic — maybe (they should imo) the place you bought from will replace it. Otherwise your current course of action seems about right. Sucks.
Current: 2022 M5 CS
Past: 2021 M550i (BSM) Past: 2010 535 xDrive (Alpine White) |
04-30-2023, 06:06 PM | #4 | |
72
Rep 65
However, these are my first run flats, and by far my heaviest car... Excellent feedback - I will dig those pics up right now! |
ResIpsaLoquitur4093.50 |
04-30-2023, 06:51 PM | #5 |
5234
Rep 10,616
[QUOTE=Autoregression;30086286]However, these are my first run flats[QUOTE]
M5 do not have run flat tires unless you or someone else installed them. |
04-30-2023, 06:53 PM | #6 |
72
Rep 65
04-30-2023, 07:02 PM | #7 |
5234
Rep 10,616
I was not aware BMW had approved any run flat tires for the F90 M5 and am surprised a dealer would install tires that are not approved.
04-30-2023, 07:25 PM | #9 |
4094
Rep 3,675
Drives: 2022 M5C
Most BMW dealerships will sell and install non-OE/non-star marked tires all day long, even ones not purchased from them. I run SottoZero III run flats (but the “performance” version) in the same measurements as star marked PS4S on 706Ms in the winter. I purchased these obviously non-star marked tires from a third party, had them shipped to my dealer, and they mounted them for me.
04-30-2023, 07:34 PM | #10 |
4094
Rep 3,675
Drives: 2022 M5C
Interesting that you mention run flats. With my winter run flats, I find them nearly impossible to bubble. I have hit some insane “phantom” potholes where extreme precipitation has filled them up and you can’t see them in unfamiliar areas, that would cause PS4Ss or P Zeros to bubble immediately. I had two so rough I couldn’t believe the tire didn’t bubble. The SottoZero III run flats were surprisingly resilient.
04-30-2023, 08:14 PM | #11 | |
5234
Rep 10,616
That said, I don’t think run flats are the reason the OP has a bubble. I am just surprised that a BMW dealer, of its own volition, would install parts BMW does not approve. |
04-30-2023, 11:37 PM | #12 | |
4094
Rep 3,675
Drives: 2022 M5C
05-01-2023, 03:41 AM | #13 |
2511
Rep 4,381
In our market BMW dealers (usually) refuse to fit non * rated tyres to F90 M5 stating that it would invalidate the warranty!
The BMW dealer who fitted your tyre can surely make a claim on the tyre manufacturers warranty on your behalf? Noting that there are virtually no * rated Michelin tyres available in F90 M5 sizes in the UK. There is zero stock for retail supply by Michelin UK with no future production dates on the calendar. This due to a shortage of Carbon Black caused by the war in Ukraine. Is production in the USA being affected? Last edited by SenorFunkyPants; 05-01-2023 at 03:48 AM.. |
05-01-2023, 05:23 AM | #14 |
72
Rep 65
05-01-2023, 07:24 AM | #15 |
72
Rep 65
Followup:
1. The FOR SALE photos do not have the resolution to see a small bubble in the tire, so they are inconclusive. 2. The dealer's service department says there is no tire road hazard warranty on used vehicle purchases, unless I specifically purchased one. The dealer is 100 miles away, so it isn't particularly convenient anyway. 3. I bought another tire from TireRack (arrives tomorrow), and will have it installed locally. For the record, the tire size/brand/model is this: 275/35R-20 PIRELLI P ZERO RUN FLAT (PZ4) STAR RSC BMW, RUN FLAT, LUXURY XL |
05-01-2023, 10:09 AM | #16 |
5234
Rep 10,616
I think the star means it is BMW approved. Interesting. Had not read of these before and BMW has not factory equipped F90 M5 with run flats. Put those on the heavy standard wheels and you would have a really heavy wheel and tire combination.
05-01-2023, 10:16 AM | #17 |
316
Rep 396
Drives: 23 M5C, 19 X5
The star means it meets a BMW specification. I bet that tire is OEM on a different BMW model. I figure most used cars are treated like rentals when it comes to tires...mismatched brands between axles, wrong specs, etc.
05-01-2023, 10:18 AM | #18 |
316
Rep 396
Those are the OEM rear tires for the M550.
ResIpsaLoquitur4093.50 Autoregression71.50 |
05-01-2023, 10:55 AM | #20 |
316
Rep 396
I bet you can wear them down pretty fast if you want to
Does anyone know the weight of those wheels? I know the 789M are 27.8lbs front and 29.6 rear. I still need to weigh them with the Pilot Sport A/S4 and PZeros. I will do that this fall when I swap. |
05-01-2023, 11:43 AM | #22 |
316
Rep 396
At least those are actually the correct tire for the M5.
I ran mixed runflat/non-runflat for my CTS-V "winter" (all-season) set because that was the only way that generation of Michelin Pilot Sport A/S came. I wasn't too worried since it was my winter set. Worked out too since I actually ended up with a puncture in one of the run flats. |
