10-09-2019, 03:06 PM | #67 | |
241
Rep 534
Mine is also a company car but out of respect for mechanical things I'm still trying to be kind... :-) |
10-10-2019, 05:41 AM | #68 |
6659
Rep 15,858
10-10-2019, 07:42 AM | #69 |
64
Rep 102
One week since I picked mine up and due to issues getting charging points installed at home and work, not yet charging daily. One charge from 12miles to full last night, and so far, getting 38mpg overall, with a lot of manual S-mode driving and plenty of battery control (set at 70%).
Very pleased to see others getting much higher on regular charges, as that will deliver the benefit I expected. :-) |
10-10-2019, 07:56 AM | #70 | |
17546
Rep 25,131
Your post went down a very different path to that it thought it might take when you mentioned the Highlands and cold....I thought you might refer to greatly reduced range in Cold conditions. A few manufacturers have a handy(ish!) range calculator that allows you to adjust parameters such as ambient temp, AC on/off etc. Obviously this will not help completely as they are designed to show how much of a theoretical 310 mile range is affected by this, but it could help to run the figures and assume like4like maybe 25% range reduction in winter etc. I'd be envious of a standard 12 mile day trip and to my knowledge this is absolutely sweet spot usage for a PHEV.
My car made front page of Bimmerpost
10-10-2019, 08:44 AM | #71 | |
6659
Rep 15,858
Longer trips, (typically 120 miles), ICE will be doing most of the work. So little advantage to having an PHEV on those trips, other than boosting performance when necessary. |
10-10-2019, 09:33 AM | #72 | |
17546
Rep 25,131
X5 45e is 50+ miles I believe and a nice B58 up front too!
10-22-2019, 03:54 PM | #75 | ||
8571
Rep 19,982
Drives: 911, Cayenne Turbo, Disco 4
My experience is that over a journey like that the mpg difference between a journey started with an empty battery versus a full battery, would be about 5mpg in my F30 330e. I expect it would be even more on the G20 version. That would be a journey involving significant sections of high speed running. The battery definitely helps the engine when running in standard hybrid mode, not just for moments of acceleration.
Current: Porsche 911 991 C4S, Porsche Cayenne Turbo, Land Rover Discovery 4. Gone...G01 X3 M40i, Cayman S 987, F31 340i, Cayman GT4, F82 M4 CP, Lotus Exige V6, G20 330e, F30 330e, Boxster S 987, F31 335d, Mini Cooper SD, E89 Z4, E90 330d 320d, E60 520d, E46 330d 320d, MX5s, E30 325i
HighlandPete6658.50 |
10-23-2019, 12:55 AM | #76 | |
241
Rep 534
10-23-2019, 02:28 PM | #77 |
64
Rep 102
Out of interest, I presume you are charging at both ends of your journeys, and driving in hybrid mode all the time until the battery is exhausted? And presumably you're using eco-pro mode?
10-24-2019, 09:27 AM | #81 |
48
Rep 170
10-24-2019, 10:36 AM | #82 | |
241
Rep 534
10-25-2019, 02:00 PM | #84 |
Rep 9
Got my brand new 330e last Monday. It has been a pleasure to drive, but today I got a brake fluid warning, saying service was due back on 2001... Was it an easy fix for you guys who had this same problem?
10-25-2019, 02:41 PM | #85 |
Grumpy Old Git
443
Rep 923
Drives: BMW G20 330i RWD M Sport
Report to Dealer... quick fix according to those who have had this warning.
Retired:
F10 520D M Sport E60 520D SE Volvo S60 type R |
10-27-2019, 01:55 AM | #86 | |
66
Rep 146
10-27-2019, 10:10 AM | #87 |
48
Rep 170
Ok, so here's my observation:
Removed from charge - 22 miles of electric distance. Drove 6.5 miles (with a bit of traffic and a bit of a road at 60 mph). Parked. Drove back same distance. Parked. Drove another mile. Parked. When returned - 11 miles on electric only remaining. |
10-28-2019, 04:26 PM | #88 |
Rep 9
Ended up sorting this out on my own. After complaining to my dealer over the phone she sended me a pack of instructions that I had already read somewhere on this forum, detailing how to reset oil service. It worked flawlessly.
