05-14-2019, 10:55 AM | #67 |
19477
Rep 10,180
Its minute to say the least and this is not a track car. If you are the least concerned I would just keep it OEM.
2024 BMW M3 CS Frozen Solid White
2023 BMW M8 Coupe Competition Alpine White 2022 Porsche Carrera GTS Coupe Shark Blue 2020 Audi R8 V10 Performance Suzuka Gray 2012 Mercedes Benz C63 AMG Black Series Obsidian Black |
05-14-2019, 11:05 AM | #68 | |
General
12979
Rep 18,721
But, damper valving will not since you are still using stock damper. So, you will still be in control on your dampening via the driving mode.
Email:sales@rgsport.com | IG:RGSport_USA | Web:RGSportShop.com PM for Everyday DEALS!! MSS • iSweep • RaceChip • Sterckenn • AutoTecknic • Akrapovic • Vossen Wheels • Eventuri Active Autowerke • KW • H&R • Ohlins • Remus • and more... |
dardeca499.50 |
05-14-2019, 11:11 AM | #69 | |
500
Rep 1,313
What I'm trying to confirm is whether a change in springs will impact the electronic features/adjustability of the suspension. Sounds like "no", but just wanted to make sure I have a full understanding before doing a switch. I don't want to find out later that a spring switch eliminated comfort mode or something else.
E92 M3 Supplemental manual p.38: "The laws of physics cannot be repealed, even with DSC."
05-14-2019, 11:18 AM | #70 | |
1716
Rep 1,910
Drives: 2023 M5C
dardeca499.50 r33_RGSport12979.00 |
05-14-2019, 11:49 AM | #71 | |
19477
Rep 10,180
Thanks for the clarity and as Wintendo stated, you are not going to lose any EDC functionality. The main intent of the springs, to me, is form over function. You want a better eye sight of the car when parked as did I. I still wallow over going to the M550i set up but for several reasons I hold off: 1. When I back out of my garage in my other cars the F90 looks plenty low but then again I backing in an R8, GTS, Porsche or an NSX and they are all much lower 2. Im lazy and dont want to go and lose a day for lowering further and then realigning. 3. I dont like Ben LOL aka r33_RGSport and he does my local work 4. Im lazy
05-14-2019, 12:05 PM | #72 | |
500
Rep 1,313
05-14-2019, 12:18 PM | #73 |
19477
Rep 10,180
100%
You are changing the geometry of the oem specs and will need to reset the camber, caster, and toe. Most shops will have the OEM specs and can get the car back to range. If you dont do this you will possible have excessive tire wear and handling issues plus other issues like steering pull.
05-14-2019, 12:35 PM | #74 | |
General
12979
Rep 18,721
1" or less usually is not a big deal. But, again, it will depending on the suspension setup. In this case, the suspension design is double wishbone / multilink. Where the alignment doesn't change much. Camber, usually on double wishbone (front on F90 M5) is not adjustable. While on the rear, multilink, is adjustable both toe and camber. On McPherson suspension design though, like 2/3/4 series (include M), there is camber adjustment on the front. What kills the tire is mainly the toe setting.
05-14-2019, 01:37 PM | #75 | |
500
Rep 1,313
I'll need to get my 1200 mile service done in the not too distance future, so could probably have an alignment done at the same time at my dealership.
05-14-2019, 02:32 PM | #76 | |
General
12979
Rep 18,721
But, usually I recommend to have the spring settled for 1-2 weeks before alignment.
05-14-2019, 04:16 PM | #77 |
4077
Rep 5,235
Not affected.
CURRENT: 22' INDIVIDUAL M5| CHALK | TARTUFO | CCB | MPE | H&R | IND
GONE: 19' M5C| SINGAPORE GREY| ARAGON|VELOS VLS-06|H&R|iPE|IND|XPEL|CF|RADENSO GONE: 15' F10 M5|BSM|BLACK|VELOS VSS-S2|KW|AKRA|IND|CF |ESCORT 360|VELOS PIGGY GONE: 13' F10 M5|SG|BLACK|AKRA|KW|IND LONG GONE: 09' E60 M5|02' E39 M5 |
dardeca499.50 |
05-16-2019, 06:15 PM | #78 |
500
Rep 1,313
Ben - thanks for answering all my many questions and for the great customer service! Can't wait to get the springs and spacers installed.
05-16-2019, 06:38 PM | #79 | |
General
12979
Rep 18,721
05-16-2019, 07:47 PM | #80 |
19477
Rep 10,180
3
05-16-2019, 08:19 PM | #81 |
General
12979
Rep 18,721
I got your beer if you are coming over this Saturday.
05-16-2019, 08:21 PM | #82 |
19477
Rep 10,180
No, I want springs and install and you need to pay me to show up.
05-16-2019, 08:31 PM | #83 |
General
12979
Rep 18,721
05-20-2019, 11:18 PM | #84 | |
117
Rep 402
05-20-2019, 11:22 PM | #85 | ||
General
12979
Rep 18,721
mtndog116.50 |
05-21-2019, 09:26 PM | #87 |
500
Rep 1,313
Decided to go 15 front/11 back + H&R F90 Sport Springs. Car is going to the shop tomorrow for install. I'll post some before and after pics so people can get an idea of the drop on a M5 Comp.
r33_RGSport12979.00 BocaM50.00 |
05-21-2019, 10:27 PM | #88 |
117
Rep 402
